accept new hardware - Prevent creating MQTT AD devices Topic is solved
JuanUil
- Domoticz version: 4.11083
Hi Folks,
So I am on the latest beta and zwave-js.
A lot of new, mostly irrelevant, devices appear.
When I remove them I constantly get the message that accept new hardware is disabled.
When I let them be accepted as new devices and put them as not being used they are still questioned which sometimes slows down my response.
Is there a way to get rid of these devices permanently?
Jan
Jan
- Domoticz version: 2026.3
Re: accept new hardware
I believe there is an option in Zwave-JS-UI somewhere to not publish those unwanted device to MQTT and then they won't appear in Domoticz.
JuanUil
Hi Walter,waltervl wrote: Thursday 13 June 2024 0:16 I believe there is an option in Zwave-JS-UI somewhere to not publish those unwanted device to MQTT and then they won't appear in Domoticz.
question is then where to find it.
JuanUil
Hi Walter,
Not working
see below my settings in zwavejs-ui and the report in the log
Settings:
Log:
Not working
Settings:
Log:
2024-06-13 13:14:50.652 MQTT: Accept new hardware disabled. Ignoring new sensor Achterkamer-Verlichting Achter (Achterkamer-Verlichting Achter_electric_kwh_value)Your mind is like a parachute,
- gizmocuz
Re: accept new hardware - Prevent creating MQTT AD devices
Okey, but find the Watt/kWh not important?
If you go to the devices overview, you can set them unused, and they won't show up in the utility tab
JuanUil
That is correct they don't show up but are still interviewed altough I have set them to disabled in Zwavejs-ui and set them to unused in the devices overviewgizmocuz wrote: Thursday 13 June 2024 13:43 Okey, but find the Watt/kWh not important?
You probably still have retained MQTT config topics in your MQTT broker. https://www.domoticz.com/wiki/MQTT#Dele ... ined_topic
JuanUil
Deleted all messages but problem remains
And restart the Domoticz MQTT AD hardware gateway (press on update button) or restart Domoticz completely as indicated in the wiki section I referred to.
Are those not needed MQTT AD config topics gone or recreated by zwave-js-ui?
JuanUil
That did the trick!!
Restartet the broker and all well now, no more interviewing.
Thnx for the help!!
Thnx for the help!!
