Heat-It Wall controller config for OZW
madpatrick
Domoticz version: 2026.1
Post by madpatrick »
For those who are still using OZW and want to use the Heat-it Wall controller
(https://products.z-wavealliance.org/pro ... uencyId=-1)
I've made a simple config that works within Domoticz
add in the following line manufacturer_specific.xml
under section <Manufacturer id="019b" name="ThermoFloor AS">
   <Product config="thermofloor/heatitzwc.xml" id="0x2403" name="Heatit Wall Controller" type="0x0004"/>
add a file heatitzwc.xml in /domoticz/Config/thermofloor
<Product Revision="1" xmlns="https://github.com/OpenZWave/open-zwave">
  <!-- Please refer to https://github.com/OpenZWave/open-zwave/wiki/Adding-Devices for instructions -->
  <MetaData>
    <MetaDataItem name="Name">Heatit Z-wave Wall Controller</MetaDataItem>
    <MetaDataItem name="Description">The Heatit Z-Push Wall Controller is a wireless wall-mounted Z-Wave Controller. It has mounting options for 1, 2 or 3 rockers, allowing for easy and practical management of your Z-Wave products. The switch can be set up to control scenarios or work in association with other Z-Wave products. Each rocker switch has a dual-color LED to indicate button actions.
</MetaDataItem>
    <MetaDataItem name="OzwInfoPage">http://www.openzwave.com/device-database/XXXX:XXXX:XXXX</MetaDataItem>
    <MetaDataItem name="ProductPage">https://https://heatit.com/product/10221/smart-products/controllers/heatit-z-push-wall-controller-white-ral-9010-glossy/1107/</MetaDataItem>
    <MetaDataItem name="ProductSupport">https://heatit.com/product/10221/smart-products/controllers/heatit-z-push-wall-controller-white-ral-9010-glossy/1107/</MetaDataItem>
    <MetaDataItem name="ProductPic">images/thermofloor/Heatit-Z-Push-button-8-white.png</MetaDataItem>
    <MetaDataItem name="ProductManual">https://https://media.heatit.com/2077</MetaDataItem>
    <MetaDataItem name="WakeupDescription">short press any button</MetaDataItem>
    <MetaDataItem name="InclusionDescription">set controller in inclusion mode press and press up button for 6 times in 3 seconds</MetaDataItem>
    <MetaDataItem name="ExclusionDescription">set controller in exclusion mode press and press down button for 6 times in 3 seconds</MetaDataItem>
    <MetaDataItem id="0x2403" name="ZWProductPage" type="0x0004">https://products.z-wavealliance.org/products/4028</MetaDataItem>
    <MetaDataItem id="0x2403" name="FrequencyName" type="0x0004">CEPT</MetaDataItem>
    <MetaDataItem id="0x2403" name="Identifier" type="0x0004">Heat-It</MetaDataItem>
    <ChangeLog>
      <Entry author="MadPatrick" date="23 December 2023" revision="1">add Heatit Z-wave Wall Controlle</Entry>
    </ChangeLog>
  </MetaData>
  <!-- Configuration Command Class - All Configuration Parameters should be entered into the section below -->
  <CommandClass id="112">
    <!-- Here is a Byte/Int/Short Value Sample -->
    <Value genre="config" index="1" label="Factory reset"  max="21930" min="21930" type="int" units="" value="0" write_only="true">
      <Help>
			Set to 21930 to factory reset the device.
			</Help>
    </Value>
  </CommandClass>
  <!-- The Association Group Information -->
  <CommandClass id="133">
    <Associations num_groups="3">
      <Group index="1" label="LifeLine" max_associations="5"/>
      <Group index="2" label="Launch 1" max_associations="5"/>
      <Group index="3" label="Launch 2" max_associations="5"/>
      <Group index="4" label="Launch 3" max_associations="5"/>
    </Associations>
  </CommandClass>
</Product>
Include the device by the normal incouding procedure and it should work
