Combining solar panel systems
bldewit
- Domoticz version: Stable
Within the next few weeks we will be installing a second set of solar panels with it's own inverter. I can add this system to my Domoticz as a seperate unit, with it's own sensors, no problems there.
Additionally however, I would like to have a set of sensors that represent the total yield of both systems added together.
What would be the way to achieve this?
Many thanks!
Verstuurd vanaf mijn SM-T590 met Tapatalk
Many thanks!
Running on rPi 3b (main) and rPi 2b (somfy), both RFLink
IthoRemote, Xiaomi Gateway, KAKU
willemd
- Domoticz version: 2024.1
Re: Combining solar panel systems
Create some dummy sensors and use a dzvents script, triggered by change in your solar panel sensors, to add the values together and store it on the dummy sensors.
bldewit
Would you suggest singular dummy sensors for each value i wish to monitor or add a dummy Solar sensor? In the last case, how can i find out the variable names for the values i need to add?
- Domoticz version: 2025.1
This is the Dzvents script I use to combine my 3 inverters and put the value in a dummy custom sensor. You could make it fancier by using an energy counter but that makes more calculations needed that I did not want to do.
timer = {
'every 10 minutes'
execute = function(domoticz, device, timer)
-- Replace between () the idx or 'name' of your solar panel devices or put -- in front of it if you don't use it
local vandaagKwhzon = domoticz.devices(141).counterToday -
local vandaagKwhzon2 = domoticz.devices(184).counterToday
local vandaagKwhzon3 = domoticz.devices(478).counterToday
-- Create a customsensor with Kwh as variable and replace the idx or 'name' with your device name or idx
local zonTotaal = domoticz.devices(367)
-- calculate total kWh
local kwhOpbrengst = tonumber(domoticz.utils.round((vandaagKwhzon + vandaagKwhzon2 + vandaagKwhzon3),2))
-- update total custom sensor
zonTotaal.updateCustomSensor(kwhOpbrengst)
bldewit
Looks superb, thx!
bldewit
I added a custom sensor type Usage Electric. With the script above i get following message:
"2024-02-28 18:30:00.473 Error: dzVents: Error: (3.1.8) Method updateCustomSensor is not available for device "Solar Total Yield" (deviceType=Usage, deviceSubType=Electric). If you believe this is not correct, please report"
Have i done something wrong?
I made a custom sensor. So nothing electric.
https://www.domoticz.com/wiki/Dummy_for ... tom_Sensor
bldewit
Created a new sensor type Counter, same error message...
Create a sensor type "Custom Sensor" as shown in the wiki link.
bldewit
Right, got it now, that did the trick!waltervl wrote: Wednesday 28 February 2024 19:40 Create a sensor type "Custom Sensor" as shown in the wiki link.
