Any IOS app that works with 2024 version?
nlovrens
Post by nlovrens »
I can't find any IOS app that works correctly with recent releases of domoticz. I have a paid version of Pilot, setpoints are no longer working. There is no response from the developer any more, I see that others have the same experience with Pilot support. Domoticz app won't even connect to the server any more and it has not been updated for three years. Is there any other app/solution for IOS devices? I just hope that I don't have to switch to the horrible home assistant...
thank you
Domoticz version: 2024.7
Re: Any IOS app that works with 2024 version?
Why you need an app when the webui is as good? And it is Opensource so feel free to create your own version.
Or switch over to HA. All your troubles will disappear... :-)
akamming
Post by akamming »
For IOS you can use homekit by installing homebridge and use the edomoticz plug-in
Homebridge install instruction are describe Here: https://github.com/homebridge/homebridg ... n-Raspbian
Edimoticz plug-in can be found here: https://github.com/PatchworkBoy/homebridge-edomoticz
It is a bit of work, but then you can use the Apple home app and Siri to control domoticz which is much better than the webui or the domoticz app
nlovrens
Post by nlovrens »
I have tried homebridge couple of years ago, but it was working only on LAN, unless you have some apple device (TV or something like that) which acts as a hub. Am I right?
So far, web gui as a shortcut on IOS seems to be only working option...
madpatrick
Domoticz version: 2025.1
Post by madpatrick »
akamming wrote: Sunday 04 February 2024 11:15 For IOS you can use homekit by installing homebridge and use the edomoticz plug-in
Great. I'll try this also
I see that homebridge-edomoticz last update was 2 years ago.
Is this plugin this maintained ?
-= HP server GEN11 =- OZW -=- Toon2 (rooted) -=- Domoticz v2025.1 -=- Dashticz v3.14b on Tab8" =-
akamming
Post by akamming »
nlovrens wrote: Sunday 04 February 2024 13:57 I have tried homebridge couple of years ago, but it was working only on LAN, unless you have some apple device (TV or something like that) which acts as a hub. Am I right?
That’s correct. HomeKit Only works outside the home lan if you enable either an appletv or HomePod as hub
lost
Post by lost »
akamming wrote: Sunday 04 February 2024 11:15 It is a bit of work...
It's also a bit of work to setup a free dns (no-ip...) & certificate (let's encrypt) but after this any device with any standard web browser does the job. No need for any dumbphone app, that's magic & just works not needing any third party mess since years, believe me! :D
When there is some work to make things just work: Go ahead with something standard is my advice.
akamming
Post by akamming »
lost wrote: Sunday 04 February 2024 21:03
But then you miss features like Siri integration. Very Nice to just say “hey Siri goodmorning” to my phone and have the heating and lights switched on. That’s impossible with a web app
lost
Post by lost »
akamming wrote: Sunday 04 February 2024 21:20 But then you miss features like Siri integration...
Sure, did not even think about this use case as I'm really too suspicious to setup anything needing an always-on microphone in my home, being a physical device or a smartphone app... Dumbphones are even forbidden upstairs where the bedrooms are and that's common rule, so not only targeting my childs for obvious reasons (always easiest to ask for what you abide yourself anyway).
