As many, I have moved to a MQTT and Z-Wave-JS. I am not an expert on either of these but I managed to get it working, albeit with some trickery.
I have Fibraro smart switch has a couple of power meters and, of course, a switch. I found the following configuration under "Home Assistant - devices":
The strange thing here is that it seems that the order of the values "37-0-currentValue" and "37-0-targetValue" matter. I had to swap them to make the switch working. I only get one device and I suppose only the first value is used domoticz autodiscovery.
"type": "switch",
"object_id": "switch",
"discovery_payload": {
"payload_off": false,
"payload_on": true,
"value_template": "{{ value_json.value }}",
"command_topic": "zwave/Vloerverwarming/37/0/targetValue/set",
"state_topic": "zwave/Vloerverwarming/37/0/currentValue",
"device": {
"identifiers": [
"zwavejs2mqtt_0xc1dfb822_node11"
"manufacturer": "Fibargroup",
"model": "Metered Wall Plug Switch (FGWP102)",
"name": "Vloerverwarming",
"sw_version": "3.2"
"name": "Vloerverwarming_switch",
"unique_id": "zwavejs2mqtt_0xc1dfb822_11-37-0-currentValue"
"discoveryTopic": "switch/Vloerverwarming/switch/config",
"values": [
"37-0-currentValue",
"37-0-targetValue"
"persistent": false,
"ignoreDiscovery": false,
"id": "switch_switch"
