zwave-js-ui container keeps restarting (loops)
hvoorend
Domoticz version: 2024.2
Post by hvoorend »
Hi all, I'm in the process of migrating to MQTT-zwavejs-ui. MQTT (Mosquitto) container installed and gateway definitions in Domoticz created for "MQTT Client Gateway" and "MQTT Auto Discover Client Gateway". After spinning up the zwave-js-ui container, I'm able to access it via my browser. After zwavejs-ui configuration (according to the instructions here (https://www.domoticz.com/wiki/Zwave-JS-UI)), I do see devices coming into the zwavejs-ui but after about 50 seconds they disappear and I can see from "docker ps" that my container restarted. Then it starts all over again. Any idea what could be wrong or help on how to investigate ?
Raspberry Pi 2
Raspbian Bookworm
Aeon zStick Gen5 fw 1.0
RFXCOM USB
Domoticz 2024.2
mgugu
Re: zwave-js-ui container keeps restarting (loops)
Post by mgugu »
Check logs. Use docker-compose up without daemon, In a terminal, write:
cd <yml directory>
docker-compose down
docker-compose up
Logs should appear in the terminal
akamming
Post by akamming »
Or just docker compose logs -f
hvoorend
Post by hvoorend »
Thanks. Got this:
zwave-js-ui  | #
zwave-js-ui  | # Fatal error in , line 0
zwave-js-ui  | # unreachable code
zwave-js-ui  | #
zwave-js-ui  | #
zwave-js-ui  | #
zwave-js-ui  | #FailureMessage Object: 0x74007764
zwave-js-ui exited with code 0
Running Buster currently. Do you think I need to upgrade to Bookworm and retry ?
Raspberry Pi 2
Raspbian Bookworm
RFXCOM USB
Domoticz 2024.2
Varazir
Post by Varazir »
I hade issue with looping as well. Both times was that it couldn't access the device.
Could you share your compose conf file ?
What type of Zwave HW do you use ?
Raspberry PI 4 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
Several IKEA devices/z-wave devices
hvoorend
Post by hvoorend »
Thanks Varazir and others. Am not able to answer the questions yet as I decided to upgrade to Bookworm in the meantime, but the upgrade ran into an error (libc6) and wacked my full raspbian (seems to be a known error. At least not to me. So I had to recover from an SD-card image. Luckily only one week old but I had to rebuild my MQTT/ZWaveJS-UI efforts from Docker Engine up. Almost there again and will retest then. Maybe with better results. Who knows. Will keep yo posted.
Raspberry Pi 2
Raspbian Bookworm
RFXCOM USB
Domoticz 2024.2
hvoorend
Post by hvoorend »
Unfortunately still a looping container. Here a list of my Pi USB devices:
pi@raspberrypi:~ $ ls /dev/serial/by-id -l
total 0
lrwxrwxrwx 1 root root 13 Feb 23 22:36 usb-0658_0200-if00 -> ../../ttyACM0
lrwxrwxrwx 1 root root 13 Feb 23 22:36 usb-RFXCOM_RFXtrx433_A12WY8N-if00-port0 -> ../../ttyUSB0
So usb-0658_0200-if00 is my Aeon zStick 5 (as you can see I also have a RFXCOM dongle installed: usb-RFXCOM_RFXtrx433_A12WY8N-if00-port0).
Here the contents of /opt/zwavejs-ui/docker-compose.yml:
version: "3.7"
services:
  zwave-js-ui:
    container_name: zwave-js-ui
    image: zwavejs/zwave-js-ui:latest
    restart: unless-stopped
    tty: true
    stop_signal: SIGINT
    environment:
      - SESSION_SECRET=mySecretSession
      - TZ=Europe/Amsterdam
    devices:
      - '/dev/serial/by-id/usb-0658_0200-if00:/dev/zwave'
    volumes:
      - ./store:/usr/src/app/store
    ports:
      - "8091:8091" # port for web interface
      - "3000:3000" # port for Z-Wave JS websocket server
Does anyone have any suggestions ?
Raspberry Pi 2
Raspbian Bookworm
RFXCOM USB
Domoticz 2024.2
hvoorend
Post by hvoorend »
By the way: a "docker compose up" shows:
root@raspberrypi:/opt/zwavejs-ui# docker compose up
[+] Running 1/1
 ✔ Container zwave-js-ui  Recreated        0.4s
Attaching to zwave-js-ui
zwave-js-ui  | 2024-02-27 21:04:24.357 INFO APP: Version: 9.9.0.09b107a
zwave-js-ui  | 2024-02-27 21:04:24.390 INFO APP: Application path:/usr/src/app
zwave-js-ui  |   ______  __          __                      _  _____     _    _ _____
zwave-js-ui  |  |___  /  \ \        / /                     | |/ ____|   | |  | |_   _|
zwave-js-ui  |     / /____\ \  /\  / /_ ___   _____         | | (___     | |  | | | |
zwave-js-ui  |    / /______\ \/  \/ / _' \ \ / / _ \    _   | |\___ \    | |  | | | |
zwave-js-ui  |   / /__      \  /\  / (_| |\ V /  __/   | |__| |____) |   | |__| |_| |_
zwave-js-ui  |  /_____|      \/  \/ \__,_| \_/ \___|    \____/|_____/     \____/|_____|
zwave-js-ui  |
zwave-js-ui  | 2024-02-27 21:04:24.542 WARN STORE: scenes.json not found
zwave-js-ui  |
zwave-js-ui  | /usr/src/app/server/app.js:597
zwave-js-ui  |             gw.zwave?.setUserCallbacks();
zwave-js-ui  |                ^
zwave-js-ui  | TypeError: Cannot read properties of undefined (reading 'zwave')
zwave-js-ui  |     at SocketManager.<anonymous> (/usr/src/app/server/app.js:597:16)
zwave-js-ui  |     at SocketManager.emit (node:events:517:28)
zwave-js-ui  |     at SocketManager._onConnection (/usr/src/app/server/lib/SocketManager.js:48:14)
zwave-js-ui  |     at Namespace.emit (node:events:529:35)
zwave-js-ui  |     at Namespace.emitReserved (/usr/src/app/node_modules/socket.io/dist/typed-events.js:56:22)
zwave-js-ui  |     at Namespace._doConnect (/usr/src/app/node_modules/socket.io/dist/namespace.js:269:14)
zwave-js-ui  |     at /usr/src/app/node_modules/socket.io/dist/namespace.js:231:22
zwave-js-ui  |     at processTicksAndRejections (node:internal/process/task_queues:77:11)
Raspberry Pi 2
Raspbian Bookworm
RFXCOM USB
Domoticz 2024.2
hvoorend
Post by hvoorend »
I’m pretty much stuck. Anyone any suggestions for a direction to look into? Hope someone can help me out. Otherwise I need to revert back to OZW… :roll: . Thanks in advance for your thoughts.
Raspberry Pi 2
Raspbian Bookworm
RFXCOM USB
Domoticz 2024.2
Domoticz version: 2026.3
Perhaps better to ask this to the specialists of Zwave-JS-UI on their GitHub repository
https://github.com/zwave-js/zwave-js-ui/issues
mgugu
Post by mgugu »
hvoorend wrote: Tuesday 27 February 2024 21:01 Here the contents of /opt/zwavejs-ui/docker-compose.yml:
version: "3.7"
services:
  zwave-js-ui:
    tty: true
    stop_signal: SIGINT
    environment:
    devices:
    volumes:
    ports:
You set an internal zwave device as /dev/zwave but it should be /dev/ttyACM0. This is probably the source of error shown in the logs
/dev/serial/by-id/usb-0658_0200-if00 is a proper device and should be used in favorite of eg /dev/ttyACM0 as those can change when having multiple USB devices in use.....
