Nest integration
remko2000
Nest integration
Post by remko2000 »
I try to follow the wiki:
https://www.domoticz.com/wiki/NestDeveloperApiKey
It looks like ther's something changed with google. The link:
https://console.developers.nest.com/nl/auth/new doesn't work.
I also see nowhere a link to create new OAuth Client to get Oautpin.
Do I something wrong or is there something changed?
By the way, I do have my nest running under home bridge. So I do have an apikey, issue token and cookie. But in domoticz other things are asked to be entered....
remko2000
Re: Nest integration
Post by remko2000 »
Anyone a suggestion?
boum
Domoticz version: 4.10717
Post by boum »
I think Nest API stopped to work a few years ago when it was bought by Google. If there is a new API, nobody did port it to the domoticz plugin.
remko2000
Post by remko2000 »
I tried this:
https://github.com/FilipDem/Domoticz-NE ... ree/master
One device is added in domoticz 'nest - away' but I can't switch it.
In my log I get:
2024-01-19 16:26:08.594 Error: Nest: > General error TaskHandler: 'Away'
This isn't working I think.
Domoticz version: 2026.3
remko2000 wrote: Friday 19 January 2024 16:28 I tried this:
In my log I get:
As this repository is updated only 3 weeks ago it should work. Perhaps make an issue or read through the closed issues to see if someone had the same issue as you.
Do you see something special in the Domoticz log when you restart the plugin (select plugin hardware gateway and click on update)
remko2000
Post by remko2000 »
If I update the plugin and use the whole issuetoken including ' home.nest.com&include_granted_scopes=true&auto=1' in the end the log of domoticz says:
'Error: Nest: Hardware setting issue_token must end with nest.com.'
After entering I also have to reset my raspberry because domoticz seems to freeze
I have created an issue on GitHub for this.
It seems you did not read the instructions well enough, it should end with .nest.com
Did you try it separately from Domoticz by running the nest.py?
remko2000
Post by remko2000 »
I tried another nest plugin:
https://github.com/rolandbreedveld/nest ... me-ov-file
this works fine.
