Netatmo authentication changes Oct 2022
JaapB
Domoticz version: 2025.2
Re: Netatmo authentication changes Oct 2022
Post by JaapB »
JapieG wrote: Monday 10 June 2024 12:59 same here. Not working for more than a few hours. So annoying.
As of this morning after yet another attempt to enter the credentials and resetting the token at dev.netatmo things seem to be working again and stay working now for over 8 hours now. Keeping my fingers crossed.
ricvee
Domoticz version: Stable
Post by ricvee »
Same here. Stopped working just before our vacation on 3 june.
After resetting the token it worked for about 1 hour, and than stopped again.
Time out set to 5 minutes like said in the wiki. Did not change that, because it worked for 6 months without any errors.
Antoon
Post by Antoon »
JaapB wrote: Tuesday 11 June 2024 15:24
My longest up-time was from 15.08u till 23.11u on jun 12. That 's a little bit more then 8 hours. But at 23.11u Domoticz ended with working with Netatmo! Then i must create a new password conform the procedure. Time for an update of Domoticz or a script!
gizmocuz
Post by gizmocuz »
Antoon wrote: Thursday 13 June 2024 20:49
Please make a PR with the needed changes.
JaapB
Post by JaapB »
gizmocuz wrote: Friday 14 June 2024 10:12
The problem does seem to be at netatmo and not within domoticz so a chance to domoticz will not fix the problem.
ccaru
Post by ccaru »
Has anybody been able to sort this out? I've tried multiple times - also created a new profile on the Netatmo side - doesn't update more that a couple of times before it fails again...
RFXCom, Somfy RTS, 433Mhz Lighting, Evohome, Smart watering via Netatmo, solenoid valves, soil humidity sensors, Airthings Radon via bluetooth, Marley heat recovery fresh air units, Blue Iris, Alexa via DA Bridge.
ricvee
Post by ricvee »
It is working for me now since yesterday, after I removed the Time out of 5 minutes (and created a new password).
jibenito
Domoticz version: 2025.1
Post by jibenito »
I'm going to try to generate a new password again after last domoticz update..
Rob67ert
Post by Rob67ert »
For me I happens when I install a new update for Domoticz. Than I have to get a new password from Netatmo.
jibenito
Post by jibenito »
Rob67ert wrote: Tuesday 18 June 2024 19:17 For me I happens when I install a new update for Domoticz. Than I have to get a new password from Netatmo.
Same to me, every restart or update I have to generate a new password...
ccaru
Post by ccaru »
ccaru wrote: Monday 17 June 2024 23:42 Has anybody been able to sort this out? I've tried multiple times - also created a new profile on the Netatmo side - doesn't update more that a couple of times before it fails again...
Seems to have stabilized now for me. Over 24 hours without it stopping. Keeping fingers crossed.
phil35
Domoticz version: 2023.1
Post by phil35 »
Feedback:
following as previously the procedure written here:https://www.domoticz.com/wiki/Netatmo
- first try as usual username = <client_id>:<client_secret> + password ... works only a few hours (<3)
- then second try,
it works since june 17.
domoticz has not been restarted, only using domoticz UI.
Production platform uses domoticz v2023.1
Production platform (for Netatmo and Zigbee) uses domoticz v2024.7
Thuis
Post by Thuis »
Indeed, i also have the problem when i restart domoticz, then i need to fill out the url again with my usercode and then copy paste the code in the hardware section and then it runs for a while. Stupid netattamo.
If you can not handle a computer, you buy a Mac. If you can not handle domotica, you use Homeassistant!
ccaru
Post by ccaru »
Thuis wrote: Friday 21 June 2024 19:39 Indeed, i also have the problem when i restart domoticz, then i need to fill out the url again with my usercode and then copy paste the code in the hardware section and then it runs for a while. Stupid netattamo.
Confirmed. After I managed to get it running for a almost 2 days I needed to restart domoticz due to a configuration change and it stopped working again - I had to go through the API reset process :(
Thuis
Post by Thuis »
Ah yes, my system needed a restart and now, even if i fill in my id with the url provided on https://www.domoticz.com/wiki/Netatmo i now get a blank page with nothing.
ccaru
Post by ccaru »
Thuis wrote: Sunday 23 June 2024 12:48 Ah yes, my system needed a restart and now, even if i fill in my id with the url provided on https://www.domoticz.com/wiki/Netatmo i now get a blank page with nothing.
remember that it's normal that the page comes up with nothing - the password you need is in the address bar. It's also quite slow to load.
Thuis
Post by Thuis »
I know it is in the addressbar, however now the addressbar does not change, it does not lead me to the page where i have to accept permission, nor does it do anything. Before i done this several times but now it just sits there at a blank page without the addressbar url changing.
Thuis
Post by Thuis »
ok so i waited a while, and just now, i did the same thing, now no blank page, but i get the "yes, i accept" button, then the code in the address bar. So i think there is a waiting time, specially for me, to get a new token. Im sure if i restart domoticz now, then netatmo fails, and i have to wait again 12 hours before i can use the link from the wiki to get a new code. But i am a bit of a crazy person, so probably it is only just me and my computer.
Thuis
Post by Thuis »
and here we are again, no redirect, netatmo failing again with a blank page. just filtering out my irritation, sorry.
phil35
Post by phil35 »
sorry for you,
May I kindly ask you to follow the procedure - see my post above (june 20), It works perfectly
However each time domoticz is restarted .. it must be done :-(
one tip: do not change the scope in the URL used to generarate the code aka the password, otherwise it will not work, this is my experience.
regards
