Hello
Just to inform that the Data Format of Selector Switch has changed in build build 16046 when executing
http://Domoticz_IP:Domoticz_Port/json.htm?type=command¶m=getdevices&rid=DEVICE_ID
Prior it was "Data" : "Set Level: 10 %" ==> Data = Level
Now it is "Data" : "Alive" ==> Data = Name
BR
- Domoticz version: 2020.2
Re: Data Format of Selector Switch has changed in build build 16046
Nice script killer
- Domoticz version: 2024.7
I checked the latest commits but could not find a reason why this would have happened. From what version did you update?
Hello
From the build 16030
BR
BR
meal
Hello
The switch has been created with type 244 (switch), subtype 62 (selector switch). switchtype 18 (Selector)
BR
BR
meal
Still dont see it changed. Field Data is some kind of multipurpose field. For getting selector status level from the json I use the Level and Name fields
Think I found it. It is there to get the level shown in the log...
https://github.com/domoticz/domoticz/pull/6077
Hello
OK I see.
I will use Level instead of Data info in the JSON response.
BR
OK I see.
BR
meal
- gizmocuz
Exactly, you have to use level. And for presentation the Data field.
This was requested via a PR, and I agree it made sense to show the correct data
