Thanks a lot. Will try todayThorgal789 wrote: Saturday 24 February 2024 21:14 I have updated the code to "trying" to support your device (just comment/uncomment in platformio.ini file), I m using pin from here https://github.com/Smanar/CYD-Domoticz-Remote/issues/2
The code compile, but I think your device don't use the same driver, I m using DILI9341_2_DRIVER but I think you need to use DILI9341_DRIVER, problem with this driver you will miss some declaration.
I m searching a working project with this device, and you will probably need the same lib than @kniazio (lovyanGFX), but I prefer make try first with TFT_eSPI
Edit:
Have found a new configurationThis one is compiling, I don't think the touch will work but I think the display will be fine.Code: Select all
"-DILI9341_DRIVER=1", "-DESP32_2432S024C",
This last change is not yet on the github.
New project, a small wall display to control Domoticz using CYD (Cheap ESP32 touchscreen)
palnic
- Domoticz version: V3.8153
Re: New project, a small wall display to control Domoticz using CYD (Cheap ESP32 touchscreen)
palnic
Thanks again! As you said it is compiling now but touch doesn't work. All I can see is "Calibrate screen"
Thorgal789
- Target OS: -
Yes exaclty, I have put this one in my list but it have somes negatives points
- the price, it's correct, but others are realy cheaper.
- Need to make a special hole in the wall, and I already have one (standard hole in my country), so I need to adapt it, for the other one, I just need to print a case, put a 230AC/5VDC alimentation in the hole, and the device behind.
-Few documentation.
But for the moment it's the better one I have found.
@palnic I based the code on this issue https://github.com/HASwitchPlate/openHASP/issues/555
But it seem the lib I m using don't support this touchpad, so need to migrate too on the LOVYANGFX.
The only working project for your device I have found is this one https://github.com/elik745i/ESP32-2432s024c so I will use the same config.
I have a new version using the second lib on the github, but on branch "test", I m breaking other stuff ATM so I can't send it on "master".
palnic
I saw the openHASP project and a few years back I tried to adopt it to Domoticz. Unfortunately my programming skills is not good enough, I am electrical engineer, and I wasn't able finish this job. I still have case from the HASP and ESP32-2432s024c wilt fit almost perfectly. This is a standard case for US. It would be nice to finish this project for Domoticz
Thorgal789
- Target OS: -
Do you have tried the branch "test" on my github to see if this one is working ? Display and touch ?
I have updated it yesterday with the same setting than in the openHASP project ,but my driver, so I don't know the result.
https://github.com/Smanar/CYD-Domoticz-Remote/tree/test
palnic
The sensing definitely works, the is some issue with display pictures will look into
kniazio
- Domoticz version: 3.7243
As usual, @Thorgal789 did a lot of work. The display now works very stably. All I need is additional websites for my devices
- EdwinK
- Domoticz version: BETA
Going to try this with the CYD that I bought for my printer but is now not needed anymore.
Thorgal789
- Target OS: -
@palnic The field to play are
On the json file and
in the screen_driver.cpp file, sometime we need to reverse TFT_HEIGHT and TFT_WIDTH.
If you can't success, I will try to compile the project that use your device, this action will enable/disable code, so easier to understand the good config in this "multi support" code.
@EdwinK
Take care the last code is still on the branch "test", I haven't updated the master branch yet, need to make some bench to see cpu/memory use with the new code.
"-DTFT_WIDTH=240",
"-DTFT_HEIGHT=320",
"-DTFT_ROTATION=4",Code: Select all
disp_drv.hor_res = TFT_HEIGHT;
disp_drv.ver_res = TFT_WIDTH;If you can't success, I will try to compile the project that use your device, this action will enable/disable code, so easier to understand the good config in this "multi support" code.
@EdwinK
palnic
Thanks. Here are my settings:
platformio.ini:
-DTFT_WIDTH=320
-DTFT_HEIGHT=240
-DTFT_ROTATION=2
screen_driver.cpp:
Display looks perfect, but sensing doesn't work
platformio.ini:
-DTFT_WIDTH=320
-DTFT_HEIGHT=240
-DTFT_ROTATION=2
screen_driver.cpp:
Thorgal789
- Target OS: -
You need to reverve the display at 90° no ? Widgets are by defaut more longer than larger.
On the platoformio.ini file
Set it to "true", It's possible the previously memorised don't work with your new setting. This setting will reset the touch calibration at every restart.
(And there is a setting to reverse the touchpad too if neeeded, but harder to see, I can give you a code to see the pointer, easier to see if you need to reverse it too)
It have worked previously ? Yes else you will be blocked at calibration step.but sensing doesn't work
-DFORCECALIBRATE=false (And there is a setting to reverse the touchpad too if neeeded, but harder to see, I can give you a code to see the pointer, easier to see if you need to reverse it too)
palnic
OK. It works now, trying to connect to Domoticz. Thanks a lot. What about cup of coffee
Thorgal789
- Target OS: -
Lol, for me will be soon a full diner.
Give me your last setting, 90° reversed (or you can keep it in this side, but not sure what can be the result) I will put them in my next update.
For information I m searching a way to add secondary (or more) page, will be the same than on the homepage, but not updated in real time.
And I still have a strange issue on too big json.
palnic
Ok, enjoy your dinner. My lunch is over, working to rotate the screen
palnic
Actually I am going to keep it vertically, since I want to replace some wall switch and display extra info on the screen. My settings stay the same:
platformio.ini:
-DTFT_WIDTH=320
-DTFT_HEIGHT=240
-DTFT_ROTATION=2
screen_driver.cpp:
So far I can't connect to Domoticz, says "Failed to connect"?
platformio.ini:
-DTFT_WIDTH=320
-DTFT_HEIGHT=240
-DTFT_ROTATION=2
screen_driver.cpp:
palnic
No matter what I do, the is no connection to Domoticz. Connected to WiFi, Domoticz is ON, but can't connect display, it says "Failed to connect"
Thorgal789
- Target OS: -
No problem, I will update the code for the vertical support, waiting if one day I found someone that need the horizontal. But you will probably need to change the display 2*4 instead of 3*3 ?
Value to enter for connexion need to be for exemple:
- host : 192.168.1.1
- port : 8080
If it don't work
- port : 8080
If it don't work
Be sure the device have its IP autorised in the Trusted Networks setting in Domoticz.
palnic
My Domoticz address is 192.168.0.86:8080. This is what I entered. Looks like it doesn't reset connection after if failed once.
- 20240229_104914.jpg (80.45 KiB) Viewed 3082 times
Thorgal789
- Target OS: -
If I m right it's memorised, but you have a button to reset it.Looks like it doesn't reset connection after if failed once
You can set them direclty in code in main.cpp
#if FORCE_CONFIG
strcpy(global_config.wifiPassword, "xxxxxxxxxxxxxxxxxxx");
strcpy(global_config.wifiSSID, "xxxxxxxxxxxxxxx");
strcpy(global_config.ServerHost, "192.168.1.1");
global_config.ServerPort = 8080;
global_config.wifiConfigured = true;
global_config.ipConfigured = true;
const static int t[] = {37, 75, 16, 36, 28, 35, 57, 89, 45};
for (int i=0; i<TOTAL_ICONX*TOTAL_ICONY; i++)
global_config.ListDevices[i] = t[i];
WriteGlobalConfig();
#endif
You see nothing in domoticz log, or on device log (with serial monitor) ?
Yo have added the device IP to domoticz setting (trusted network) ?