So the docker-compose.yml seems OK. Something else is wrong here....
hvoorend
Post by hvoorend »
Might my zStick Gen5 running firmware 1.0 need a firmware update ? (think 1.2 is the latest if I’m correct). Thanks for your responses sofar. Will consult the GitHub guys as well in the meantime.
Raspberry Pi 2
Raspbian Bookworm
RFXCOM USB
Domoticz 2024.2
mgugu
Post by mgugu »
waltervl wrote: Thursday 29 February 2024 17:15 /dev/serial/by-id/usb-0658_0200-if00 is a proper device and should be used in favorite of eg /dev/ttyACM0 as those can change when having multiple USB devices in use.....
I do not speak about the docker external device but the internal on whick AFAIK has to be /dev/ttyACM0 and not /dev/zwave.
So the complete devices option should be:
devices:
      - '/dev/serial/by-id/usb-0658_0200-if00:/dev/ttyACM0'
It is the default setup of the Zwave-JS-UI docker container to use /dev/zwave so it should have no impact.
BUT in Zwave-JS-UI user interface (port 8091) settings check that the correct device is used: the second part of the docker device configuration /dev/zwave or /dev/ttyACM0 and press on SAVE (important action!!)
mgugu
Post by mgugu »
At this step of installation he has no access to the UI so no possibility to change something.
My interpretation of the log
zwave-js-ui  |                ^
is that the gateway 'zwave' cannot be accessed, so an exception is raised.
It is worth to try to change the device name, at least for a test.
hvoorend
Post by hvoorend »
I ran some test with your suggestions: first I changed to '/dev/serial/by-id/usb-0658_0200-if00:/dev/ttyACM0' in docker-compose.yaml and restarted the zwavejs-ui container. Connected to the UI and changed Zwave Serial port settings to
zwave serial port.png (30.98 KiB) Viewed 4531 times
and SAVED :D . This resulted in
Driver failed to open.png (19.37 KiB) Viewed 4531 times
Restart of the container -> same result.
Reverted back to '/dev/serial/by-id/usb-0658_0200-if00:/dev/zwave' in docker-compose.yml and started the container without -d flag (so: docker compose up). Changed to /dev/zwave in UI settings and the driver was opened all right:
zwave serial port2.png (32.81 KiB) Viewed 4531 times
but the container crashed with:
pi@raspberrypi:/opt/zwavejs-ui $ sudo docker compose up
[+] Running 2/2
 ✔ Network zwavejs-ui_default  Created        0.5s
 ✔ Container zwave-js-ui       Created        0.3s
zwave-js-ui  | 2024-02-29 19:58:25.938 INFO APP: Version: 9.9.0.09b107a
zwave-js-ui  | 2024-02-29 19:58:25.968 INFO APP: Application path:/usr/src/app
zwave-js-ui  |
zwave-js-ui  | 2024-02-29 19:58:26.116 WARN STORE: scenes.json not found
zwave-js-ui  | Logging to file:
zwave-js-ui  |  /usr/src/app/store/logs/zwavejs_2024-02-29.log
zwave-js-ui  |
zwave-js-ui  |
zwave-js-ui  | #
zwave-js-ui  | #
zwave-js-ui  | #
zwave-js-ui  | #
zwave-js-ui  | #FailureMessage Object: 0x75821764
I have attached a piece of /usr/src/app/store/logs/zwavejs_2024-02-29.log . I actually do not see any signs that there is something wrong, but I'm not into the internals of zwavejs-ui. I did notice that the log times from the docker are 1 hour behind on my RPI (local) time (?).
docker exec -it zwave-js-ui sh
/usr/src/app/
cat store/logs/zwavejs_2024-02-29.log
2024-02-29T19:18:32.796Z DRIVER   ███████╗        ██╗    ██╗  █████╗  ██╗   ██╗ ███████╗          ██╗ ███████╗
2024-02-29T19:18:32.805Z DRIVER   version 12.4.4
2024-02-29T19:18:32.810Z DRIVER
2024-02-29T19:18:32.814Z DRIVER   starting driver...
2024-02-29T19:18:32.816Z DRIVER   opening serial port /dev/zwave
2024-02-29T19:18:33.052Z DRIVER   serial port opened
2024-02-29T19:18:33.064Z SERIAL » 0x15        (1 bytes)
2024-02-29T19:18:33.138Z SERIAL « 0x0110000400290a7105000000ff070001084d                              (18 bytes)
2024-02-29T19:18:33.178Z DRIVER   Dropping message because the driver is not ready to handle it yet.
2024-02-29T19:18:33.185Z SERIAL » [ACK]        (0x06)
2024-02-29T19:18:33.198Z SERIAL « 0x0110000400260a32022134000000310000d3                              (18 bytes)
2024-02-29T19:18:33.211Z DRIVER   Dropping message because the driver is not ready to handle it yet.
2024-02-29T19:18:33.214Z SERIAL » [ACK]        (0x06)
2024-02-29T19:18:34.120Z DRIVER   loading configuration...
2024-02-29T19:18:34.176Z CONFIG   Using external configuration dir /usr/src/app/store/.config-db
2024-02-29T19:18:34.180Z CONFIG   version 12.4.4
2024-02-29T19:18:41.678Z DRIVER   beginning interview...
2024-02-29T19:18:41.689Z DRIVER   added request handler for AddNodeToNetwork (0x4a)...
                                  1 registered
2024-02-29T19:18:41.691Z DRIVER   added request handler for RemoveNodeFromNetwork (0x4b)...
                                  1 registered
2024-02-29T19:18:41.692Z DRIVER   added request handler for ReplaceFailedNode (0x63)...
                                  1 registered
2024-02-29T19:18:41.696Z DRIVER   added request handler for SerialAPIStarted (0x0a)...
                                  1 registered
2024-02-29T19:18:41.703Z CNTRLR   querying Serial API capabilities...
