Hello community,
I have been trying to use a Zigbee Button to trigger different things. In this example, I am trying to switch an air dehumidifier on using that button.
Currently, I am either switching the air dehumidifier on using my phone or using the phsycal button on the Shelly Plug S actor. Then, after a certain period of time, the air dehumidifier will be switched off again. This works fine. But because I relocated the actor, which is now hard to reach, I wanted to add a wireless button.
The physical button registered four buttons buttons to Domoticz: ON/OFF/UP/DOWN. I want to utilize the "ON" button. None of these buttons ever change their condition. For instance, the "ON" button will never change its status to "OFF". But when I press the button, the "Last Update" value changes.
So I added the button using two different ways... None of these work out. But why? In my screenshots the button is called "Taster Bad AN".
Button won't trigger Blocky
ChrisVH1982
- Event in log.png (52.94 KiB) Viewed 5184 times
- Option 2.png (18.88 KiB) Viewed 5184 times
- Option 1.png (10.73 KiB) Viewed 5184 times
