I have setup a group within Domoticz which called "All". This group has several devices defined, one called "Led Keuken". Within a dzVents script I would like to ask what level I setup for this device.
Is this possible to do? and if so, has some one a sample cond for me?
Thanks,
Marcel
Get group settings [Solved]
willemd
- Domoticz version: 2026.3
Re: Get group settings
Did you check the wiki? If you know the type of the device and the idx then the wiki tells you which command to use.
https://www.domoticz.com/wiki/DzVents:_ ... _scripting
- mvleusden
- Domoticz version: 2024.3
sometimes you have to look twice. could reas the setting with
Thanks.
local myDevice = domoticz.groups('All').devices().find(function(device)
return device.name == 'Led Keuken'
end)
domoticz.log('Level is set to: ' .. myDevice.level)-
willemd
wow, next level DzVents .... respect