2024-02-29T19:18:43.599Z SERIAL » 0x01030007fb                                                         (5 bytes)
2024-02-29T19:18:43.612Z DRIVER » [REQ] [GetSerialApiCapabilities]
2024-02-29T19:18:43.696Z SERIAL « [ACK]        (0x06)
2024-02-29T19:18:43.718Z SERIAL « 0x012b0107010000860001005afe81ff884f1f0000fb9f7da067000080008086000 (45 bytes)
                                  000e87300000e0000600000fb
2024-02-29T19:18:43.734Z SERIAL » [ACK]        (0x06)
2024-02-29T19:18:43.748Z DRIVER « [RES] [GetSerialApiCapabilities]
                                    payload: 0x010000860001005afe81ff884f1f0000fb9f7da067000080008086000000e8730
                                  0000e0000600000
2024-02-29T19:18:43.881Z CNTRLR   received API capabilities:
                                    firmware version:    1.0
                                    manufacturer ID:     0x86
                                    product type:        0x01
                                    product ID:          0x5a
                                    supported functions:
                                    · GetSerialApiInitData (0x02)
                                    · SetApplicationNodeInformation (0x03)
                                    · ApplicationCommand (0x04)
                                    · GetControllerCapabilities (0x05)
                                    · SetSerialApiTimeouts (0x06)
                                    · GetSerialApiCapabilities (0x07)
                                    · SoftReset (0x08)
                                    · GetProtocolVersion (0x09)
                                    · SetRFReceiveMode (0x10)
                                    · UNKNOWN_FUNC_SET_SLEEP_MODE (0x11)
                                    · FUNC_ID_ZW_SEND_NODE_INFORMATION (0x12)
                                    · SendData (0x13)
                                    · SendDataMulticast (0x14)
                                    · GetControllerVersion (0x15)
                                    · SendDataAbort (0x16)
                                    · FUNC_ID_ZW_R_F_POWER_LEVEL_SET (0x17)
                                    · UNKNOWN_FUNC_SEND_DATA_META (0x18)
                                    · FUNC_ID_ZW_GET_RANDOM (0x1c)
                                    · GetControllerId (0x20)
                                    · UNKNOWN_FUNC_MEMORY_GET_BYTE (0x21)
                                    · UNKNOWN_FUNC_MEMORY_PUT_BYTE (0x22)
                                    · UNKNOWN_FUNC_MEMORY_GET_BUFFER (0x23)
                                    · UNKNOWN_FUNC_MEMORY_PUT_BUFFER (0x24)
                                    · EnterBootloader (0x27)
                                    · GetNVMId (0x29)
                                    · ExtNVMReadLongBuffer (0x2a)
                                    · ExtNVMWriteLongBuffer (0x2b)
                                    · ExtNVMReadLongByte (0x2c)
                                    · ExtExtWriteLongByte (0x2d)
                                    · GetNodeProtocolInfo (0x41)
                                    · HardReset (0x42)
                                    · FUNC_ID_ZW_REPLICATION_COMMAND_COMPLETE (0x44)
                                    · FUNC_ID_ZW_REPLICATION_SEND_DATA (0x45)
                                    · AssignReturnRoute (0x46)
                                    · DeleteReturnRoute (0x47)
                                    · RequestNodeNeighborUpdate (0x48)
                                    · ApplicationUpdateRequest (0x49)
                                    · AddNodeToNetwork (0x4a)
                                    · RemoveNodeFromNetwork (0x4b)
                                    · FUNC_ID_ZW_CREATE_NEW_PRIMARY (0x4c)
                                    · FUNC_ID_ZW_CONTROLLER_CHANGE (0x4d)
                                    · FUNC_ID_ZW_SET_LEARN_MODE (0x50)
                                    · AssignSUCReturnRoute (0x51)
                                    · FUNC_ID_ZW_REQUEST_NETWORK_UPDATE (0x53)
                                    · SetSUCNodeId (0x54)
                                    · DeleteSUCReturnRoute (0x55)
                                    · GetSUCNodeId (0x56)
                                    · UNKNOWN_FUNC_SEND_SUC_ID (0x57)
                                    · FUNC_ID_ZW_EXPLORE_REQUEST_INCLUSION (0x5e)
                                    · RequestNodeInfo (0x60)
                                    · RemoveFailedNode (0x61)
                                    · IsFailedNode (0x62)
                                    · ReplaceFailedNode (0x63)
                                    · UNKNOWN_FUNC_UNKNOWN_0x66 (0x66)
                                    · UNKNOWN_FUNC_UNKNOWN_0x67 (0x67)
                                    · GetRoutingInfo (0x80)
                                    · UNKNOWN_FUNC_LOCK_ROUTE_RESPONSE (0x90)
                                    · GetPriorityRoute (0x92)
                                    · SetPriorityRoute (0x93)
                                    · UNKNOWN_FUNC_UNKNOWN_0x98 (0x98)
                                    · UNKNOWN_FUNC_UNKNOWN_0xB4 (0xb4)
                                    · UNKNOWN_FUNC_WATCH_DOG_ENABLE (0xb6)
                                    · UNKNOWN_FUNC_WATCH_DOG_DISABLE (0xb7)
                                    · UNKNOWN_FUNC_WATCH_DOG_KICK (0xb8)
                                    · UNKNOWN_FUNC_UNKNOWN_0xB9 (0xb9)
                                    · UNKNOWN_FUNC_RF_POWERLEVEL_GET (0xba)
                                    · UNKNOWN_FUNC_GET_LIBRARY_TYPE (0xbd)
                                    · UNKNOWN_FUNC_SEND_TEST_FRAME (0xbe)
                                    · UNKNOWN_FUNC_GET_PROTOCOL_STATUS (0xbf)
                                    · UNKNOWN_FUNC_UNKNOWN_0xD2 (0xd2)
                                    · UNKNOWN_FUNC_UNKNOWN_0xD3 (0xd3)
                                    · UNKNOWN_FUNC_UNKNOWN_0xD4 (0xd4)
                                    · undefined (0xee)
                                    · UNKNOWN_FUNC_UNKNOWN_0xEF (0xef)
2024-02-29T19:18:43.887Z CNTRLR   querying version info...
2024-02-29T19:18:43.982Z SERIAL » 0x01030015e9                                                         (5 bytes)
2024-02-29T19:18:43.986Z DRIVER » [REQ] [GetControllerVersion]
2024-02-29T19:18:44.050Z SERIAL « [ACK]        (0x06)
2024-02-29T19:18:44.067Z SERIAL « 0x011001155a2d5761766520332e3935000199                              (18 bytes)
2024-02-29T19:18:44.074Z SERIAL » [ACK]        (0x06)
2024-02-29T19:18:44.081Z DRIVER « [RES] [GetControllerVersion]
                                    payload: 0x5a2d5761766520332e39350001
2024-02-29T19:18:44.105Z CNTRLR   received version info:
                                    controller type: Static Controller
                                    library version: Z-Wave 3.95
2024-02-29T19:18:44.107Z CNTRLR   querying protocol version info...
2024-02-29T19:18:44.149Z SERIAL » 0x01030009f5                                                         (5 bytes)
2024-02-29T19:18:44.155Z DRIVER » [REQ] [GetProtocolVersion]
2024-02-29T19:18:44.167Z SERIAL « [ACK]        (0x06)
2024-02-29T19:18:44.176Z SERIAL « 0x0107010900035f00ac                                                 (9 bytes)
2024-02-29T19:18:44.181Z SERIAL » [ACK]        (0x06)
2024-02-29T19:18:44.189Z DRIVER « [RES] [GetProtocolVersion]
                                    payload: 0x00035f00
2024-02-29T19:18:44.207Z CNTRLR   received protocol version info:
                                    protocol type:             Z-Wave
                                    protocol version:          3.95.0
2024-02-29T19:18:44.214Z CNTRLR   querying controller IDs...
2024-02-29T19:18:44.251Z SERIAL » 0x01030020dc                                                         (5 bytes)
2024-02-29T19:18:44.257Z DRIVER » [REQ] [GetControllerId]
2024-02-29T19:18:44.274Z SERIAL « [ACK]        (0x06)
2024-02-29T19:18:44.285Z SERIAL « 0x01080120fdd0547b01d5                                              (10 bytes)
2024-02-29T19:18:44.293Z SERIAL » [ACK]        (0x06)
2024-02-29T19:18:44.301Z DRIVER « [RES] [GetControllerId]
                                    home ID:     0xfdd0547b
                                    own node ID: 1
2024-02-29T19:18:44.321Z CNTRLR   received controller IDs:
                                    home ID:     0xfdd0547b
                                    own node ID: 1
2024-02-29T19:18:44.340Z DRIVER   all queues idle
2024-02-29T19:18:44.489Z CNTRLR   Performing soft reset...
2024-02-29T19:18:44.503Z DRIVER   all queues busy
2024-02-29T19:18:44.521Z SERIAL » 0x01030008f4                                                         (5 bytes)
2024-02-29T19:18:44.525Z DRIVER » [REQ] [SoftReset]
2024-02-29T19:18:44.544Z SERIAL « [ACK]        (0x06)
2024-02-29T19:18:44.562Z CNTRLR   Waiting for the controller to reconnect...
2024-02-29T19:18:44.569Z DRIVER   all queues idle
2024-02-29T19:18:46.070Z CNTRLR   Re-opening serial port...
2024-02-29T19:18:47.098Z CNTRLR   Waiting for the Serial API to start...
