Anyone have Domoticz running on a pi 5? I have tried but no joy. 2024-four seams to install ok on raspios-bookworm lite, no errors but can not connect on port 8080 or 443
Thanks.
Raspberry pi 5
- Domoticz version: 2026.3
Re: Raspberry pi 5
On Bookworm it is best to use the Docker install due to the OpenSSL3 library issue (for https 443 access).
https://www.domoticz.com/wiki/Docker
akamming
Re: Raspberry pi 5
i am also running on bookworm, no issues with openssl3. Have no issues on https/port 443
(although i have a pi4b, not a pi5)
joetuttle
- Domoticz version: 2024.4
Re: Raspberry pi 5
I am running remote headless, guess I will have to stick with my pi4b untill domoticz has a fix.waltervl wrote: Friday 09 February 2024 10:00 On Bookworm it is best to use the Docker install due to the OpenSSL3 library issue (for https 443 access).
thanks for the reply.
Re: Raspberry pi 5
what has remote headless have to do with this? tou can do everything from the command linejoetuttle wrote: Friday 09 February 2024 13:54I am running remote headless, guess I will have to stick with my pi4b untill domoticz has a fix.waltervl wrote: Friday 09 February 2024 10:00 On Bookworm it is best to use the Docker install due to the OpenSSL3 library issue (for https 443 access).
joetuttle
Re: Raspberry pi 5
I got the impression that docker needs a os with a desktop to install I am using raspberry bookworm lite. I will go back and revisit docker. Thanks.waltervl wrote: Friday 09 February 2024 13:57what has remote headless have to do with this? tou can do everything from the command linejoetuttle wrote: Friday 09 February 2024 13:54I am running remote headless, guess I will have to stick with my pi4b untill domoticz has a fix.waltervl wrote: Friday 09 February 2024 10:00 On Bookworm it is best to use the Docker install due to the OpenSSL3 library issue (for https 443 access).
joetuttle
Re: Raspberry pi 5
The pi5 requires bookworm It will not boot with bullseye or buster.akamming wrote: Friday 09 February 2024 10:13 i am also running on bookworm, no issues with openssl3. Have no issues on https/port 443
