Return to 2023.2
pkelderman
- Domoticz version: 2024.4
Return to 2023.2
Is there a good description for a return from 2024.2/2024.1 to 2023.2? I have to many problems in 2024.1 (Aeotec Stick gen5 and communication with other domoticz servers).
- Domoticz version: 2026.3
Re: Return to 2023.2
Better invest in getting Zwave-JS-UI running. Looking at this topic viewtopic.php?t=41257 you have issues with the USB connection. Look into that as it would have the same issue with OpenZwave.
pkelderman
The instruction "ls /dev/serial/by-id" does not give me the information about my z-wave plus z-stick. So it ended there.
For that reason i'm waiting for a correct instruction about the use off a z-stick on a raspberry 3b. And as far as I can see, I'm not the only one.
You can also use ttyUSBx or ttyACMx or similar but not having by-id is an operating system issue. If using tty you could end up with a non responding USB as the USB link has changed after a reboot.
See wiki https://www.domoticz.com/wiki/PersistentUSBDevices
willemd
You can always compile from scratch. A recent thread can be found using a search.pkelderman wrote: Tuesday 23 January 2024 14:41 Is there a good description for a return from 2024.2/2024.1 to 2023.2? I have to many problems in 2024.1 (Aeotec Stick gen5 and communication with other domoticz servers).
After that, reinstall your backup database.
- gizmocuz
Het yourself a usb zwave stick or update to 2024.3 where OZW has returned
pkelderman
What is "OZW"?
FlyingDomotic
- Domoticz version: 2020.2
OpenZWave?
pkelderman
