After installing Domoticz on a raspberry pi 4b i can't acces the default webpage. Wen i check the status of Domoticz is get this error:
domoticz.sh[2248]: /home/pi/domoticz/domoticz: error while loading shared libraries: libssl.so.1.1: cannot open shared object f>
Anyone now how i can solve this?
(PS i have installed the 64 bits version of Bookshelf)
I allready tried to disable 64 bits in the config file but then the pi does not boot anymore
Fresh install on raspberrypi Bookshelf can't acces
akamming
Re: Fresh install on raspberrypi Bookshelf can't acces
try
sudo apt install libssl1.1
mobielbas
- Domoticz version: 2021.1
I have tried that but the problem still exists. I saw i did not post the hole sentence:
/home/pi/domoticz/domoticz: error while loading shared libraries: libssl.so.1.1: cannot open shared object file: No such file or directory
mobielbas
I was to quick, after a reboot everything works! Thanks!
