How to do a simple calculation P=U*I  [Solved]
Thuis
Post by Thuis »
Hello, i try to calculate P=U*I, or Idx95*Idx1417=Idx1714 in W or kW.
But i do not seem to get this simple P=U*I to input in a style that dzvents wants.
And i know this is not correct i have the cos phi of the device the blind and the real power bla bla, but i just want the simplest calculation to work. P=U*I
Could someone give me an example of how i can do this in the most simple way in dzvents, or lua is also fine. P=U*I
Thanks in advance.
Fun for everyone!
gizmocuz
Re: How to do a simple calculation P=U*I
Post by gizmocuz »
Can you post your dzVents script here?
Sure you can get the value of a Ampere and voltage sensor, and just multiply them and write the value to the console?
Thuis
Post by Thuis »
I probably think too simple...
    timer = {'every 5 seconds'}
 execute = function(dz)
local spanning = dz.devices('Voltage') -- Voltage from p1 meter
local stroom = dz.devices('Onshuis_AC - Stroom opname') -- Opname AC via esp AC
local value = dz.devices('Verbruik MHI Airco') -- Virtuele kwh meter
    value = (spanning * stroom)
I see no errors in the log also the kwh device stays on zero kwh, perhaps im using wrong device to put the value in? No clue.
Fun for everyone!
Thuis
Post by Thuis »
And ofcourse im reading https://www.domoticz.com/wiki/DzVents:_ ... _scripting but there are lots of calculations about averages, medians, max, min, sum and delta's but no multiply.
Fun for everyone!
Domoticz version: 2026.3
dzvents is built on lua so standard arithmic operators apply https://www.lua.org/pil/3.1.html
But to update a kwh device you have to use
dz.devices('Verbruik MHI Airco').updateEnergy(spanning * stroom)
https://www.domoticz.com/wiki/DzVents:_ ... tric_usage
Thuis
Post by Thuis »
updateEnergy(energy) Aha.
Ok im doing it wrong its not updating, no errors in log, but ill keep on trying.
Thanks for the steering me in a direction :-)
Fun for everyone!
What you were doing ( value = (spanning * stroom) ) is from a scripting point of view not wrong only it is not doing anything with the device..... That is why you did not get an error.
You never can change a domoticz device with only setting a value. You always have to use a function.
RonkA
Domoticz version: 2025.1
Post by RonkA »
Dont you read your private messages?
SolarEdge ModbusTCP - Kaku - Synology NAS - Watermeter - ESPEasy - DS18b20
Work in progress = Life in general..
Kedi
Domoticz version: latest
Post by Kedi »
You also have to use
local spanning = dz.devices('Voltage').voltage -- Voltage from p1 meter
local stroom = dz.devices('Onshuis_AC - Stroom opname').current -- Opname AC via esp AC
Thuis
Re: How to do a simple calculation P=U*I  [Solved]
Post by Thuis »
RonkA wrote: Thursday 13 June 2024 16:32 Dont you read your private messages?
Yes i do 😁
Fun for everyone!
