Get group settings  [Solved]
mvleusden
Domoticz version: 2024.3
Post by mvleusden »
I have setup a group within Domoticz which called "All". This group has several devices defined, one called "Led Keuken". Within a dzVents script I would like to ask what level I setup for this device.
2024-04-07 12_43_55-Clipboard.png (48.44 KiB) Viewed 871 times
Is this possible to do? and if so, has some one a sample cond for me?
Thanks,
Marcel
willemd
Domoticz version: 2026.3
Re: Get group settings
Post by willemd »
Did you check the wiki? If you know the type of the device and the idx then the wiki tells you which command to use.
https://www.domoticz.com/wiki/DzVents:_ ... _scripting
mvleusden
Post by mvleusden »
sometimes you have to look twice. could reas the setting with
local myDevice = domoticz.groups('All').devices().find(function(device)
	return device.name == 'Led Keuken'
	end)
domoticz.log('Level is set to: ' .. myDevice.level)
Thanks.
willemd
Post by willemd »
wow, next level DzVents .... respect :-)
