json for version or other command
Subforum for general discussions. Do not dump your questions/problems here, but try to find the subforum where it belongs!
pierrotori
Domoticz version: 2024.4
Re: json for version or other command
Post by pierrotori »
it's exactly that i search
is your process web-scraping is a node-red flow ?
rpi : Raspberry Pi 2 Model B Rev 1.1 / Modele : Cortex-A7 armv7l GNU/Linux / Os Name : bullseye
Docker/Domoticz/zwave-ui/homebridge/mosquitto/wireguard
Domoticz version: 2024.7
Why scraping??? Why not use whatchtower or diun as suggested earlier?
pierrotori
because i prefer to use only the container to manage the functionality of the smart home, not to manage the system, or exploitation
i prefer in this case use the script shell or dzvents
today, i have a different container for domoticz/mosquito/homebridge/zwave-js-ui/fail2ban/wireguard
i could to use watchtower, portainer, etc but i add a constraint when i upgrade all the containers. i prefer a script shell , it's a sure value and i prefer also to concentrate the times only on the home automation scenario
You can also run a daily or weekly Cron just to pull the latest beta.
FireWizard
Post by FireWizard »
Hello @pierrotori,
You asked:
Yes, it is.
If you can tell me which version (stable/beta) and platform you need, I can send you a working flow for your version.
It is not up to me, to decide for others, what is the best method to get the desired data.
I have this flow available and if someone want to use it, I'm happy to share.
@waltervl
You commented:
These programs seems to be Docker related. I do not use them and I'm not familiar with them, because I do not use Docker.
Perhaps they are better than web scraping, but, as said, that is for Docker users to decide.
lost
Post by lost »
FireWizard wrote: Friday 19 January 2024 16:28
Yes, it is.
Sound a bit complex considering the information present in waltervi API call suggestion?
You get:
	"DomoticzUpdateURL" : "https://www.domoticz.com/download.php?channel=stable&type=release&system=linux&machine=aarch64",
	"HaveUpdate" : false,
	"Revision" : 15854,
	"SystemName" : "linux",
	"UseUpdate" : true,
	"build_time" : "2024-01-05 12:51:42",
	"dzvents_version" : "3.1.8",
	"hash" : "30067cce8",
	"python_version" : "None",
	"status" : "OK",
	"title" : "GetVersion",
	"version" : "2024.1 (build 15805)"
=> So you know you're on build 15805 and there is a 15854 available.
Maybe I miss something, but web scrapping the page may not be needed? That's really something to do when there is no other choice (because no API to get required info): Changes in page structure may need code change etc...
Did this (using python and BeautifulSoup module, as this was for something done in python) for my fixed phone spammers filtering service, to get some score/rank classification for incoming callers from web sites like shouldianswer or tellows... but that's because I did not found another free way (i.e. they provides API but you need to pay for access) for my own personal use!
FireWizard
Hello @lost.
You are correct, it is relative complex, as an URL is available. I made this once, a while ago, in order to show someone, how to do web scraping in Node-RED. I demonstrated it with the Domoticz web page and that is the reason I have it available.
Last edited by FireWizard on Friday 19 January 2024 21:25, edited 1 time in total.
pierrotori
i scrapped the html page
{"domoticz":"version"
{"mode":"release","os":"linux","bits":"armv7l.tgz","numero":"2024.2.15854","date":"2024-01-16","size":"14,36 MB"}
{"mode":"release","os":"linux","bits":"aarch64.tgz","numero":"2024.2.15854","date":"2024-01-16","size":"14,89 MB"}
{"mode":"release","os":"windows","bits":"x86.zip","numero":"2024.2.15854","date":"2024-01-15","size":"13,56 MB"}
{"mode":"release","os":"linux","bits":"x86","numero":"2024.2.15854","date":"2024-01-16","size":"15,72 MB"}
{"mode":"beta","os":"linux","bits":"armv7l.tgz","numero":"2024.2.15864","date":"2024-01-18","size":"14,35 MB"}
{"mode":"beta","os":"linux","bits":"aarch64.tgz","numero":"2024.2.15864","date":"2024-01-18","size":"14,04 MB"}
{"mode":"beta","os":"windows","bits":"x86.zip","numero":"2024.2.15865","date":"2024-01-18","size":"13,48 MB"}
{"mode":"beta","os":"linux","bits":"x86","numero":"2024.2.15864","date":"2024-01-18","size":"15,72 MB"}
now i can compare my version a the last version and push a alert when the new version is arrived
i can check with a script shell with json with jq or dzvents with json data
@FireWizard i have node-red but it's not in my domoticz container
