This could not have happened without the help of everyone who contributed to make this happen!
Forum moderators, users, beta testers and specially all those who contributed with code! Thank you once again!!!
As always, PLEASE make a FULL backup of your Domoticz folder (or in case of an embedded system, your SD card!)
This way you can always return to the previous version you were running before this update!
Thanks to all volunteers who helped with the implementation! I know it was a lot of work with a lot of stress!
A few notes before updating:
- Because some users are still experiencing migration issues to ZWaveJS-UI, OpenZWave is back (No support!).
The OpenZWave project was stopped 2 years ago.
We still urge ysers using OpenZWave to migrate to ZWaveJS-UI in combination with the MQTT Autodiscovery method build into Domoticz.
(See https://www.domoticz.com/wiki/Zwave-JS-UI) - Armv6 device support has been stopped. Sure, you can still build Domoticz yourself, but no binary versions are published anymore.
This means devices like the Raspberry Pi 1, Pi Zero from ~12 years ago are not supported anymore. - When using Domoticz with client/server setup (multiple locations), it is important that both server and client run this version or a beta.
- Support for remote updating a RFXCom transceiver has been removed as it was not working 100% with the latest models.
This was a joined decision between us, and you now need to use the flash application from the RFXCom website.
For a full detailed overview visit:Version 2024.7 (July 13th 2024)
- Implemented: P1 Meter, Report, Header now also supports simple mode (No T1/T2/R1/R2 but just total)
- Fixed: Google Cloud Messaging (GCM/FCM) possible crash when notification needed to be send
Version 2024.6 (July 8th 2024)
- Fixed: EventSystem, LOG_FORCE now always logged
- Changed: Google Cloud Messaging (GCM) now uses the new v1 API of Google's Firebase Cloud Messaging (FCM)
Version 2024.5 (July 7th 2024)
- Implemented: Currency Symbol in Location Settings
- Implemented: dzVents, Added historical data helper 'med' to calculate the median value
- Implemented: dzVents, Improved logging
- Implemented: Energy Dashboard
- Implemented: Enever, Added Budget Energy and Eneco
- Implemented: Enphase, Live storage data
- Implemented: Enphase, Option for more Inverter details (ac/dc voltage, temperature, lastupdate)
- Implemented: Event Editor, Close/Close All menu dropdown
- Implemented: Event Editor, Storing/Loading opened events
- Implemented: Hour chart for P1 log
- Implemented: MQTT-AD Climate Fan Mode
- Implemented: MQTT-AD Climate Swing Mode
- Implemented: OpenWeatherMap, API 3.0 support
- Implemented: P1 Meter, option to specify view (low/high tariff or simple (dynamic contract))
- Implemented: Possible to query a range of device states via JSON
- Implemented: SolarEdge, polling Storage devices
- Fixed: Data Pushers, Forecast for Weather Station subtypes
- Fixed: Floorplan, better detection of switches
- Fixed: Hardware Setup, hiding extra parameters when selecting a python plugin
- Fixed: PythonEx framework, two notifications where send for switch type devices
- Fixed: Python framework, custom image loading
- Removed: Cereal Proxy (not used anymore)
- Changed: EvoHome, now making use of general logging system
- Changed: MQTT-AD, now also handles brightness scale number values as string
- Changed: SBFSpot, disabled error 28 error
- Changed: Selector switch now displays correct state in Data field (and devices overview)
https://github.com/domoticz/domoticz/commits/master/
https://github.com/domoticz/domoticz/bl ... istory.txt
You can also update manually by going to your Domoticz folder and issue the following command: ./updaterelease
Up up and away !
