Zwave-JS-UI AND MQTT
BartSr
Domoticz version: V2024.7
Post by BartSr »
I managed to get the zwave-js-ui up and running in a test-environment. In my production system mosquitto is working fine.
Q: once I install Zwave-JS-ui as per Wiki instructions in mg production environment I do have 2 Brokers. That is how it must be? Is the 2nd one running in a separate docker? And what if I install as per Wiki Zigbee 2 MQTT? Again another Broker there?
Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Domoticz version: 2026.3
Re: Zwave-JS-UI AND MQTT
You only need 1 mqtt broker in your network. It will communicate with Domoticz and Zwave-JS-UI and Zigbee2MQTT
BartSr
Post by BartSr »
Thanks Walter.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
