Android app: temperature setpoints aren't working anymore.
Huntback
- Domoticz version: 2024.2
I've noticed that the temperature setpoint function does not work (anymore).
They display but I cant change an temperature setting.
The app version is 0.2.366 (9403) and is the premium (paid) version.
The domotics version is (currently) 2024.1 (build 15797), but setting the setpoints has not worked for some time.
Any idea how to solve this?
Synology - DS918+
RFXCOM - RFXtrx433XL (LAN)
Oregon - Weatherstation
Some KAKU, Impuls, TFA, etc.
Jgue
Re: Android app: temperature setpoints aren't working anymore.
Hello I am facing the same problem we use the app a lot and have multiple dummy thermostats in our
house now I have to set the thermostats in the webbrowser that's not don for my wife.does anyone already have a solution for the problem?
See the screenshot I marked the place where the ZET butten was.
- Screenshot_20240104_170900_Domoticz.jpg (242.16 KiB) Viewed 14053 times
Jgue
The next screenshot how it was before the update.
- Screenshot_20240104_192250_Domoticz.jpg (268.18 KiB) Viewed 14052 times
dheuts
I have the same problem after updating. Also on ios domoticz and Pilot app
Raspberry Pi 4 With Domoticz - RFXCom - Tuya Wifi LED lights - Chuango Alarm - Zwave+ - Zigbee2MQTT - Anna Thermostat - Broadlink IR, P1 - Eufy Robo Vacuum - Worx Robo Mower
- Domoticz version: 2026.3
It has been reported on the android app repository. We will have to wait until it is implemented. https://github.com/domoticz/domoticz-android/issues/704
- jvdz
- Domoticz version: 4.107
Looks like a fix is committed: https://github.com/domoticz/domoticz-an ... c1d9c5dda0 for the next update.
Huntback
Domoticz on Android has been updated.
Thermostat setpoints work again.
But the display of the setpoint temperature after setting and reopening the setting screen differs from the previously set temperature.
in brief:
- click on set
- set the temperature to, for example, 19.5 and click on set.
- set point value is 19.5
- click on set
- setpoint value is 19.0 and not 19.5
It only seems to go wrong with the .5 values which are displayed as .0.
So the setpoint works again, but not yet correctly.
in brief:
- click on set
- click on set
Synology - DS918+
There is a new update on its way to play store that will fix the issue (also take into account step size/min/max).
Huntback
Domoticz on Android has been updated again.
Thermostat setpoints work now as it should be
Thanks.
Thanks.
Synology - DS918+
No it is not, it only works ok if you use it as a thermostat within 0 to 30 degrees but not if you use different settings eg min/max -100 to + 100 with step size 10.Huntback wrote: Thursday 18 January 2024 19:41 Hello,
Thermostat setpoints work now as it should be.
Thanks.
