Domoticz Premium apk has stopped working
Subforum for general discussions. Do not dump your questions/problems here, but try to find the subforum where it belongs!
Cubes
Re: Domoticz Premium apk has stopped working
Post by Cubes »
HansF wrote: Friday 27 October 2023 16:250.2.366 (9403)
How do you get 366?
I'm on 365 but clicking download latest takes you to the different app in the appstore.
jvdz
Domoticz version: 4.107
Post by jvdz »
Rollout of apps is often staggered, so it could take a bit before everybody get it proposed in the play store, sk it should be presented via the regular route in the play store.
Cubes
Post by Cubes »
jvdz wrote: Friday 27 October 2023 19:11 Rollout of apps is often staggered, so it could take a bit before everybody get it proposed in the play store, sk it should be presented via the regular route in the play store.
Sorted. Tnx for the assistance.
kniazio
Domoticz version: 3.7243
Post by kniazio »
What if someone deleted the Domoticz Premium app from their smartphone? Where should I download it now?
TurboX
Post by TurboX »
jvdz wrote: Thursday 26 October 2023 9:25
TurboX wrote: Wednesday 25 October 2023 22:05 Thanks@jvdz to the Nginx code, it works!
I had modified the config in order to adapt to my configuration.
Great it works for you too.
Just wondering why you removed the header fields...was that needed as now you will loose the original IP address and the proxy IP is used?
I can't explain because NGinx Manage was new for me and this is the way I found which works :lol: .
LucVolders
Post by LucVolders »
You could build your own app and customize it like you want.
I build one for my girlfriend as I did not want her to mess around with settings etc.
It is really easy to build your own app with MIT's app inventor.
But you could equally easy build it in Javascript.
Here is the link to my story on building your own app.
http://lucstechblog.blogspot.com/2018/1 ... n-app.html
pizzulicchio
Post by pizzulicchio »
Hi to all... i'm using the premium app of domoticz but it's no more possible to Enable/Disable the Events created into my server's intallation from the App. Entering into Settings-->Events, it chrashes with "OOPS! No data on DOmoticz server" but into the log of the server is showed the [WebsServer] Deprecated RType (devices) for API request.
What is wrong?
slash909
Post by slash909 »
jvdz wrote: Monday 23 October 2023 13:53 ...
I added the below site config to my NGINX also running on the RPI which runs Domoticz.
The NGINX Site will proxy the traffic and first convert the parameters from new to old API format.
Then pointed the latest Android APP to port 8082 in stead of 8080.... e voilà 8-)
This config is for http, so in case you need https you will have to make changes to the proxy stuff as described in the wiki: https://www.domoticz.com/wiki/WebServer_Proxy
Thanks for the config! Works like a charm for my setup: Synology native app which CANNOT BE UPGRADED beyond 2020.2 due to maintainer dropping the project. I might take it on if I get annoyed enough :) My Synology NAS is too old to support Docker, so this upgrade route is closed to me also.
Some notes on NGINX setup on my Synology with DSM 6.2:
  • nginx seems to come pre-installed and is used for access to the admin web UI and any other Synology provided web apps e.g. their surveillance app.
  • configs are in /etc/nginx, and two symlinks: /etc/nginx/conf.d->/usr/local/etc/nginx/conf.d and /etc/nginx/app.d->/var/tmp/nginx/app.d
  • all config files outside of /usr/local/etc/nginx/conf.d are overwritten on startup so only put changes in here!
  • if you need HTTPS, you can follow the basic instructions in the wiki link above and then steal the files:
  • ->config file from app.d/server.ReverseProxy.conf
  • ->certificate files from /usr/syno/etc/certificate/ReverseProxy/*
  • put the config file in conf.d/http.{AnyNameYouLike}.conf
  • put the certificate files in conf.d/cert and update the file paths in the config file to match
  • add the above config lines to the config file to map the API calls
  • delete the basic reverse proxy config via the admin web UI as this will clash with your new one
  • restart nginx service (sudo stop nginx; sudo start nginx)
You may also want to force Domoticz user login on all network connections: simply go to the settings page and delete the local IP address (127.0.0.1) from the no-login-required box then click apply. This avoid any potential header-hacking based security issues.
HTH
Stu
embee999
Post by embee999 »
The (non-premium) version is not working now. V0.2.371(9474) has the Oops! no data error. I have read there have been API changes causing the app to fail (but that was October). Can anybody inform my of the working server version that the premium is working with so I can upgrade?
redtop
Post by redtop »
embee999 wrote: Monday 15 April 2024 10:03 The (non-premium) version is not working now. V0.2.371(9474) has the Oops! no data error. I have read there have been API changes causing the app to fail (but that was October). Can anybody inform my of the working server version that the premium is working with so I can upgrade?
Pic from Google Play. This is free version 0.2.371 (9474.
Accessing via web page on the phone still works.
Screenshot_20240415_101829_Google Play Store.jpg (107.45 KiB) Viewed 1293 times
embee999
Post by embee999 »
Thanks for the quick response, I'll get onto it.
embee999
Post by embee999 »
Update to latest release fixed the app issue.
Mike38
Post by Mike38 »
Hello
OK, but i cannot update to 2024 because: ARMv6 is not supported anymore
i have 2 raspberry pi B and do'nt need to upgrade, this hardware is working fine
one with arm v7
5.10.103-v7+ #1529 SMP Tue Mar 8 12:21:37 GMT 2022 armv7l GNU/Linux
update ok
one with arm v6
5.10.103+ #1529 Tue Mar 8 12:19:18 GMT 2022 armv6l GNU/Linux
update error
but the 2 pi are same raspberry B
regards
Michel
jvdz
Post by jvdz »
Mike38 wrote: Monday 15 April 2024 16:57 Hello
Then your option still is to use the reverse proxy solution I shared. ;)
juankar
Post by juankar »
I'm using free version of Domoticz in my Android and I have the same problem "no data on the server" since about a week of days ago.
I've update to the lsat version without success.
In Domoticz Server log I can see that the app connect with server
2024-04-18 10:03:44.067 Status: Login successful from 192.168.1.86 for user 'xxxxx'
2024-04-18 10:03:44.068 Status: [web:8080] Incoming connection from: 192.168.1.86
Where is the problem?
jvdz
Post by jvdz »
Which version of Domoticz are you running?
juankar
Post by juankar »
Domoticz App (Android): 0.2.375 (9514)
Update a day ago. The problem appeared before update
I can access remotely using web browser.
EricDeMeutter
Post by EricDeMeutter »
I have the same problem a couple of days.
It won't work on 2 celfhones. (samsung A54 and A34)
It still works on a Ipad and samsung tab.
Cyril09
Post by Cyril09 »
I too have exactly the same problem on my Google Pixel 6a.
Apk version :0.2.375(9514)
Domoticz os: raspberry pi 3B+
Domoticz version: 2020.2(b63341bc0)
Domoticz version: 2024.7
I don't know about the premium app but the free app needs Domoticz 2024.x now.
