Problem Setpoint SetSet point Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
French89
Domoticz version: 2024 2
Post by French89 »
I am the latest newcomer, from France. I have been using domoticz since 2016 on a pi 3B, and I would like to take this opportunity to congratulate all the actors who contribute to the development of the program, thank you to you.
There is a small downside for me with the latest version "2024 2" since this morning, all the "Thermostat Setpoint" devices are no longer updated by my scripts.
Example that no longer works:
 commandArray['SetSetPoint:575']= '0' -- Draw at least overnight
What's wrong, can you help me?
Kind regards
thomasbaetge
Domoticz version: 2023.1
Re: Problem Setpoint SetSet point
Post by thomasbaetge »
I had the same issue I think.
I could set them manually from the dashbord but any updates from the internal automation (blockly in my case) just seized to function after the update.
No errors were given.
I simply sorted that out by moving the automation tasks (like controlling thermostate based on windows sensor) to Node-Red.
Took me about an hour and now everything is under control.
French89
Post by French89 »
I don't use Node-red, and especially I can't afford that updates disrupt the proper functioning of my scripts in Lua or Blocky.
I have an automatic system for controlling the temperature of a fireplace with a boiler.
If not, is it possible to revert to an earlier version, and how do you do it?
Kind regards.
Domoticz version: 2024.7
What is the configuration of your setpoint device? Can it accept the value you have set (eg 0) ?
French89
Post by French89 »
Hello.
My system has been working for 2 years, and was working yesterday until 11:15 am, then I accepted the update 2024 2 to domoticz,
and in the afternoon I realized that there was a problem.
My machine works very well, if I manually change the thermostat setpoint, it reacts.
I have some scripts in lua and another in blocky that worked before the update.
Now the setpoint of devices are no longer updated.
what's happen?
The previous thermostat setpoint device have been converted to general setpoint devices with more options. You now can configure resolution/step size, min/max values, unit of measure , check the dialog in device edit button.
Lua should be able to set this new setpoint so if it fails perhaps you have changed the min/max value so 0 is not accepted.
What is the error in the logging if you run the script?
French89
Post by French89 »
I present to you the elements:
Capture d'écran 2024-01-17 202813.png (12.35 KiB) Viewed 12001 times
Capture d'écran 2024-01-17 202744.png (9.55 KiB) Viewed 12001 times
Capture d'écran 2024-01-17 202919.png (27.5 KiB) Viewed 12001 times
Read more in the message below
French89
Post by French89 »
I'll continue the photo report:
Capture d'écran 2024-01-17 202845.png (1.83 KiB) Viewed 11997 times
You can see that the update is not done.
The 150° is not there
Do you see an error somewhere?
Thank you for your help.
Capture d'écran 2024-01-17 203037.png (25.83 KiB) Viewed 11997 times
I can reproduce your issue on stable and latest beta of today.
With Lua a setpoint device is not updated.
I created a similar dzvents script and that works without issues.
As I never programmed in Lua this is the timer triggered script I used. I created a dummy setpoint device named: test setpoint
When activated I see the print statement but the setpoint device is not updated.
-- loop through all the devices
for deviceName,deviceValue in pairs(otherdevices) do
 if (deviceName=='test setpoint') then
  commandArray['SetSetPoint:183'] = "25"
  print("set Setpoint")
Dzvents script that has no issues
		timer = {
			'every minute',
	execute = function(domoticz, timer)
		domoticz.devices(183).updateSetPoint(25)
French89
Post by French89 »
Thank you Waltervl for your valuable help.
So if the SetPoint works under Dzvents, which just got a fix not too long ago, it seems to me, it's because the Setpoint device has been modified in domoticz.sh but not the Blocky and Lua languages or interpreters, no???
Should we wait for a fix?
As I am not a Lua programmer I am not sure if my program is correct. So I hope an experienced Lua programmer can verify our findings.
As a workaround you can convert your Lua scripts to dzvents.
To be sure I opened a GitHub issue https://github.com/domoticz/domoticz/issues/5991
French89
Post by French89 »
Ok,
I'm going to try it with Dzvents, which I don't know, and I'm going to find out.
Thank you for all the attention Waltervl.
gizmocuz
Post by gizmocuz »
Thanks for the example code!
Found the issue! :roll:
The issue was inside the internal task scheduler that was checking for a fixed SetPoint device ID....
Fixed in beta 15864
The above lua script is a bit scarry as it will cause an endless loop
Better to use
-- loop through all changed devices
if (devicechanged['DummySwitch']) then
  commandArray['SetSetPoint:158'] = "23.4"
French89
Post by French89 »
Great so Gizmocuz.
I'm going to check if my script Lua works with beta version 15864.
I'll keep you posted.
But what about Blocky?
Kind regards.
French89
Post by French89 »
Ah, ah.
It works! In blocky and in Lua.
That's here:
Pour être sûr d’avoir ouvert un ticket GitHub https://github.com/domoticz/domoticz/issues/5991
Kind regards.
Thank you both. Look on:
Capture d'écran 2024-01-18 081239.png (48.72 KiB) Viewed 11875 times
Capture d'écran 2024-01-18 081350.png (2.37 KiB) Viewed 11875 times
Capture d'écran 2024-01-18 081324.png (13.08 KiB) Viewed 11875 times
imautohuttraeger
Post by imautohuttraeger »
gizmocuz wrote: Thursday 18 January 2024 7:23 Thanks for the example code!
Fixed in beta 15864
Better to use
As I am a little bit scared of installing a beta on my production system: Is it planned to release a stable Version 2024.3 in the near future?
I think around mid 2024 you can expect a new stable release.
You can update to current beta and keep checking on new stable release. So no triggers for new betas. Current beta is as stable as it can be.....
imautohuttraeger
👍 thx for explaining! So I will dare the beta
gizmocuz
Post by gizmocuz »
Lucky you... there's a new stable ;)
imautohuttraeger
🙏🏽👍🏽Thx! You are my hero!