2024-02-29T19:18:47.851Z SERIAL « 0x010f00040029097105000000ff07080050                                (17 bytes)
2024-02-29T19:18:47.862Z SERIAL » [ACK]        (0x06)
2024-02-29T19:18:47.878Z CNTRLR   [Node 041] is unknown - discarding received command...
2024-02-29T19:18:47.892Z DRIVER « [Node 041] [REQ] [ApplicationCommand]                              [discarded]
                                  └─[NotificationCCReport]
                                      notification type:   Home Security
                                      notification status: 255
                                      notification state:  Motion detection
2024-02-29T19:18:47.899Z SERIAL « 0x01090004000903300300cb                                            (11 bytes)
2024-02-29T19:18:47.910Z SERIAL » [ACK]        (0x06)
2024-02-29T19:18:47.915Z CNTRLR   [Node 009] is unknown - discarding received command...
2024-02-29T19:18:47.921Z DRIVER « [Node 009] [REQ] [ApplicationCommand]                              [discarded]
                                  └─[BinarySensorCCReport]
                                      type:  Any
                                      value: false
2024-02-29T19:18:47.926Z SERIAL « 0x01090004000903200100d9                                            (11 bytes)
2024-02-29T19:18:47.933Z SERIAL » [ACK]        (0x06)
2024-02-29T19:18:47.940Z CNTRLR   [Node 009] is unknown - discarding received command...
2024-02-29T19:18:47.944Z DRIVER « [Node 009] [REQ] [ApplicationCommand]                              [discarded]
                                  └─[BasicCCSet]
                                      target value: 0
2024-02-29T19:18:52.102Z CNTRLR   Did not receive notification that Serial API has started, checking if it respo
                                  nds...
2024-02-29T19:18:52.116Z DRIVER   all queues busy
2024-02-29T19:18:52.136Z SERIAL » 0x01030015e9                                                         (5 bytes)
2024-02-29T19:18:52.144Z DRIVER » [REQ] [GetControllerVersion]
2024-02-29T19:18:52.154Z SERIAL « [ACK]        (0x06)
2024-02-29T19:18:52.162Z SERIAL « 0x011001155a2d5761766520332e3935000199                              (18 bytes)
2024-02-29T19:18:52.166Z SERIAL » [ACK]        (0x06)
2024-02-29T19:18:52.172Z DRIVER « [RES] [GetControllerVersion]
2024-02-29T19:18:52.191Z CNTRLR   Serial API responded
2024-02-29T19:18:52.197Z DRIVER   all queues idle
2024-02-29T19:18:52.289Z CNTRLR   supported Z-Wave features:
2024-02-29T19:18:52.291Z CNTRLR   querying controller capabilities...
2024-02-29T19:18:52.299Z DRIVER   all queues busy
2024-02-29T19:18:52.314Z SERIAL » 0x01030005f9                                                         (5 bytes)
2024-02-29T19:18:52.319Z DRIVER » [REQ] [GetControllerCapabilities]
2024-02-29T19:18:52.327Z SERIAL « [ACK]        (0x06)
2024-02-29T19:18:52.333Z SERIAL « 0x010401051ce3                                                       (6 bytes)
2024-02-29T19:18:52.339Z SERIAL » [ACK]        (0x06)
2024-02-29T19:18:52.344Z DRIVER « [RES] [GetControllerCapabilities]
                                    payload: 0x1c
2024-02-29T19:18:52.358Z CNTRLR   received controller capabilities:
                                    controller role:      primary
                                    is the SUC:           true
                                    started this network: true
                                    SIS is present:       true
                                    was real primary:     true
2024-02-29T19:18:52.359Z CNTRLR   finding SUC...
2024-02-29T19:18:52.381Z SERIAL » 0x01030056aa                                                         (5 bytes)
2024-02-29T19:18:52.383Z DRIVER » [REQ] [GetSUCNodeId]
2024-02-29T19:18:52.402Z SERIAL « [ACK]        (0x06)
2024-02-29T19:18:52.408Z SERIAL « 0x0104015601ad                                                       (6 bytes)
2024-02-29T19:18:52.412Z SERIAL » [ACK]        (0x06)
2024-02-29T19:18:52.416Z DRIVER « [RES] [GetSUCNodeId]
                                    payload: 0x01
2024-02-29T19:18:52.431Z CNTRLR   This is the SUC
2024-02-29T19:18:52.434Z CNTRLR   querying additional controller information...
2024-02-29T19:18:52.460Z SERIAL » 0x01030002fe                                                         (5 bytes)
2024-02-29T19:18:52.465Z DRIVER » [REQ] [GetSerialApiInitData]
2024-02-29T19:18:52.477Z SERIAL « [ACK]        (0x06)
2024-02-29T19:18:52.562Z SERIAL « 0x0125010205081d01dd66daa201000000000000000000000000000000000000000 (39 bytes)
                                  000000005000f
2024-02-29T19:18:52.569Z SERIAL » [ACK]        (0x06)
2024-02-29T19:18:52.573Z DRIVER « [RES] [GetSerialApiInitData]
                                    payload: 0x05081d01dd66daa20100000000000000000000000000000000000000000000000
                                  500
2024-02-29T19:18:52.588Z CNTRLR   received additional controller information:
                                    Z-Wave API version:         5 (legacy)
                                    Z-Wave chip type:           ZW050x
                                    node type                   Controller
                                    controller is the SIS:      true
                                    controller supports timers: false
                                    nodes in the network:       1, 9, 11, 12, 13, 15, 16, 18, 19, 22, 23, 26, 28
                                  , 29, 31, 32, 34, 38, 40, 41
2024-02-29T19:18:52.952Z DRIVER   Cache file for homeId 0xfdd0547b found, attempting to restore the network from
                                   cache...
2024-02-29T19:18:53.021Z DRIVER   all queues idle
2024-02-29T19:18:53.834Z CNTRLR   [Node 001] Embedded device config loaded
2024-02-29T19:18:53.865Z DRIVER   Restoring the network from cache was successful!
2024-02-29T19:18:53.890Z CNTRLR   [Node 001] [Manufacturer Specific] manufacturerId: metadata updated
2024-02-29T19:18:53.896Z CNTRLR   [Node 001] [Manufacturer Specific] productType: metadata updated
2024-02-29T19:18:53.901Z CNTRLR   [Node 001] [Manufacturer Specific] productId: metadata updated
2024-02-29T19:18:53.910Z CNTRLR   [Node 001] [~] [Manufacturer Specific] manufacturerId: 134 => 134
2024-02-29T19:18:53.916Z CNTRLR   [Node 001] [~] [Manufacturer Specific] productType: 1 => 1
2024-02-29T19:18:53.919Z CNTRLR   [Node 001] [~] [Manufacturer Specific] productId: 90 => 90
2024-02-29T19:18:53.929Z CNTRLR   [Node 001] [Version] firmwareVersions: metadata updated
2024-02-29T19:18:53.933Z CNTRLR   [Node 001] [~] [Version] firmwareVersions: 1.0 => 1.0
2024-02-29T19:18:53.937Z CNTRLR   [Node 001] [Version] zWaveProtocolVersion: metadata updated
2024-02-29T19:18:53.940Z CNTRLR   [Node 001] [~] [Version] zWaveProtocolVersion: "3.95.0" => "3.95.0"
2024-02-29T19:18:53.945Z CNTRLR   [Node 001] [Version] sdkVersion: metadata updated
2024-02-29T19:18:53.948Z CNTRLR   [Node 001] [~] [Version] sdkVersion: "6.51.2" => "6.51.2"
2024-02-29T19:18:53.950Z CNTRLR   setting serial API timeouts: ack = 1000 ms, byte = 150 ms
2024-02-29T19:18:53.960Z DRIVER   all queues busy
2024-02-29T19:18:53.976Z SERIAL » 0x01050006640f97                                                     (7 bytes)
2024-02-29T19:18:53.981Z DRIVER » [REQ] [SetSerialApiTimeouts]
                                    payload: 0x640f
2024-02-29T19:18:54.000Z SERIAL « [ACK]        (0x06)
2024-02-29T19:18:54.005Z SERIAL « 0x01050106960f64                                                     (7 bytes)
2024-02-29T19:18:54.011Z SERIAL » [ACK]        (0x06)
2024-02-29T19:18:54.017Z DRIVER « [RES] [SetSerialApiTimeouts]
                                    payload: 0x960f
2024-02-29T19:18:54.031Z CNTRLR   serial API timeouts overwritten. The old values were: ack = 1500 ms, byte = 15
                                  0 ms
2024-02-29T19:18:54.032Z CNTRLR   Interview completed
2024-02-29T19:18:54.034Z DRIVER   No network key for S0 configured, communication with secure (S0) devices won't
                                   work!
