Another zwave-ui problem (SOLVED) Topic is solved
capady
Post by capady »
I'm trying to install z-wave-ui with docking and mqtt for more then 3 weeks without an acceptable result.
When I call the zwave-ui page I can make settings but the page is showing an error "Driver: failed to open serial port Error: no such file or directory, cannot open /dev/zwave (zw0100)"
I've read a real lot of internet pages but can't found a solution to solve this.
At one place on the internet I saw this should be a permission problem but I cann't find this page again so also no solution :)
On the other hand, "/dev/zwave (zw0100" is not a known adress for me either
Domoticz version: 2026.3
Re: Another zwave-ui problem
Can you share your docker-compose.yml file or at least the devices section as mentioned here:
https://www.domoticz.com/wiki/Zwave-JS- ... ZWaveJS-UI
Devices section should look something like.
devices:
      - '/dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0001-if00-port0:/dev/zwave'
Also check the USB name on your system with
ls /dev/serial/by-id
You should see one or multiple serial devices, find out which one is your ZWave stick, for example it's:
capady
Post by capady »
I am not very well known with this so sometimes I need some more time.
I Think you want to see this :
ls /dev/serial/by-id result:
usb-0658_0200-if00 usb-FTDI_FT232R_USB_UART_A13LYBV4-if00-port0
http://www.capady.nl/tmp/Scherm_1.png
Schermafbeelding 2024-02-16 141128.png (33.42 KiB) Viewed 1225 times
Yes, looks ok if the output of
gives the same output for the USB device you are using.
Do you have more USB devices attached to your system? Are you sure this device is your USB Zwave-stick?
What kind of zwave controller do you have?
capady
Post by capady »
Zwave stick is gen5, about 2,5 years old.
Led on it is blinking red-green-blue continiously
Another USB is used for P1-energie measuring
You edited your post. I see that ls /dev/serial/by-id gives 2 results:
usb-0658_0200-if00
Which one is the Zwave Stick?
Googling for both let me think usb-0658_0200-if00 is the Zwave stick so that should be used in the docker-compose.yml
capady
Post by capady »
I hadn't even noted there where 2 USB's :(
But I have still the same problem
No idea what happens but images are not shown
I see your images. Did you restart the docker container after the change?
capady
Post by capady »
I noticed an zero to many in the config file. (_if000 instead of _if00)
I've removed that zero and reboot the raspberry, I suppose docker will be restarted then also
capady
Re: Another zwave-ui problem (solved)
Post by capady »
After editing some parameters at MQTT it is up and running without errors.
Thank you very much :mrgreen:
