I tried to use the script from wiki for controlling fan in bathroom. That's 100% LUA.
As I have not a real humidity device but used custom device instead it seems impossible to get the humidity value (%) in a LUA script.
So I wonder if there's a similair dzVents scripts or a workaround to get humidity% in LUA script.
-Bart
dzVents equivqlent for LUA script
- Domoticz version: V2024.3
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 espeasy
MQTT
Arduino
KAKU
RfxCom
Zwave
OTGW
Tasmota
Esp8266 espeasy
MQTT
- Domoticz version: 2020.2
Re: dzVents equivqlent for LUA script
If you device is a temp + humidity sensor, then sValue is formatted as TEMP;HUM;HUM_STAT where:
- TEMP = Temperature
- HUM = Humidity (0-100 %)
- HUM_STAT = Humidity status is 0=Normal, 1=Comfortable, 2=Dry, 3=Wet
You can extract it with a LUA script like:
allValues = otherdevices_svalues["my temp device name"] -- Get values
temperature, humidity, humidity_state = allValues:match("([^;]+);([^;]+);([^;]+)") -- Split using ';'
