I have problem with latest beta
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
fantom
Post by fantom »
Today morning i update domoticz to latest beta.
And now I can't connect to domoricz by web etc :(
I don't know why.
I do uprady often. I've never had this problem.
pi@raspberrypi:~/domoticz $ sudo ./updatebeta
Stopping Domoticz...
Making backup of current installation...
Output file: backups/domoticz_backup_20240615_090051.tar.gz
Backup finished...
Downloading latest beta version...
Checking file integrity...
Installing new version...
Starting Domoticz... (please standby...)
Done...
Jun 15 09:00:23 raspberrypi systemd[1]: Started Session 15 of user pi.
Jun 15 09:00:51 raspberrypi systemd[1]: Stopping LSB: Home Automation System...
Jun 15 09:00:51 raspberrypi systemd[1]: domoticz.service: Succeeded.
Jun 15 09:00:51 raspberrypi systemd[1]: Stopped LSB: Home Automation System.
Jun 15 09:01:06 raspberrypi systemd[1]: Starting LSB: Home Automation System...
Jun 15 09:01:06 raspberrypi domoticz.sh[1201]: 2024-06-15 09:01:06.172  Status: Domoticz V2024.4 (build 16065) (c)2012-2024 GizMoCuz
Jun 15 09:01:06 raspberrypi domoticz.sh[1201]: 2024-06-15 09:01:06.172  Status: Build Hash: 3c92fc508, Date: 2024-06-14 15:33:35
Jun 15 09:01:06 raspberrypi domoticz.sh[1201]: 2024-06-15 09:01:06.172  Status: Startup Path: /home/pi/domoticz/
Jun 15 09:01:06 raspberrypi domoticz.sh[1201]: domoticz: Domoticz is starting up....
Jun 15 09:01:06 raspberrypi domoticz: Domoticz is starting up....
Jun 15 09:01:06 raspberrypi systemd[1]: Started LSB: Home Automation System.
pi@raspberrypi:~/domoticz $ ps -ax | grep domoticz
 1280 pts/0    S+     0:00 grep --color=auto domoticz
pi@raspberrypi:~/domoticz $ df -h
Filesystem      Size  Used Avail Use% Mounted on
/dev/root       110G  5.3G  101G   5% /
devtmpfs        1.6G     0  1.6G   0% /dev
tmpfs           1.9G     0  1.9G   0% /dev/shm
tmpfs           1.9G  8.5M  1.9G   1% /run
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           1.9G     0  1.9G   0% /sys/fs/cgroup
/dev/sda1       253M   54M  199M  22% /boot
tmpfs           380M     0  380M   0% /run/user/1000
pi@raspberrypi:~/domoticz $ free -h
              total        used        free      shared  buff/cache   available
Mem:          3.7Gi        74Mi       3.3Gi       8.0Mi       355Mi       3.6Gi
Swap:          99Mi          0B        99Mi
What can I check ?
heggink
Domoticz version: 12451
Re: I have problem with latest beta
Post by heggink »
So the process is not running but there is nothing in the logs? You probably tried restarting and look at the logs again?
DASHTICZ 🙃
P1 meter & solar panel
fantom
Post by fantom »
I tried several times. Including restarting rpi
in var/run exists domoticz.pid
I add domoticz log and i see errors
2024-06-15 11:08:21.929  Error: Domoticz(pid:1404, tid:1415('MainWorker')) received fatal signal 6 (Aborted)
2024-06-15 11:08:21.929  Error: siginfo address=0x57c, address=0xffffffff
2024-06-15 11:08:24.164  Error: Thread 12 (Thread 0xf0cff200 (LWP 1415)):
2024-06-15 11:08:24.165  Error: #0  __waitpid (options=0, stat_loc=0xf0cfdf30, pid=1427) at ../sysdeps/unix/sysv/linux/waitpid.c:30
2024-06-15 11:08:24.165  Error: #1  __waitpid (pid=1427, stat_loc=0xf0cfdf30, options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:25
2024-06-15 11:08:24.165  Error: #2  0x00a98b62 in dumpstack_gdb(bool) ()
2024-06-15 11:08:24.165  Error: #3  0x00a98fb8 in signal_handler(int, siginfo_t*, void*) ()
2024-06-15 11:08:24.165  Error: #4  <signal handler called>
2024-06-15 11:08:24.165  Error: #5  __GI_raise (sig=sig@entry=6) at ../sysdeps/unix/sysv/linux/raise.c:50
2024-06-15 11:08:24.165  Error: #6  0xf764b280 in __GI_abort () at abort.c:79
2024-06-15 11:08:24.165  Error: #7  0x00f4a488 in __gnu_cxx::__verbose_terminate_handler() ()
2024-06-15 11:08:24.165  Error: #8  0x00eedf18 in __cxxabiv1::__terminate(void (*)()) ()
2024-06-15 11:08:24.165  Error: #9  0x00eedf6e in std::terminate() ()
2024-06-15 11:08:24.165  Error: #10 0x00eede94 in __cxa_throw ()
2024-06-15 11:08:24.165  Error: #11 0x00f47b78 in std::__throw_invalid_argument(char const*) ()
2024-06-15 11:08:24.165  Error: #12 0x00b92080 in int __gnu_cxx::__stoa<long, int, char, int>(long (*)(char const*, char**, int), char const*, char co
nst*, unsigned int*, int) [clone .constprop.785] ()
heggink
Post by heggink »
Can you post both the crash log and the domoticz log?
DASHTICZ 🙃
gizmocuz
Post by gizmocuz »
Could you also try with the latest beta
go to the domoticz folder and issue
./updatebeta
Send you a PM as well
