re-index database domoticz
Subforum for general discussions. Do not dump your questions/problems here, but try to find the subforum where it belongs!
pierrotori
Domoticz version: 2024.4
Post by pierrotori »
i realized more test with zwave-js-ui and create a lot of device in domoticz and i removed the device
my question is , i created a lot of index and is it possible to re-index the device counter in the database ?
Pierre
rpi : Raspberry Pi 2 Model B Rev 1.1 / Modele : Cortex-A7 armv7l GNU/Linux / Os Name : bullseye
Docker/Domoticz/zwave-ui/homebridge/mosquitto/wireguard
psubiaco
Re: re-index database domoticz
Post by psubiaco »
What do you mean?
Do you want to reset a counter value (energy/gas/water meter) and restart from zero or from another value to avoid a discontinuity in the graph/chart?
Paolo
Domoticz version: 2024.7
I think @pierrotori is referring to the device IDX running high due to making and deleting a lot of devices.
There is no need to worry about it. That IDX value can be very big and there is no need to start that IDX number counter from 0 or fill the gaps.
pierrotori
great, thank you
jesse628wallick
Post by jesse628wallick »
The IDX is a unique identifier assigned to each device in Domoticz.
When you create and delete devices, IDXs may increase without being reused.
However, there is usually no need to reindex devices, as Domoticz handles high IDX values ​​automatically.
IDX values ​​can get very large without problem.
There is no need to reset the IDX counter from 0 or fill in the gaps.
Domoticz will continue to work correctly even with high IDX values.MaximTimeClock
Last edited by jesse628wallick on Saturday 13 April 2024 6:33, edited 1 time in total.
jesse628wallick wrote: Friday 12 April 2024 8:54 L’IDX est un identifiant .....
Pleas modify your post to English....