2024-02-29T19:18:54.036Z DRIVER   No network key for S2 configured, communication with secure (S2) devices won't
                                   work!
2024-02-29T19:18:54.037Z DRIVER   driver ready
2024-02-29T19:18:54.051Z DRIVER   Checking for configuration updates...
2024-02-29T19:18:54.317Z CNTRLR   [Node 001] The node is alive.
2024-02-29T19:18:54.421Z CNTRLR   [Node 001] The node is ready to be used
2024-02-29T19:18:54.448Z CNTRLR   Interviewing nodes and/or determining their status: 19, 9, 11, 12, 13, 15, 16,
                                   18, 22, 23, 26, 28, 29, 31, 32, 34, 38, 40, 41
2024-02-29T19:18:54.459Z CNTRLR   [Node 019] Beginning interview - last completed stage: ProtocolInfo
2024-02-29T19:18:54.462Z CNTRLR » [Node 019] pinging the node...
2024-02-29T19:18:55.154Z CNTRLR   [Node 009] The node is asleep.
2024-02-29T19:18:55.163Z CNTRLR   [Node 009] Beginning interview - last completed stage: ProtocolInfo
2024-02-29T19:18:55.168Z CNTRLR » [Node 009] querying node info...
2024-02-29T19:18:55.183Z CNTRLR   [Node 011] Beginning interview - last completed stage: None
2024-02-29T19:18:55.184Z CNTRLR   [Node 011] new node, doing a full interview...
2024-02-29T19:18:55.192Z CNTRLR » [Node 011] querying protocol info...
2024-02-29T19:18:55.210Z CNTRLR   [Node 012] Beginning interview - last completed stage: None
2024-02-29T19:18:55.212Z CNTRLR   [Node 012] new node, doing a full interview...
2024-02-29T19:18:55.220Z CNTRLR » [Node 012] querying protocol info...
2024-02-29T19:18:55.266Z CNTRLR   [Node 013] Beginning interview - last completed stage: None
2024-02-29T19:18:55.268Z CNTRLR   [Node 013] new node, doing a full interview...
2024-02-29T19:18:55.271Z CNTRLR » [Node 013] querying protocol info...
2024-02-29T19:18:55.282Z CNTRLR   [Node 015] Beginning interview - last completed stage: None
2024-02-29T19:18:55.284Z CNTRLR   [Node 015] new node, doing a full interview...
2024-02-29T19:18:55.287Z CNTRLR » [Node 015] querying protocol info...
2024-02-29T19:18:55.298Z CNTRLR   [Node 016] Beginning interview - last completed stage: None
2024-02-29T19:18:55.300Z CNTRLR   [Node 016] new node, doing a full interview...
2024-02-29T19:18:55.303Z CNTRLR » [Node 016] querying protocol info...
2024-02-29T19:18:55.316Z CNTRLR   [Node 018] Beginning interview - last completed stage: None
2024-02-29T19:18:55.317Z CNTRLR   [Node 018] new node, doing a full interview...
2024-02-29T19:18:55.322Z CNTRLR » [Node 018] querying protocol info...
2024-02-29T19:18:55.332Z CNTRLR   [Node 022] Beginning interview - last completed stage: None
2024-02-29T19:18:55.333Z CNTRLR   [Node 022] new node, doing a full interview...
2024-02-29T19:18:55.338Z CNTRLR » [Node 022] querying protocol info...
2024-02-29T19:18:55.348Z CNTRLR   [Node 023] Beginning interview - last completed stage: None
2024-02-29T19:18:55.350Z CNTRLR   [Node 023] new node, doing a full interview...
2024-02-29T19:18:55.353Z CNTRLR » [Node 023] querying protocol info...
2024-02-29T19:18:55.364Z CNTRLR   [Node 026] Beginning interview - last completed stage: None
2024-02-29T19:18:55.365Z CNTRLR   [Node 026] new node, doing a full interview...
2024-02-29T19:18:55.368Z CNTRLR » [Node 026] querying protocol info...
2024-02-29T19:18:55.377Z CNTRLR   [Node 028] Beginning interview - last completed stage: None
2024-02-29T19:18:55.378Z CNTRLR   [Node 028] new node, doing a full interview...
2024-02-29T19:18:55.381Z CNTRLR » [Node 028] querying protocol info...
2024-02-29T19:18:55.391Z CNTRLR   [Node 029] Beginning interview - last completed stage: None
2024-02-29T19:18:55.393Z CNTRLR   [Node 029] new node, doing a full interview...
2024-02-29T19:18:55.395Z CNTRLR » [Node 029] querying protocol info...
2024-02-29T19:18:55.404Z CNTRLR   [Node 031] Beginning interview - last completed stage: None
2024-02-29T19:18:55.406Z CNTRLR   [Node 031] new node, doing a full interview...
2024-02-29T19:18:55.408Z CNTRLR » [Node 031] querying protocol info...
2024-02-29T19:18:55.418Z CNTRLR   [Node 032] Beginning interview - last completed stage: None
2024-02-29T19:18:55.420Z CNTRLR   [Node 032] new node, doing a full interview...
2024-02-29T19:18:55.423Z CNTRLR » [Node 032] querying protocol info...
2024-02-29T19:18:55.431Z CNTRLR   [Node 034] Beginning interview - last completed stage: None
2024-02-29T19:18:55.433Z CNTRLR   [Node 034] new node, doing a full interview...
2024-02-29T19:18:55.435Z CNTRLR » [Node 034] querying protocol info...
2024-02-29T19:18:55.443Z CNTRLR   [Node 038] Beginning interview - last completed stage: None
2024-02-29T19:18:55.445Z CNTRLR   [Node 038] new node, doing a full interview...
2024-02-29T19:18:55.447Z CNTRLR » [Node 038] querying protocol info...
2024-02-29T19:18:55.456Z CNTRLR   [Node 040] Beginning interview - last completed stage: None
2024-02-29T19:18:55.457Z CNTRLR   [Node 040] new node, doing a full interview...
2024-02-29T19:18:55.460Z CNTRLR » [Node 040] querying protocol info...
2024-02-29T19:18:55.468Z CNTRLR   [Node 041] Beginning interview - last completed stage: None
2024-02-29T19:18:55.470Z CNTRLR   [Node 041] new node, doing a full interview...
2024-02-29T19:18:55.473Z CNTRLR » [Node 041] querying protocol info...
