Hi to all
For my SolarEdge Inverter I have a device subtype Text. Is show the status of my inverter as a text.
When the status is Fault or Off I would like to receive a notification. However these devices do not have the notification option.
Who knows the trick to send a notification on these status values from this device
Thanks in advace
Send Notification from device subtype text
- McMelloW
- Domoticz version: V2024.1
Greetings McMelloW
- Domoticz version: 2025.1
Re: Send Notification from device subtype text
I would setup a dzvents script:
trigger on the text device change
read the text contents
if text contains Fault or Off send a notification.
Something like below (not tested so you probably have to tweak some things)
Below the notify function from the wiki https://www.domoticz.com/wiki/DzVents:_ ... _scripting
return
on =
devices = { 'YourSolaredgetextdevice'}
if item.text == 'Off' or item.text == 'Fault' then
domoticz.notify('Solar edge issue!',
'Solar edge is Off or in Fault',
domoticz.PRIORITY_LOW)
}notify(subject, message [,priority][,sound][,extra][,subsystem][,delay]3.0.10 ): Function. Send a notification (like Prowl). Priority can be like domoticz.PRIORITY_LOW, PRIORITY_MODERATE, PRIORITY_NORMAL, PRIORITY_HIGH, PRIORITY_EMERGENCY. extra is notification subsystem specific. For NSS_FIREBASE you can use this field to specify the target mobile (‘midx_1’, midx_2, etc..). For sound see list of dzVents Constants for the SOUND constants below. subsystem defaults to all subsystems but can be one subsystem or a table containing one or more notification subsystems. See list of dzVents Constants for domoticz.NSS_subsystem types. Delay is delay in seconds
- McMelloW
@waltervl
Thanks for your example. I will try this out.
Got it working in test situation. It is now in production an have wait for live status changes.
Greetings McMelloW
- McMelloW
Hi Waltervl.waltervl wrote: Thursday 09 May 2024 0:00 I would setup a dzvents script:
Something like below (not tested so you probably have to tweak some things)Code: Select all
return { on = { devices = { 'YourSolaredgetextdevice'} }, execute = function(domoticz, item) if item.text == 'Off' or item.text == 'Fault' then domoticz.notify('Solar edge issue!', 'Solar edge is Off or in Fault', domoticz.PRIORITY_LOW) end }
I have turned things around, only whenthe status is Producing or Sleeping I will not send a notification. These are the normal day and night status. All other status may send a notification. Somehow my equation does not work correct, because notifications are send with Producing or Sleeping Can you tell me what is wrong.
return
on =
devices = { 'SE - Status'}
if (item.text ~= 'Sleeping') or (item.text ~= 'Producing') then
domoticz.notify('SolarEdge Status notification!',
'SolarEdge Status is now: ' .. item.text,
domoticz.PRIORITY_HIGH)
Greetings McMelloW
Is the status exactly Sleeping or Producing?
Perhaps put an extra log statement in it to get the real text value.
- habahabahaba
- Domoticz version: 2024.4
try
if (item.text ~= 'Sleeping' and item.text ~= 'Producing') then
end- McMelloW
Thanks @habahabahaba, an AND operator did the trick. it works perfect now.habahabahaba wrote: Sunday 12 May 2024 17:06 try
if (item.text ~= 'Sleeping' and item.text ~= 'Producing') then domoticz.notify('SolarEdge Status notification!', 'SolarEdge Status is now: ' .. item.text, domoticz.PRIORITY_HIGH) end
@waltervl The real value of item.text was already included in the notification text. So I am able to see it already.
Greetings McMelloW
