I try to follow the wiki:
https://www.domoticz.com/wiki/NestDeveloperApiKey
It looks like ther's something changed with google. The link:
https://console.developers.nest.com/nl/auth/new doesn't work.
I also see nowhere a link to create new OAuth Client to get Oautpin.
Do I something wrong or is there something changed?
By the way, I do have my nest running under home bridge. So I do have an apikey, issue token and cookie. But in domoticz other things are asked to be entered....
Nest integration
remko2000
Re: Nest integration
Anyone a suggestion?
- boum
- Domoticz version: 4.10717
I think Nest API stopped to work a few years ago when it was bought by Google. If there is a new API, nobody did port it to the domoticz plugin.
remko2000
I tried this:
https://github.com/FilipDem/Domoticz-NE ... ree/master
One device is added in domoticz 'nest - away' but I can't switch it.
In my log I get:
2024-01-19 16:26:08.594 Error: Nest: > General error TaskHandler: 'Away'
This isn't working I think.
In my log I get:
- Domoticz version: 2026.3
As this repository is updated only 3 weeks ago it should work. Perhaps make an issue or read through the closed issues to see if someone had the same issue as you.remko2000 wrote: Friday 19 January 2024 16:28 I tried this:
In my log I get:
Do you see something special in the Domoticz log when you restart the plugin (select plugin hardware gateway and click on update)
remko2000
If I update the plugin and use the whole issuetoken including ' home.nest.com&include_granted_scopes=true&auto=1' in the end the log of domoticz says:
'Error: Nest: Hardware setting issue_token must end with nest.com.'
After entering I also have to reset my raspberry because domoticz seems to freeze
I have created an issue on GitHub for this.
It seems you did not read the instructions well enough, it should end with .nest.com
Did you try it separately from Domoticz by running the nest.py?
remko2000
I tried another nest plugin:
https://github.com/rolandbreedveld/nest ... me-ov-file
this works fine.
this works fine.
