No data to display Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Domoticz version: 2024.7
Re: No data to display
Ah, Ok you have something completely different as your graphs are working but you do not see the device widgets in the tab.
That is a known issue after an update. You have assigned devices to the logged in user. If you are an admin user you have to clear the list. Menu Setup - Users and remove all assigned devices (right column should be empty)
See wiki https://www.domoticz.com/wiki/User_Mana ... et_Devices
ocack
Domoticz version: 2024.4
Post by ocack »
Thank you again but unfortunately, I already tested your tips again and you persennoly even answered me in this topic https://www.domoticz.com/forum/viewtopi ... 12#p312312
I keep two topics open because I do really have two issues :
I have the "No Data to display" from a long time ago
But, since the upgrade to 2024.4, I have now this second issue "All dashboards empty after Domoticz upgrade"
There still have issue with the latest domoticz release and the previous one and it's strange I'am the only one
I would not want to restart from scratch because I have a big database now as I use domoticz for many years with my RFXCom devices
I would like to find the issue and peharps someone stronger than me in javascript could help me, because I do have error when I open the developper tools of the browser
User Ocack.jpg (208.35 KiB) Viewed 513 times
User Admin 2.jpg (214.35 KiB) Viewed 513 times
user Admin.jpg (280.5 KiB) Viewed 513 times
Platform: raspberry Linux 5.10.103-v7+ armv71 GNU/linux
Plugin/Hardware: RFX 433 / THGR810 / ...
Version: 2024.4
Build Hash: 731719420
dzVents Version: 3.1.8
Python Version: 3.7.3 (default, Jan 22 2021, 20:04:44) [GCC 8.3.0]
Active User: admin
ocack
Post by ocack »
Thank to waltervl's intuition, my issue has been solved by installing a new fresh domoticz setup.
I did a backup of my database, removed domoticz folder, installed a new domoticz release, restored my database then cleared my caches.
I will never understand why my previous upgrade and caches clearing didn't fix it before.
Anyway, that's all folks 😀
Version: 2024.4
Active User: admin
StevenHoogslag
Post by StevenHoogslag »
StevenHoogslag wrote: Tuesday 23 April 2024 15:32 Hello Walter,
After updating Domoticz to the latest version on April 23d of 2024 the problem persists.
There are still no temperature statistics shown.
This recent version is: 2024.3.15889
MISSING READINGS SINCE UPDATE
Since the update on April 23d only two of 10 temperature sensors are updated in Domoticz Dashboard. The sensors report accurately but are red and not updated since date of update.
Here ia a sample log of ESP12-143 overboven with idx 420:
1736124470: DS : Temperature: 27.00 (28-ff-ac-88-80-14-2-96)
1736124475: Domoticz: Sensortype: 1 idx: 420 values: 24.9
1736130589: DS : Temperature: 27.00 (28-ff-ac-88-80-14-2-96)
1736130592: Domoticz: Sensortype: 1 idx: 420 values: 24.9
1736132554: WD : Uptime 28936 ConnectFailures 41699 FreeMem 21440 WiFiStatus 3
1736136733: DS : Temperature: 27.00 (28-ff-ac-88-80-14-2-96)
1736136735: Domoticz: Sensortype: 1 idx: 420 values: 24.9
1736142865: DS : Temperature: 27.00 (28-ff-ac-88-80-14-2-96)
1736142868: Domoticz: Sensortype: 1 idx: 420 values: 24.9
1736148984: DS : Temperature: 27.00 (28-ff-ac-88-80-14-2-96)
1736148987: Domoticz: Sensortype: 1 idx: 420 values: 24.9
1736155104: DS : Temperature: 27.00 (28-ff-ac-88-80-14-2-96)
1736155107: Domoticz: Sensortype: 1 idx: 420 values: 24.9
1736161223: DS : Temperature: 27.00 (28-ff-ac-88-80-14-2-96)
1736161227: Domoticz: Sensortype: 1 idx: 420 values: 24.9
1736162555: WD : Uptime 28936 ConnectFailures 41694 FreeMem 19872 WiFiStatus 3
1736167342: DS : Temperature: 27.00 (28-ff-ac-88-80-14-2-96)
1736167345: Domoticz: Sensortype: 1 idx: 420 values: 24.9
1736173461: DS : Temperature: 27.00 (28-ff-ac-88-80-14-2-96)
1736173464: Domoticz: Sensortype: 1 idx: 420 values: 24.9
1736179581: DS : Temperature: 27.00 (28-ff-ac-88-80-14-2-96)
1736179584: Domoticz: Sensortype: 1 idx: 420 values: 24.9
1736185700: DS : Temperature: 27.00 (28-ff-ac-88-80-14-2-96)
1736185704: Domoticz: Sensortype: 1 idx: 420 values: 24.9
Its actual results are not shown anymore.
StevenHoogslag wrote: Sunday 30 June 2024 10:29
How are these device updated from ESP? If using a Domoticz API call check the format.
StevenHoogslag
I am not sure but they are all alike and only two are working.
I would consider a re-install of Domoticz but there are many years of data and several blocky instructions to preserve.
Maybe do a re-install on another pc and check the results first.
If you are not sure how your sensor data is coming into Domoticz it will be hard to debug this issue.