2024-02-29T19:18:55.580Z SERIAL » 0x010800131301002501d2                                              (10 bytes)
2024-02-29T19:18:55.586Z DRIVER » [Node 019] [REQ] [SendData]
                                  │ transmit options: 0x25
                                  │ callback id:      1
                                  └─[NoOperationCC]
2024-02-29T19:18:55.740Z SERIAL « [ACK]        (0x06)
2024-02-29T19:18:55.746Z SERIAL « 0x0104011301e8                                                       (6 bytes)
2024-02-29T19:18:55.750Z SERIAL » [ACK]        (0x06)
2024-02-29T19:18:55.818Z DRIVER « [RES] [SendData]
                                    was sent: true
2024-02-29T19:18:55.858Z SERIAL « 0x0107001301000005ef                                                 (9 bytes)
2024-02-29T19:18:55.866Z SERIAL » [ACK]        (0x06)
2024-02-29T19:18:55.876Z DRIVER « [REQ] [SendData]
                                    callback id:     1
                                    transmit status: OK
2024-02-29T19:18:55.904Z CNTRLR   [Node 019] The node is alive.
2024-02-29T19:18:55.914Z CNTRLR « [Node 019] ping successful
2024-02-29T19:18:55.915Z CNTRLR » [Node 019] querying node info...
2024-02-29T19:18:55.947Z SERIAL » 0x010400410bb1                                                       (6 bytes)
2024-02-29T19:18:55.950Z DRIVER » [REQ] [GetNodeProtocolInfo]
                                    payload: 0x0b
2024-02-29T19:19:40.607Z DRIVER   ███████╗        ██╗    ██╗  █████╗  ██╗   ██╗ ███████╗          ██╗ ███████╗
2024-02-29T19:19:40.618Z DRIVER   version 12.4.4
2024-02-29T19:19:40.624Z DRIVER
2024-02-29T19:19:40.628Z DRIVER   starting driver...
2024-02-29T19:19:40.630Z DRIVER   opening serial port /dev/zwave
2024-02-29T19:19:40.909Z DRIVER   serial port opened
2024-02-29T19:19:40.922Z SERIAL » 0x15        (1 bytes)
2024-02-29T19:19:41.006Z SERIAL « 0x010900040009033003ff34                                            (11 bytes)
2024-02-29T19:19:41.051Z DRIVER   Dropping message because the driver is not ready to handle it yet.
2024-02-29T19:19:41.058Z SERIAL » [ACK]        (0x06)
2024-02-29T19:19:41.071Z SERIAL « 0x010900040009032001ff26                                            (11 bytes)
2024-02-29T19:19:41.084Z DRIVER   Dropping message because the driver is not ready to handle it yet.
2024-02-29T19:19:41.087Z SERIAL » [ACK]        (0x06)
2024-02-29T19:19:41.987Z DRIVER   loading configuration...
2024-02-29T19:19:42.035Z CONFIG   Using external configuration dir /usr/src/app/store/.config-db
2024-02-29T19:19:42.038Z CONFIG   version 12.4.4
2024-02-29T19:19:49.089Z DRIVER   beginning interview...
2024-02-29T19:19:49.100Z DRIVER   added request handler for AddNodeToNetwork (0x4a)...
                                  1 registered
2024-02-29T19:19:49.102Z DRIVER   added request handler for RemoveNodeFromNetwork (0x4b)...
                                  1 registered
2024-02-29T19:19:49.103Z DRIVER   added request handler for ReplaceFailedNode (0x63)...
                                  1 registered
2024-02-29T19:19:49.107Z DRIVER   added request handler for SerialAPIStarted (0x0a)...
                                  1 registered
2024-02-29T19:19:49.115Z CNTRLR   querying Serial API capabilities...
2024-02-29T19:19:51.158Z SERIAL » 0x01030007fb                                                         (5 bytes)
2024-02-29T19:19:51.169Z DRIVER » [REQ] [GetSerialApiCapabilities]
2024-02-29T19:19:51.208Z SERIAL « [ACK]        (0x06)
2024-02-29T19:19:51.223Z SERIAL « 0x012b0107010000860001005afe81ff884f1f0000fb9f7da067000080008086000 (45 bytes)
2024-02-29T19:19:51.233Z SERIAL » [ACK]        (0x06)
2024-02-29T19:19:51.243Z DRIVER « [RES] [GetSerialApiCapabilities]
                                  0000e0000600000
2024-02-29T19:19:51.291Z CNTRLR   received API capabilities:
                                    product type:        0x01
                                    product ID:          0x5a
                                    · SoftReset (0x08)
                                    · SendData (0x13)
                                    · GetNVMId (0x29)
                                    · HardReset (0x42)
                                    · undefined (0xee)
2024-02-29T19:19:51.294Z CNTRLR   querying version info...
2024-02-29T19:19:51.339Z SERIAL » 0x01030015e9                                                         (5 bytes)
2024-02-29T19:19:51.342Z DRIVER » [REQ] [GetControllerVersion]
2024-02-29T19:19:51.407Z SERIAL « [ACK]        (0x06)
2024-02-29T19:19:51.444Z SERIAL « 0x011001155a2d5761766520332e3935000199                              (18 bytes)
2024-02-29T19:19:51.451Z SERIAL » [ACK]        (0x06)
2024-02-29T19:19:51.471Z DRIVER « [RES] [GetControllerVersion]
2024-02-29T19:19:51.506Z CNTRLR   received version info:
2024-02-29T19:19:51.519Z CNTRLR   querying protocol version info...
2024-02-29T19:19:51.610Z SERIAL » 0x01030009f5                                                         (5 bytes)
2024-02-29T19:19:51.616Z DRIVER » [REQ] [GetProtocolVersion]
2024-02-29T19:19:51.636Z SERIAL « [ACK]        (0x06)
2024-02-29T19:19:51.648Z SERIAL « 0x0107010900035f00ac                                                 (9 bytes)
2024-02-29T19:19:51.654Z SERIAL » [ACK]        (0x06)
2024-02-29T19:19:51.662Z DRIVER « [RES] [GetProtocolVersion]
                                    payload: 0x00035f00
2024-02-29T19:19:51.681Z CNTRLR   received protocol version info:
2024-02-29T19:19:51.685Z CNTRLR   querying controller IDs...
2024-02-29T19:19:51.772Z SERIAL » 0x01030020dc                                                         (5 bytes)
2024-02-29T19:19:51.778Z DRIVER » [REQ] [GetControllerId]
2024-02-29T19:19:51.795Z SERIAL « [ACK]        (0x06)
2024-02-29T19:19:51.806Z SERIAL « 0x01080120fdd0547b01d5                                              (10 bytes)
2024-02-29T19:19:51.813Z SERIAL » [ACK]        (0x06)
2024-02-29T19:19:51.821Z DRIVER « [RES] [GetControllerId]
                                    home ID:     0xfdd0547b
                                    own node ID: 1
2024-02-29T19:19:51.841Z CNTRLR   received controller IDs:
                                    home ID:     0xfdd0547b
                                    own node ID: 1
2024-02-29T19:19:51.856Z DRIVER   all queues idle
2024-02-29T19:19:51.960Z CNTRLR   Performing soft reset...
2024-02-29T19:19:51.970Z DRIVER   all queues busy
2024-02-29T19:19:51.986Z SERIAL » 0x01030008f4                                                         (5 bytes)
2024-02-29T19:19:51.989Z DRIVER » [REQ] [SoftReset]
2024-02-29T19:19:52.004Z SERIAL « [ACK]        (0x06)
2024-02-29T19:19:52.021Z CNTRLR   Waiting for the controller to reconnect...
2024-02-29T19:19:52.027Z DRIVER   all queues idle
2024-02-29T19:19:53.527Z CNTRLR   Re-opening serial port...
2024-02-29T19:19:54.554Z CNTRLR   Waiting for the Serial API to start...
2024-02-29T19:19:59.558Z CNTRLR   Did not receive notification that Serial API has started, checking if it respo
                                  nds...
