no scripts anymore
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
anno
Domoticz version: all
no scripts anymore
Post by anno »
With the update 2024.1 all the scripts stop working, dzvents, lua and blocky. non work!!!!!!!
long time domiticz user, running 8 domoticz installations on vm's nuc i3. And espeay hosting more than 30.
solarboy
Domoticz version: 2024.6
Re: no scripts anymore
Post by solarboy »
When I updated it was fine, have you enabled "events" in settings, perhaps a bit flipped during the upgrade. It's the last 2 entries on the "Other" tab.
Intel NUC with Ubuntu Server VM (Proxmox),mosquitto(docker),RFXtrx433E,zwavejsUI (docker),Zigbee2mqtt(docker),SMA Hub (docker),Harmony Hub plugin, Kodi plugin,Homebridge(docker)+Google Home,APC UPS,SMA Modbus,Mitsubishi MQTT, Broadlink,Dombus
anno
Post by anno »
no, event are still active. It is a really big, Stupid code problem.
gizmocuz
Post by gizmocuz »
So you got it working again?
anno
Post by anno »
gizmocuz wrote: Wednesday 03 January 2024 15:51 So you got it working again?
Nop, it is on all the domoticz installs, every switch is working (after replacing with the exaxt same new switches) manual, but not with a script. The only solution i now have is to migrate the espeasy switches to my head domoticz. This will not work with the klikaanklikuit, so fer this i don't have a detour. And i don't get it, this update was a stable?!!!! not!!
anno
Post by anno »
anno wrote: Wednesday 03 January 2024 21:16
For so far i did find out. Before the 2024.1 update (and yes i do update to beta versions) everything was working perfectly. Today after the 2024.1 update, and this is a stable version :? :shock: there is a lot broken or working really poor. I did thougt maybe i have to many scripts. But after some researh this is not the cause. So what is it, the script system is broken, if it is working it is so slow, for example, when i have a motion sensor detect the lamp that need to go on within a script it if!!! will take up to 10 minutes to go on!!!!! And lua code is not working at all!!!!!! So a lot is broken. If and When i need to start al over, it will be a nightmare!!!
anno
Post by anno »
anno wrote: Thursday 04 January 2024 14:32
Ik denk dat ik voor de lamp en bewegingsmelder scripts (blocky) een omweg heb gevonden. Zet in espeasy de pir sensor op "push button active high" dan blijft de virtuale motion sensor in domoticz aan, en zodra an x seconden (veen seconden) later de lamp aangaat zet dan in het script virtuale bewegingsmelder off. is not working,
An example:
A simple blocky script, did work great before the 2024.1 update.
Schermafbeelding 2024-01-04 171144.png (87.59 KiB) Viewed 711 times
After puching the switch, nothing is happening see:
rainshower script nothing after pressing switch.jpg (57.82 KiB) Viewed 713 times
A shower of about 6 minutes and than the rainshower needs to go off, but it won't, only when i push the button manual with my smartphone goes it off
Schermafbeelding 2024-01-04 171019.png (101.29 KiB) Viewed 712 times
