Bar chart in dashticz - block definition
Daro1003
Domoticz version: 2023.1
Post by Daro1003 »
Please help me define a block in dashticz total energy.
I want to add a bar chart because now I have a linear one, I used the following instructions: https://dashticz.readthedocs.io/en/mast ... raphs.html
but somehow I don't manage to insert a block like this:
blocks[610] = { title: 'TV Kamer Całkowita', devices: [6], graph:'bar', width: 2,}
and still nothing, line graph.
Please help me how to define a block in dashticz so that a bar chart is displayed as in the instructions.
willemd
Domoticz version: 2024.1
Re: Bar chart in dashticz - block definition
Post by willemd »
It seems 6 is your device so 610 is just a title, therefore it should be between quotes.
blocks['610'] = { title: 'TV Kamer Całkowita', devices: [6], graph:'bar', width: 2,}
of course also in your column definition you should then refer to '610'
Better to give it a meaningfull title like 'TV Kamer Całkowita''in your case
so
blocks['TV Kamer Całkowita'] = { title: 'TV Kamer Całkowita', devices: [6], graph:'bar', width: 2,}
Daro1003
Post by Daro1003 »
Then something is wrong because this entry doesn't work:
columns[38] = { blocks : ['blocktitle_13',576,580,579,578,'610'], width: 12}
610 - this is the idx of the device in domoticz that I want to display in a bar chart
So in this notation:
how does dashticz know what domoticz block should show?
blocks[610] = { title: 'TV Kamer Całkowita', graph:'bar', width: 2,}
doesn't work
I want to display a bar chart of this device in domoticz:
Lokonli
Post by Lokonli »
With '610' as key Dashticz normally will display a default Domoticz block for device with domoticz id 610
You can enforce to display it as a graph as follows:
blocks['mykey'] = { title: 'TV Kamer Całkowita', graph:'bar', devices=[610], width: 2, type:'graph'}
If you want to show all data in one graph:
blocks['mykey'] = { title: 'TV Kamer Całkowita', graph:'bar', devices=[576, 580, 579, 578, 610], width: 2, type:'graph'}
Daro1003
Post by Daro1003 »
I managed to display the chart, but I wanted the dashticz to display a bar chart after clicking on the block, not a line chart as in the instructions.
In the code you sent you have the error "devices=[610]" it doesn't work, there is a total error, it should probably be "devices:[610]"
And then there is a graph in the block:
I would like to display a bar chart instead of a line chart as it is now when clicking on a block.
willemd
Post by willemd »
If it is about the popup graph (you did not state that in your first question), then you should look at the documentation here:
https://dashticz.readthedocs.io/en/mast ... aph-window
Daro1003
Post by Daro1003 »
I meant the chart that pops up after clicking on the block. Maybe I described it wrong, sorry.
But thanks to this I learned how to make a nice chart on a separate screen.
Now I will try to follow the instructions provided to make a pop-up bar graph after clicking on the block regarding total electricity.
Lokonli
Post by Lokonli »
You have to define a block for the popup parameter, like:
blocks['tv'] = { title: 'TV Kamer Całkowita', idx:610, width: 2, popup: 'tvgraph'}
blocks[ 'tvgraph'] = { devices: [610], type: 'graph', graph: 'bar'}
Daro1003
Post by Daro1003 »
I have a question about the chart below, how to set it to display - the last month?
blocks['wykres_dom'] = { title: 'Dom Całkowita', graph:'bar', devices:[618], width: 12, height: '300px', type:'graph'}
Ostatni miesiąc.jpg (127.44 KiB) Viewed 4424 times
willemd
Post by willemd »
https://dashticz.readthedocs.io/en/mast ... tom-graphs
use range and filter as described in the manual, link above
Daro1003
Post by Daro1003 »
I just wish the first view was a month and not 24 hours
willemd
Post by willemd »
Daro1003 wrote: Sunday 14 January 2024 14:56 I just wish the first view was a month and not 24 hours
Just change the order of the definition in your custom graph, so define the month graph first and then the 24 hours graph.
Daro1003
Post by Daro1003 »
Do I understand correctly:
custom: {range: 'month'}
I would like the month to be displayed because now I have to press the month button, by default it displays several hours
willemd
Post by willemd »
Daro1003 wrote: Monday 15 January 2024 22:31 Do I understand correctly:
You have to create a CUSTOM graph as shown in the link and then define the month as the first in the list.
Daro1003
Post by Daro1003 »
Or so:
blocks['wykres2'] = {
    title: 'Całkowita',
	height: '300px',
    devices: [618],
    graph: ['bar'],
    custom : {
        "Miesiąc": {
            range: 'month',
            filter: '1 month',
			 data: {
        "Dziś": {
            range: 'today',
            filter: '1 days',
            data: {
        "Ostatnie godziny": {
            range: 'days',
            filter: '6 hours',
            data: {
    legend: true,
    datasetColors:['blue','red','yellow']
And what should I enter in data? ?
willemd
Post by willemd »
d.v_618 , in line with the example in the manaul
Daro1003
Post by Daro1003 »
    title: 'Całkowita Dziś',
	height: '300px',
    devices: [770],
    graph: ['bar'],
    custom : {
        "Miesiąc": {
            range: 'month',
            filter: '1 month',
			 data: {
				 nett: 'd.v_770'
        "Dziś": {
            range: 'today',
            filter: '1 days',
            data: {
				nett: 'd.v_770'
        "Cały Rok": {
            range: 'year',
            filter: '6 months',
            data: {
				nett: 'd.v_770'
    legend: {nett: 'Godziny Dni Miesiące'},
Back to topic:
Monthly chart - ok, very good
Today Chart - Not ok indications as in the picture
Year Chart - No ok it doesn't show the year.
What's wrong with my code?
In the Year Chart it should show the months and in the Today Chart it should show the hours from 00 to 23:59 but it shows otherwise, what is wrong?
Miesiąc ok Good.jpg (87.82 KiB) Viewed 1562 times
Dziś - Today.jpg (118.95 KiB) Viewed 1562 times
willemd
Post by willemd »
How does the graph of this devcie in domoticz itself look like? Are you sure there is data for other moments?
Daro1003
Post by Daro1003 »
In red, a positive graph of the same domoticz device like this:
blocks['wykres_dom'] = { title: 'Dom Dziś', graph:'bar', devices:[770], width: 12, height: '300px', type:'graph',}
In blue, the custom chart shows differently as you can see.
But in the meantime - a month is ok.
Daro1003
Post by Daro1003 »
Domoticz All year round