2024-02-29T19:19:59.571Z DRIVER   all queues busy
2024-02-29T19:19:59.585Z SERIAL » 0x01030015e9                                                         (5 bytes)
2024-02-29T19:19:59.592Z DRIVER » [REQ] [GetControllerVersion]
2024-02-29T19:19:59.604Z SERIAL « [ACK]        (0x06)
2024-02-29T19:19:59.610Z SERIAL « 0x011001155a2d5761766520332e3935000199                              (18 bytes)
2024-02-29T19:19:59.613Z SERIAL » [ACK]        (0x06)
2024-02-29T19:19:59.620Z DRIVER « [RES] [GetControllerVersion]
2024-02-29T19:19:59.632Z CNTRLR   Serial API responded
2024-02-29T19:19:59.638Z DRIVER   all queues idle
2024-02-29T19:19:59.709Z CNTRLR   supported Z-Wave features:
2024-02-29T19:19:59.710Z CNTRLR   querying controller capabilities...
2024-02-29T19:19:59.721Z DRIVER   all queues busy
2024-02-29T19:19:59.740Z SERIAL » 0x01030005f9                                                         (5 bytes)
2024-02-29T19:19:59.744Z DRIVER » [REQ] [GetControllerCapabilities]
2024-02-29T19:19:59.757Z SERIAL « [ACK]        (0x06)
2024-02-29T19:19:59.763Z SERIAL « 0x010401051ce3                                                       (6 bytes)
2024-02-29T19:19:59.768Z SERIAL » [ACK]        (0x06)
2024-02-29T19:19:59.774Z DRIVER « [RES] [GetControllerCapabilities]
                                    payload: 0x1c
2024-02-29T19:19:59.791Z CNTRLR   received controller capabilities:
                                    is the SUC:           true
2024-02-29T19:19:59.793Z CNTRLR   finding SUC...
2024-02-29T19:19:59.815Z SERIAL » 0x01030056aa                                                         (5 bytes)
2024-02-29T19:19:59.819Z DRIVER » [REQ] [GetSUCNodeId]
2024-02-29T19:19:59.830Z SERIAL « [ACK]        (0x06)
2024-02-29T19:19:59.836Z SERIAL « 0x0104015601ad                                                       (6 bytes)
2024-02-29T19:19:59.840Z SERIAL » [ACK]        (0x06)
2024-02-29T19:19:59.845Z DRIVER « [RES] [GetSUCNodeId]
                                    payload: 0x01
2024-02-29T19:19:59.860Z CNTRLR   This is the SUC
2024-02-29T19:19:59.862Z CNTRLR   querying additional controller information...
2024-02-29T19:19:59.893Z SERIAL » 0x01030002fe                                                         (5 bytes)
2024-02-29T19:19:59.898Z DRIVER » [REQ] [GetSerialApiInitData]
2024-02-29T19:19:59.909Z SERIAL « [ACK]        (0x06)
2024-02-29T19:19:59.994Z SERIAL « 0x0125010205081d01dd66daa201000000000000000000000000000000000000000 (39 bytes)
                                  000000005000f
2024-02-29T19:20:00.001Z SERIAL » [ACK]        (0x06)
2024-02-29T19:20:00.006Z DRIVER « [RES] [GetSerialApiInitData]
                                  500
2024-02-29T19:20:00.021Z CNTRLR   received additional controller information:
2024-02-29T19:20:00.378Z DRIVER   Cache file for homeId 0xfdd0547b found, attempting to restore the network from
                                   cache...
2024-02-29T19:20:00.440Z DRIVER   all queues idle
2024-02-29T19:20:01.359Z CNTRLR   [Node 001] Embedded device config loaded
2024-02-29T19:20:01.387Z DRIVER   Restoring the network from cache was successful!
2024-02-29T19:20:01.417Z CNTRLR   [Node 001] [Manufacturer Specific] manufacturerId: metadata updated
2024-02-29T19:20:01.424Z CNTRLR   [Node 001] [Manufacturer Specific] productType: metadata updated
2024-02-29T19:20:01.428Z CNTRLR   [Node 001] [Manufacturer Specific] productId: metadata updated
2024-02-29T19:20:01.436Z CNTRLR   [Node 001] [~] [Manufacturer Specific] manufacturerId: 134 => 134
2024-02-29T19:20:01.445Z CNTRLR   [Node 001] [~] [Manufacturer Specific] productType: 1 => 1
2024-02-29T19:20:01.450Z CNTRLR   [Node 001] [~] [Manufacturer Specific] productId: 90 => 90
2024-02-29T19:20:01.455Z CNTRLR   [Node 001] [Version] firmwareVersions: metadata updated
2024-02-29T19:20:01.459Z CNTRLR   [Node 001] [~] [Version] firmwareVersions: 1.0 => 1.0
2024-02-29T19:20:01.467Z CNTRLR   [Node 001] [Version] zWaveProtocolVersion: metadata updated
2024-02-29T19:20:01.471Z CNTRLR   [Node 001] [~] [Version] zWaveProtocolVersion: "3.95.0" => "3.95.0"
2024-02-29T19:20:01.474Z CNTRLR   [Node 001] [Version] sdkVersion: metadata updated
2024-02-29T19:20:01.477Z CNTRLR   [Node 001] [~] [Version] sdkVersion: "6.51.2" => "6.51.2"
2024-02-29T19:20:01.479Z CNTRLR   setting serial API timeouts: ack = 1000 ms, byte = 150 ms
2024-02-29T19:20:01.489Z DRIVER   all queues busy
2024-02-29T19:20:01.505Z SERIAL » 0x01050006640f97                                                     (7 bytes)
2024-02-29T19:20:01.511Z DRIVER » [REQ] [SetSerialApiTimeouts]
                                    payload: 0x640f
2024-02-29T19:20:01.544Z SERIAL « [ACK]        (0x06)
2024-02-29T19:20:01.550Z SERIAL « 0x01050106960f64                                                     (7 bytes)
2024-02-29T19:20:01.554Z SERIAL » [ACK]        (0x06)
2024-02-29T19:20:01.560Z DRIVER « [RES] [SetSerialApiTimeouts]
                                    payload: 0x960f
2024-02-29T19:20:01.575Z CNTRLR   serial API timeouts overwritten. The old values were: ack = 1500 ms, byte = 15
                                  0 ms
2024-02-29T19:20:01.576Z CNTRLR   Interview completed
2024-02-29T19:20:01.578Z DRIVER   No network key for S0 configured, communication with secure (S0) devices won't
                                   work!
2024-02-29T19:20:01.580Z DRIVER   No network key for S2 configured, communication with secure (S2) devices won't
                                   work!
2024-02-29T19:20:01.581Z DRIVER   driver ready
2024-02-29T19:20:01.595Z DRIVER   Checking for configuration updates...
2024-02-29T19:20:01.828Z CNTRLR   [Node 001] The node is alive.
2024-02-29T19:20:01.906Z CNTRLR   [Node 001] The node is ready to be used
2024-02-29T19:20:01.919Z CNTRLR   Interviewing nodes and/or determining their status: 19, 9, 11, 12, 13, 15, 16,
2024-02-29T19:20:01.931Z CNTRLR   [Node 019] Beginning interview - last completed stage: ProtocolInfo
2024-02-29T19:20:01.934Z CNTRLR » [Node 019] pinging the node...
2024-02-29T19:20:02.585Z CNTRLR   [Node 009] The node is asleep.
2024-02-29T19:20:02.594Z CNTRLR   [Node 009] Beginning interview - last completed stage: ProtocolInfo
2024-02-29T19:20:02.599Z CNTRLR » [Node 009] querying node info...
2024-02-29T19:20:02.612Z CNTRLR   [Node 011] Beginning interview - last completed stage: None
2024-02-29T19:20:02.614Z CNTRLR   [Node 011] new node, doing a full interview...
2024-02-29T19:20:02.620Z CNTRLR » [Node 011] querying protocol info...
