Hi !
I have all pi-sensors active
HDD/ shows almost 100%. Feels like being not OK
What to do? It seems there's plenty space on the SD-card
-Bart
meaning pi-sensor HDD /
- Domoticz version: V2024.3
- raspberry Schermafbeelding 2024-06-11 221308.jpg (14.46 KiB) Viewed 727 times
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 espeasy
MQTT
Arduino
KAKU
RfxCom
Zwave
OTGW
Tasmota
Esp8266 espeasy
MQTT
- FireWizard
Re: meaning pi-sensor HDD /
This is the screenshot. Seems not OK. How can I save storage place?
- DZ-forum.jpg (29.83 KiB) Viewed 716 times
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave
OTGW
Tasmota
Esp8266 espeasy
MQTT
Arduino
KAKU
RfxCom
Zwave
OTGW
Tasmota
Esp8266 espeasy
MQTT
- FireWizard
Hi @BartSr
Try to find the largest file.
See: https://www.cyberciti.biz/faq/linux-fin ... g-find-du/
or to find the 20th largest files, execute the following command.
Perhaps you can remove or move the largest files
sudo du -aBm / 2>/dev/null | sort -nr | head -n 20
After you cleaned up you could also set a notification on the 'HDD /' widget to get an early warning if usage is over a certain percentage.
- Domoticz version: 2023.2
Using you can browse the contents.
Without the grep it displays everything.
Change the grep to K] to show smaller files and G] to find huge files, amongst which maybe the domoticz directory.
Oh, BTW do a cd / to display the contents starting from the root directory.
If the result is too much for an overview try
sudo tree --du -h | grep M] | awk '{print NR, $0}'
sudo tree -L 3 --du -h | grep M] | awk '{print NR, $0}'
Bugs bug me.
