2024-05-08 17:14:51.885 Error: ebus hardware (13) thread seems to have ended unexpectedlyModerator: leecollings
2024-05-08 17:14:51.885 Error: ebus hardware (13) thread seems to have ended unexpectedlyI see here https://github.com/john30/ebusd-configu ... 15.f43.csv that HolidayRoomTemp is declared as D1C, I don't know the difference with temp, but ok, I will add that to plugin translation.fantom wrote: Tuesday 07 May 2024 13:38 1) not always temperature have correct device type (custom sensor instead temp sensor)
It should be contact type. Please check that you have 2.0.7 plugin version, try to delete the devices and go to plugin parameter and click on Modify, it will relaunch auto discovery, maybe it's because of a bug I fixed since.fantom wrote: Tuesday 07 May 2024 13:38 2) many devices have state like on/off, yes/no. Maybe they also should be contact type instead general text ? Unless there may be a third state there (auto etc)
You're right, I never encountered percentage myself in my ebus configuration, I will try to add it to plugin translation.fantom wrote: Tuesday 07 May 2024 13:38 3) device with percentage, can be percentage type instead custom sensor
That's already something I do for pressure and temperature, I can extend that behavior to other data types we identifyfantom wrote: Tuesday 07 May 2024 13:38 4) many devices send data to domoticz only one time at start hardware (or maybe very rarely). Domoticz checks how long ago the data was sent and marks in red that there is no contact with the device. Maybe you need to send this data even though ebusd haven't changed it, etc.?
How many devices do you have, what domoticz version? Do this still happen if you increase refresh rate?fantom wrote: Wednesday 08 May 2024 17:37 And after one day I see only:Code: Select all
Could you send the content of http://ipofebusddaemoncomputer:8889/data?def&write please?fantom wrote: Tuesday 07 May 2024 13:38 1) not always temperature have correct device type (custom sensor instead temp sensor)
2.0.7Barberousse wrote: Wednesday 08 May 2024 20:34It should be contact type. Please check that you have 2.0.7 plugin version, try to delete the devices and go to plugin parameter and click on Modify, it will relaunch auto discovery, maybe it's because of a bug I fixed since.fantom wrote: Tuesday 07 May 2024 13:38 2) many devices have state like on/off, yes/no. Maybe they also should be contact type instead general text ? Unless there may be a third state there (auto etc)
Please note that if you delete them, they will come back. You'll have to filter them first using the registers parameter, then delete them. Or create a new ebusd bridge hardware with registers containing the filter.fantom wrote: Wednesday 08 May 2024 20:51 The newest version of domoticz .
About 500 devices from ebusd - I keep looking at what they are, that's why I didn't delete them.
Indeed, I checked my code and deleting is not mandatory if the device type change, it's changed in Domoticz automatically.
telnet domotique 8888
Trying 192.168.0.105...
Connected to domotique.
Escape character is '^]'.
read -v -c mc monitoreeprominkonsinumber
ERR: invalid position1) I will check if other uses for 1/min unit beforefantom wrote: Thursday 09 May 2024 18:18 1) Maybe Fan device is better for 1/min
2) Domoticz have something like "counter" also. But I don't know how it works etc.
3) Who damages big numbers ? plugin or domotcz ?
read -v WaterpressureMeasureCounter
bai WaterpressureMeasureCounter =112
read -v PrEnergyCountHc1
bai PrEnergyCountHc1 =29915587
read -v FanMaxSpeedOperation
bai FanMaxSpeedOperation =5550It depends if device is writable. If it is writable and you didn't set read-only in parameters, the device will be created as on/off. But you are free to change that by editing the device in Domoticz.fantom wrote: Thursday 09 May 2024 18:33 And maybe device on/off can have another type in domoticz ? "On/Off" instead "contact".
I'm not sure ...
That's the normal behavior, Domoticz show the Set Level in devices tables (index of selector switch x 10 as you guessed), but in the interface, you should have a selector switch positioned at the right value.fantom wrote: Thursday 09 May 2024 20:44 Edit: Ok. This nvalue is selector index * 10. That this is small bug for showing value I think.
I think nvalue is ignored.fantom wrote: Thursday 09 May 2024 21:42 And what do You set in nvalue?
And i don't know, why first value on list is empty
ps. Maybe this need to be general/selector ? nor switch with level.