2024-02-29T19:20:02.634Z CNTRLR   [Node 012] Beginning interview - last completed stage: None
2024-02-29T19:20:02.636Z CNTRLR   [Node 012] new node, doing a full interview...
2024-02-29T19:20:02.640Z CNTRLR » [Node 012] querying protocol info...
2024-02-29T19:20:02.654Z CNTRLR   [Node 013] Beginning interview - last completed stage: None
2024-02-29T19:20:02.655Z CNTRLR   [Node 013] new node, doing a full interview...
2024-02-29T19:20:02.659Z CNTRLR » [Node 013] querying protocol info...
2024-02-29T19:20:02.696Z CNTRLR   [Node 015] Beginning interview - last completed stage: None
2024-02-29T19:20:02.697Z CNTRLR   [Node 015] new node, doing a full interview...
2024-02-29T19:20:02.701Z CNTRLR » [Node 015] querying protocol info...
2024-02-29T19:20:02.711Z CNTRLR   [Node 016] Beginning interview - last completed stage: None
2024-02-29T19:20:02.713Z CNTRLR   [Node 016] new node, doing a full interview...
2024-02-29T19:20:02.716Z CNTRLR » [Node 016] querying protocol info...
2024-02-29T19:20:02.727Z CNTRLR   [Node 018] Beginning interview - last completed stage: None
2024-02-29T19:20:02.728Z CNTRLR   [Node 018] new node, doing a full interview...
2024-02-29T19:20:02.734Z CNTRLR » [Node 018] querying protocol info...
2024-02-29T19:20:02.746Z CNTRLR   [Node 022] Beginning interview - last completed stage: None
2024-02-29T19:20:02.748Z CNTRLR   [Node 022] new node, doing a full interview...
2024-02-29T19:20:02.754Z CNTRLR » [Node 022] querying protocol info...
2024-02-29T19:20:02.767Z CNTRLR   [Node 023] Beginning interview - last completed stage: None
2024-02-29T19:20:02.769Z CNTRLR   [Node 023] new node, doing a full interview...
2024-02-29T19:20:02.773Z CNTRLR » [Node 023] querying protocol info...
2024-02-29T19:20:02.783Z CNTRLR   [Node 026] Beginning interview - last completed stage: None
2024-02-29T19:20:02.784Z CNTRLR   [Node 026] new node, doing a full interview...
2024-02-29T19:20:02.787Z CNTRLR » [Node 026] querying protocol info...
2024-02-29T19:20:02.797Z CNTRLR   [Node 028] Beginning interview - last completed stage: None
2024-02-29T19:20:02.798Z CNTRLR   [Node 028] new node, doing a full interview...
2024-02-29T19:20:02.801Z CNTRLR » [Node 028] querying protocol info...
2024-02-29T19:20:02.813Z CNTRLR   [Node 029] Beginning interview - last completed stage: None
2024-02-29T19:20:02.814Z CNTRLR   [Node 029] new node, doing a full interview...
2024-02-29T19:20:02.817Z CNTRLR » [Node 029] querying protocol info...
2024-02-29T19:20:02.828Z CNTRLR   [Node 031] Beginning interview - last completed stage: None
2024-02-29T19:20:02.830Z CNTRLR   [Node 031] new node, doing a full interview...
2024-02-29T19:20:02.833Z CNTRLR » [Node 031] querying protocol info...
2024-02-29T19:20:02.843Z CNTRLR   [Node 032] Beginning interview - last completed stage: None
2024-02-29T19:20:02.844Z CNTRLR   [Node 032] new node, doing a full interview...
2024-02-29T19:20:02.847Z CNTRLR » [Node 032] querying protocol info...
2024-02-29T19:20:02.857Z CNTRLR   [Node 034] Beginning interview - last completed stage: None
2024-02-29T19:20:02.858Z CNTRLR   [Node 034] new node, doing a full interview...
2024-02-29T19:20:02.861Z CNTRLR » [Node 034] querying protocol info...
2024-02-29T19:20:02.872Z CNTRLR   [Node 038] Beginning interview - last completed stage: None
2024-02-29T19:20:02.874Z CNTRLR   [Node 038] new node, doing a full interview...
2024-02-29T19:20:02.877Z CNTRLR » [Node 038] querying protocol info...
2024-02-29T19:20:02.889Z CNTRLR   [Node 040] Beginning interview - last completed stage: None
2024-02-29T19:20:02.891Z CNTRLR   [Node 040] new node, doing a full interview...
2024-02-29T19:20:02.895Z CNTRLR » [Node 040] querying protocol info...
2024-02-29T19:20:02.907Z CNTRLR   [Node 041] Beginning interview - last completed stage: None
2024-02-29T19:20:02.909Z CNTRLR   [Node 041] new node, doing a full interview...
2024-02-29T19:20:02.912Z CNTRLR » [Node 041] querying protocol info...
2024-02-29T19:20:03.006Z SERIAL » 0x010800131301002501d2                                              (10 bytes)
2024-02-29T19:20:03.020Z DRIVER » [Node 019] [REQ] [SendData]
                                  │ callback id:      1
                                  └─[NoOperationCC]
2024-02-29T19:20:03.189Z SERIAL « [ACK]        (0x06)
2024-02-29T19:20:03.195Z SERIAL « 0x0104011301e8                                                       (6 bytes)
2024-02-29T19:20:03.199Z SERIAL » [ACK]        (0x06)
2024-02-29T19:20:03.263Z DRIVER « [RES] [SendData]
                                    was sent: true
2024-02-29T19:20:03.309Z SERIAL « 0x0107001301000005ef                                                 (9 bytes)
2024-02-29T19:20:03.315Z SERIAL » [ACK]        (0x06)
2024-02-29T19:20:03.326Z DRIVER « [REQ] [SendData]
                                    callback id:     1
                                    transmit status: OK
2024-02-29T19:20:03.353Z CNTRLR   [Node 019] The node is alive.
2024-02-29T19:20:03.362Z CNTRLR « [Node 019] ping successful
2024-02-29T19:20:03.363Z CNTRLR » [Node 019] querying node info...
2024-02-29T19:20:03.393Z SERIAL » 0x010400410bb1                                                       (6 bytes)
2024-02-29T19:20:03.396Z DRIVER » [REQ] [GetNodeProtocolInfo]
                                    payload: 0x0b
2024-02-29T19:20:04.233Z SERIAL « [ACK]        (0x06)
2024-02-29T19:20:04.280Z SERIAL « 0x01090141529c000420015d                                            (11 bytes)
2024-02-29T19:20:04.330Z SERIAL » [ACK]
Raspberry Pi 2
Raspbian Bookworm
RFXCOM USB
Domoticz 2024.2
Again, please discuss this issue with the Zwave-JS-UI specialists in their GitHub repository.
mgugu
Post by mgugu »
I would try a clean install, either in a new folder (only yml file in it) or by deleting the 'store' folder. Here is my working yml:
version: '3.7'
services:
  zwave-js-ui:
    restart: always
    tty: true
    stop_signal: SIGINT
    environment:
      - SESSION_SECRET=mysupersecretkey
      - TZ=<zone>
    networks:
      - zwave
    devices:
      - /dev/serial/by-id/usb-0658_0200-if00:/dev/ttyACM0
    volumes:
    ports:
      - '8091:8091' # port for web interface
      - '3100:3000' # port for zwave-js websocket server
networks:
  zwave:
    external: true
hvoorend
Post by hvoorend »
Thanks waltervl and mgugu. Already did a clean install as my attempt upgrade Raspbian to Bookworm ruined my Pi-OS. Results after clean install
Were exactly alike. Will aks the Zwave-JS-UI specialists in their GitHub repository.
Raspberry Pi 2
Raspbian Bookworm
RFXCOM USB
Domoticz 2024.2
