RELAY-NET-V5.9 LAN 8 channel relay and binary input card
clements63
Post by clements63 »
Hello all,
I have 3 relay and Input cards in V5.7 whci works perfectly with Domotics.
And I have 2 relay and Input cards in V5.9 but the Domoticz plugin seems not adapted : input and relay status are not updated in Domoticz. Do you know how to configure Domoticz please ?
Thanks for your feedback
Domoticz version: 2026.3
Re: RELAY-NET-V5.9 LAN 8 channel relay and binary input card
It would help if you give a little bit more information about the plugin. It does not ring a bell for me.
clements63
Here after the hardware implemented :
RonkA
Domoticz version: 2025.1
Post by RonkA »
Did you use the same IP adres and port number for both cards?
SolarEdge ModbusTCP - Kaku - Synology NAS - Watermeter - ESPEasy - DS18b20
Work in progress = Life in general..
clements63
No each card use her own ip address and port 1234
RonkA
Post by RonkA »
need more info; maybe you can make a screenshot of menu-page?
I see that it is a build in hardware gateway: https://github.com/domoticz/domoticz/bl ... layNet.cpp
In the source code some instructions are given to test the relay card. Are they working in your relay card with higher version?
The source code is basically unchanged for 7 years, later only some general code refractoring done that should not have influenced the working of the integration.
RonkA
Post by RonkA »
RonkA wrote: Monday 25 March 2024 22:29 is this something?
https://ubwh.com.au/documents/SR-2CH_user_manual_en.pdf
page 43
I think this is related to another brand of relay cards. But perhaps they are compatible....
clements63
Here after some details about the card :
https://github.com/mgx0/ZMRN0808-V5
User manual here : https://github.com/mgx0/ZMRN0808-V5/blo ... Manual.pdf
Same firmware for 5.8 and 5.9
Commands sent by Domoticz OK
But status form the card to domoticz is failed
According other forums (jeedom for example), it could be linked to the TCP
habahabahaba
Domoticz version: 2024.4
Post by habahabahaba »
Try to change port number in Dz and in the Relay options (And the port number must match in Dz and in the relay settings).
For each relay its own port.
clements63
If I use an other port than 1234, I have the following log :
2024-03-26 09:33:00.229 Status: RelaisIP_4: 5-second poller started (192.168.1.94)
the relay card is not connected with Dz
Instead of :
2024-03-26 09:34:16.483 Status: RelaisIP_4: 5-second poller started (192.168.1.94)
2024-03-26 09:34:16.485 Status: RelaisIP_4: Connected to Relay Module 192.168.1.94
Dz can send request to the card
habahabahaba
Did you also change the port number on Relay?
clements63
it's not possible to update the port in relay
in Dz, if I configure an other port, the communication is OK.
I think the Dz pluging is not adapted to this card version, but I don't know how to find it and change it.
RonkA
Post by RonkA »
So the board is has firmware 5.9 running and this could be the problem by being to new for the plugin..
The github has the 5.8 hexfile; you could try to downgrade the firmware by flashing in this 'older' firmware. (in the readme it's mentioned.. )
or maybe it is possible with this flashtool to make a copy of your 5.7 firmware and flashing this onto the newer board..
i would suggest to take some screenshots of the settings before trying.
As for a different approach; I don't know if it's a possible workaround to run a second plugin in Domoticz with different ip but same port for the newer board?
habahabahaba
Did you try
/System.cgi
/relay.cgi
/settings.cgi
/network.cgi
after web authorization
as it saying on github?
What is there on that adresses?
clements63
Tool Flash Magic not allow to perform a backup of the old firmware on the old card to upload it in the new card :(
Update the plugin in Dz seems a better option but I don’t know how do it
clements63
habahabahaba wrote: Tuesday 26 March 2024 11:56 Did you try
/System.cgi
/relay.cgi
/settings.cgi
/network.cgi
These request are working fine. Only the updated status of input and relay are not received by Domoticz
habahabahaba
I have similar relays. But there is another plugin in Domoticz and broader settings.
Each relay operates on its own UDP port, otherwise the status is not returned either.
So I think if you can't change the port settings, there's no way you can make it work.
BartSr
Domoticz version: V2024.7
Post by BartSr »
I recently also used the LAN ethernet 8 channel realay and binairy inputchannel.
I only knew I could hook up to these relays by default (after reset) @ 192.168.1.166
From there I set the parms to my domoticz app.
First one went OK as expected
Second did not create new devices.
I found the solution by changing port# 12345 > 12341
Maybe same solution for this problem.
Why not? Just go to website being the ip# you set for the relay in domoticz hardware
Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
