Plugin for NIBE MyUplink ( not NIBE Uplink )
ismo67
Has someon made MyUplink plugin for Domiticz?
I think many would be very insterested it like me. Nibe is very popular Heat Pump for floor heating systems at Nordics.
There is Uplink plugin available but MyUplink is different somehow.
I heard from Nibe that Uplink cloud will be cancelled soon and all products will be moved under MyUplink cloud after firmware upgrade.
https://dev.myuplink.com/login
https://myuplink.com/
Rasperry Pi4, Shelly, Yeelights, Xiaomi, Tuya, Tahoma, ESPEASY, Google Home
- Domoticz version: 2026.3
Re: Plugin for NIBE MyUplink ( not NIBE Uplink )
You could ask the writer of the nibe uplink plugin if he planned to update it to myuplink.
Edit: https://github.com/flopp999/NIBEUplink-Domoticz
Perhaps you can buy him 2 coffee
Staafnet
Yes, NIBE Uplink will not work any more after 1 June.
With myUplink there's no delay if you use Premium functions.
i finally gave up and used nodered to download nibe data... i found a working node for it and it worked almost on the first try.... plus as a bonus i simply redirected it to the old IDX numbers from the old nibe addon and it works. ...
if anyone is interested I can send the instructions
JeroenG
- Domoticz version: 20231
Can you please post the code, would like to try it.
Jeroen
Jeroen
so you need nodered, mqtt server
and install this node https://github.com/zinen/node-red-contr ... uplink2024
then you have to read json data from nibe and choose what I want to forward to domoticz
my example was...
and all works
btw any plans for domoticz to support to change multiple values in one mqtt message?
my example was...
msg.payload = [
{ idx: 702, nvalue: 0, svalue: msg.payload.room_temperature_bt50.value.toString() },
{ idx: 697, nvalue: 0, svalue: msg.payload.current_outd_temp_bt1.value.toString() },
{ idx: 1952, nvalue: 0, svalue: msg.payload.return_line_bt62.value.toString() },
{ idx: 1951, nvalue: 0, svalue: msg.payload.supply_line_bt61.value.toString() },
{ idx: 703, nvalue: 0, svalue: msg.payload.heating_medium_pump_speed_gp1.value.toString() },
{ idx: 698, nvalue: 0, svalue: msg.payload.degree_minutes.value.toString() },
{ idx: 705, nvalue: 0, svalue: msg.payload.status_compressor_eb101.strVal.toString() },
{ idx: 704, nvalue: 0, svalue: msg.payload.number_of_starts.value.toString() }
return msg;
What is wrong with the new plugin Flopp created? https://github.com/flopp999/NIBEmyUplin ... /tree/main
its not working reliably (already send bug report), and with node-red its more modular...waltervl wrote: Tuesday 16 July 2024 8:12 What is wrong with the new plugin Flopp created? https://github.com/flopp999/NIBEmyUplin ... /tree/main
