How does dzvents handle a reptitive switch command
Tukker
Domoticz version: 2023.2
Post by Tukker »
Just out of curiosity.
How does dzvents handle reptitive calls, let's say every 10 minutes.
In the following code the 'if' will be handled 6 times.
Will there be a six (twelve) times switch command in memory or will the timed switch commands be overwritten every 10 minutes.
            if (current_time > '23:00') then
              domoticz.devices('myswitch').switchOn('at 23:01')
              domoticz.devices('myswitch').switchOff('at 06:59')
I know, the correct code should be:
            if (current_time == '23:00') then
Nevertheless there is this curiosity.
Bugs bug me.
willemd
Domoticz version: 2026.3
Re: How does dzvents handle a reptitive switch command
Post by willemd »
Not an answer to your curiosity I know, but I would test for the status of the switch before sending the switch commands. Then you are sure the command is only issued once, whether you use > or ==
