Wordwrap in devices on dashboard
janpep
Domoticz version: 2025.1
Post by janpep »
I had a problem with the readability of longer lines in text and alert devices.
Under Utility tab there is a wordwrap and text goes to the next line.
Under Dashboard tab this is not the case.
I found a workaround by changing /pathtodomoticz/www/css/styles.css.
See topic: Incomplete text shown on dashboard
I guess this shall be overwritten by next update.
Therefore my suggestion to implement this.
I can not think of a good reason to have the 'nowrap' that makes the rest of a longer sentence invisible.
Until now I do not see unexpected or unwanted side effects.
.status {
        /* 22-05-2024 Jan peppink, Modified to get wordwrap on dashboard.*/
        /*white-space: nowrap;*/
        white-space: normal;
Dz on Ubuntu VM on DS718+ behind FRITZ!Box.
EvoHome; MELCloud; P1 meter; Z-Stick GEN5; Z-Wave-js-ui; Sonoff USB-Dongle Plus-E; Zigbee2Mqtt; MQTT; Greenwave powernodes 1+6; Fibaro switch, plugs, smoke; FRITZ!DECT 200. Scripts listed in profile interests.
Re: Wordwrap in devices on dashboard
You can create a PR for this on the github repository on the developing branch so it will added to beta and later Stable.
janpep
Post by janpep »
Okay. Thanks for the tip!
I will see if I can find that.
But is it strange that I expected the 'suggestions forum' to be the place for suggestions? And that developers also read it?
There also might be a reason not to do this, which I have not thought of, that could be answered or discussed here.
I hardly see any suggestions created on this forum implemented into changes on Domoticz unless a developer has the same issue or the requester implements it themselves.
