trigger distiction in a script: physical button or script?
rugspin
Post by rugspin »
I would like to combine a shelly 1 and a physical switch (inside the house) and a light+PIR (outside the house). The light should be switched on/off by the PIR. But when I use the physical switch inside, the light should stay on until I switch it off with physical switch.
For this, I would need to get the info in a dzvents script, what triggered the switch (the physical switch or a dzvents script from the PIR).
I looked through the dzvents wiki, but could not exactly figure out which object or attribute would have this info.
I would be looking for a statement to replace the parts
'triggered by physical button'
'triggered by the PIR'
in the script below. I would be glade about any help,
best regards
return
	on =
		devices = { 'switch.test' }
    execute = function(domoticz, switch)
        if (switch.state == 'On' ) then
            domoticz.log('Hey! Switch was set to on!')
		if( 'triggered by physical button' ) then
			-- stay switched on and ignore the PIR
		elseif( 'triggered by the PIR' ) then
			-- stay on for just 3 min
        elseif (switch.state == 'Off' ) then
		domoticz.log('Hey! Switch was set to off!')
			-- recognize PIR again
rugspin
Re: trigger distiction in a script: physical button or script?
Post by rugspin »
Now, I figured out a little how to check the event triggers by the isCustomEvent, isDevice, isGroup, ... functions of the item object.
If I click in the domoticz gui on a switch_01 it would tell: isDevice is True
If I use a dzvent script from a second switch_02 and use domoticz.devices('switch_01').switchON() than also: isDevice is True
But I never got any info from the item object:
item.trigger was always NIL
So it looks to me as if it is not really possible within dzvents to figure out exactly which device triggered another, but maybe I did not fully understand the event handling in dzvents?
Doler
Post by Doler »
The way I solved this is to capture the status as changed by the script in dzVents data (data = { savedState = { initial = 'Off' }}). Whenever the script changes the state, change the savedState accordingly. So when you use a physical button this savedState remains unchanged. Then in your script you can test the current state versus the savedState. If unequal it was changed by the physical button.
Mark: Domoticz latest Beta on Virtual machine (Proxmox) running Debian Bookworm - Z-Stick 7 - RFXCom - P1 - SolarEdge - Dahua - Philips Hue - Docker - Zigbee2mqtt (latest, docker) via python plugin - Zwave-js-ui (latest, docker) - dzVents - Nodered
habahabahaba
Domoticz version: 2024.4
Post by habahabahaba »
I think you can use device.name method
Smth like
        if (device.name =='name of your physical switch'  and device.state == 'On' ) then
            -- doing smth
        elseif (device.name =='light+PIR sensonr' and device.state == 'On') then
            -- doing smth else
FlyingDomotic
Post by FlyingDomotic »
If I correctly remember, change originator is kept in device log (at least for switches). Yo ucan see it clicking on "log" on a switch widget.
Problem with scripts is the fact that you'll get only "EventSystem//home/xxxx/domoticz/dzVents/runtime/dzVents.lua" instead of name of effectively executed script. But in your case, you probably can make the difference between "User (IP)" written here when this a is user initialed command.
That said, I don't known how to extract this information from database log relation (if someone knowns, I'm interrested).
habahabahaba
FlyingDomotic wrote: Thursday 06 June 2024 11:13 If I correctly remember, change originator is kept in device log (at least for switches). Yo ucan see it clicking on "log" on a switch widget.
I'm on Win10 and that logs are empty :(
May be that is only my problem but this solution will not work in my case/
FlyingDomotic
I don't use Windows, I don't known ...
rugspin
Post by rugspin »
Thanks for the suggestions, I will try if I can make use of the above.
What I thought was to set a boolean variable 'controlled_by_physical_switch' in a dzvents script whenever the physical button switches on.
Than the a second dzvents script for the PIR checks the 'controlled_by_physical' variable and can only act if it is False. Now the PIR script needs to use .silent() to switch the light switch on. In this case the first script is not triggered and does not change the 'controlled_by_physical_switch' variable.
habahabahaba
-- TEST
		timer = {
			'every 1 minutes' -- just an example set as often as you need
		httpResponses = {
			'GettingDevInfo' -- must match with the callback passed to the openURL command
	    local devID = 90 -- ID of your switch
	    local dzURL = 'http://127.0.0.1:8081'
	    local APIURL = dzURL..'/json.htm?type=command&param=getlightlog&idx='..devID -- for text device URL: /json.htm?type=command&param=gettextlog&idx=IDX
	    if (item.isTimer) then
			domoticz.openURL({
				url = APIURL,
				method = 'GET',
				callback = 'GettingDevInfo', -- see httpResponses above.
			}).afterSec(1)
	    if (item.isHTTPResponse) then
			if (item.ok) then
				if (item.isJSON) then
                    --domoticz.utils.dumpTable(item.json)  -- необязательный элемент.
                 local userInfo = item.json.result[1].User
                 local lastDate = item.json.result[1].Date
                 local pattern = "%d+%.%d+%.%d+%.%d+"
                 local ipAddress = string.match(userInfo, pattern)
                 if ipAddress == nil then
                     ipAddress = 'no info'
                 domoticz.log('Device info: '.. domoticz.devices(devID).name, domoticz.LOG_ERROR)
                 domoticz.log('Date: '.. lastDate, domoticz.LOG_ERROR)
                 domoticz.log('User: '.. userInfo, domoticz.LOG_ERROR)
                 domoticz.log('ipAddress: '.. ipAddress, domoticz.LOG_ERROR)
				domoticz.log('LOG_ERROR', domoticz.LOG_ERROR)
