meaning of result .getColor()
BartSr
Domoticz version: V2024.7
Post by BartSr »
Hi!
I'm playing a bit with new RGB devices.
Once I use the command .getColor() next is the return:
setcolbrightnessvalue: ID: 5a0, bri: 1, color: '{m: 3, RGB: 0000ff, CWWW: ca35, CT: 53}'
Is there somewhere documentation which teaches me about the meaning?
TIA Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Domoticz version: 2026.3
Re: meaning of result .getColor()
What did you miss in the dzvents documentation (referring to the API documentation)?
Wiki documentation of setColor() is referring to API documentation: https://www.domoticz.com/wiki/Domoticz_ ... emperature
BartSr
Post by BartSr »
thanks for your reply Walter but it's about the returned value of .getcolor() not the .setcolor()
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
But the values you are getting are described there..... Scroll a little bit down....
BartSr
Post by BartSr »
Walter, for me it's weird stuff.
what to do e.g. with ID : 5a0? Or do I overlook something?
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
5A0 is 1440 in decimal form so perhaps that is the IDX of the device in hex?
You could also do a JSON getdevices API call for that Domoticz device and see if you can relate reported values
 /json.htm?type=command&param=getdevices&rid=IDX
