DzVents script suggestions please [Solved]
Tukker
- Domoticz version: 2023.2
It's getting cold outside and we're doing our utmost to reduce gas consumption.
We're using P1 Smart Meter USB which shows daily usage.
In the current situation I can read our daily usage from today up till the current hour, but yesterdays'usage only displays teh end resut at 23:59.
I want to write/copy a script that can display the usage at a given time, or at the current time yesterday and the days before.
In other words: Is my daily gas consumtion at noon more or less than yesterday at noon.
Because I don't know where to start I'm asking for help.
Must be something with a Virtual Sensor displaying yesterday's data I guess.
Bugs bug me.
- habahabahaba
- Domoticz version: 2024.4
Re: DzVents script suggestions please
1. Dummy hardware - Virtual sensor - Custom sensor
2. making Script that running every hour (or how often you nedd) and taking data from Smart Meter and putting them to new sensor
- Domoticz version: 2026.3
If you check your log page on your gasmeter device and you see the data of the last week per day including today.
I know exactly If we are above or below our normal figures if I look at the current usage of today.
Energy usage is only fair to compare with other days if you have similar temperatures. Therefore the degree days have been introduced. Also visible on the report page of a temperature device.
Else you can look at this discussion for inspiration to get the data from yesterday. viewtopic.php?t=26915
willemd
By far the easiest would be:
1) extend the history on your device to 7 days
2) run below sql statement
whereby 2 is replaced by the idx of your device and "01" by the hour up to which you want to have the values included.
This will show for each available day the consumption up to and including the hour selected.
You can run the sql statement from sqlite3, or from a python program, or from dzVents.
select substring(date,1,10) dateonly,max(value)-min(value) from meter where devicerowid=2 and substr(date,12,2)<="01" group by dateonly;
willemd
Here is the complete DzVents script. You just need to put in the correct idx of your gas device on line 1.
local gasDeviceIdx=2
timer = {
'every hour'
shellCommandResponses =
'GASconsumption',
logging = {
level = domoticz.LOG_INFO,
marker = 'GASconsumption',
if item.isTimer then
local currentHour=os.date("%H",os.time())
local shellCommand='sqlite3 /home/pi/domoticz/domoticz.db \"select substring(date,1,10) dateonly,max(value)-min(value) from meter where devicerowid='..gasDeviceIdx..' and substr(date,12,2)<\\\"'..currentHour..'\\\" group by dateonly;\"'
domoticz.log('running shellCommand '.. shellCommand,domoticz.LOG_INFO)
domoticz.executeShellCommand({
command = shellCommand,
callback = 'GASconsumption',
timeout = 5,
domoticz.log('****** cumulative consumption ***********', domoticz.LOG_INFO)
domoticz.log("\n" .. item.data,domoticz.LOG_INFO)
domoticz.log('*****************\n', domoticz.LOG_INFO)
Using SQL is not the best idea to get this.
There is a historic function to get yesterday's value so no reason to do this ugly workaround.
Also sqlite3 needs to be installed on your system.
Tukker
OK thanks. @waltervl your warning of interfering in the domoticz.db sounds reasonable.
So I have read the link you gave and tested the URL string @waaren suggested over there as a start.
This string doesn't show a result.
So I started with this one:
which gives me the actual value.
Question remains: How do I get yesterdays' value samen time same device.
Your remark about readings being not comparable because temperature outside and more circumstances may vary is correct but for my usercase that is not important right now.
http://192.168.1.1:8080/json.htm?type=command¶m=getdevices&rid=16Question remains: How do I get yesterdays' value samen time same device.
Bugs bug me.
willemd
It is not really interfering. You are not changing anything. You are only retrieving values, just in a different way from using JSON.HvdW wrote: Wednesday 29 November 2023 11:35 OK thanks. @waltervl your warning of interfering in the domoticz.db sounds reasonable.
Normally it would be better to use JSON to interface with the dbase to avoid problems when the dbase changes. In this case you are selecting the value field by date from a meter table, one of the core structures of Domoticz. Hardly expected to change.
And if you want to run JSON from a DzVents script, you will get a similar "ugly" structure, using a http response instead of a shell response.
Anyway, it is up to you .....
To get the hourly values using a JSON you can use
http://xxx.xxxx.xxx.xxx:8080/json.htm?type=command¶m=graph&sensor=counter&idx=IDX&range=day- waltervl
Or use
and you will get the summary values of the last 7 days (including today)
http://xxx.xxxx.xxx.xxx:8080/json.htm?type=command¶m=graph&sensor=counter&idx=IDX&range=weekDomoticz running on Udoo X86 (on Ubuntu)
Tukker
@willemd
Those are the values I was looking for.
And you're right.
This gives me the information I wanted.
I'll go play with it and probably ask more questions in a few days or show a working script.
And you're right.
willemd wrote: Wednesday 29 November 2023 14:44 It is not really interfering. You are not changing anything. You are only retrieving values, just in a different way from using JSON.
http://xxx.xxxx.xxx.xxx:8080/json.htm?type=command¶m=graph&sensor=counter&idx=IDX&range=dayI'll go play with it and probably ask more questions in a few days or show a working script.
Bugs bug me.
Tukker
I did like this:
But now I am at a loss how to handle the Sensor update process.
I created a Gas dummy named: Gas yesterday and a text dummy named Yestergas.
Let's say I want to fetch value 1: like 24 hours before.
How do I update ?
Remark: value 1: to 25: is never displayed, it starts with 3: or 5: and goes up and up like from 33: to 57: and onward.
The url put in a browser always starts at 0:
So why is it augmenting in a script.
First success: I am able to update the text dummy Yestergas with this one:
Maybe write some code to find the highest value and substract 24 and substitute that for the 44 in the example above?
EDIT
Suggestions for another type of dummy than text?
--Gas meten
-- Howto at Luftdaten https://www.domoticz.com/forum/viewtopic.php?f=72&t=23406&hilit=luftdaten
-- Call Gasmeter with http://192.168.1.1:8080/json.htm?type=devices&rid=16
active = true,
timer = { 'every 1 minutes' }, -- every minute for testing, 10 minutes when active
httpResponses = { 'GasmeterRetrieved' } -- matches callback string below
if (item.isTimer) then
domoticz.openURL({
-- url = 'http://192.168.1.1:8080/json.htm?type=devices&rid=16',
-- url = 'http://192.168.1.1:8080/json.htm?type=command¶m=setused&idx=58&switchtype=1&used=true',
url = 'http://192.168.1.1:8080/json.htm?type=command¶m=graph&sensor=counter&idx=16&range=day',
method = 'GET',
callback = 'GasmeterRetrieved'
elseif (item.isHTTPResponse) then
if (item.ok and item.isJSON) then
domoticz.utils.dumpTable(item.json) -- dumpTable laat alle waarden zien, mooi voor debugging
domoticz.devices('Gas yesterday').updateSensor(item.json.result[1].CounterToday)
domoticz.devices('Yestergas').updateSensor(item.json.result[1].Data)
-- oops
domoticz.log('Error fetching Gasmeter data', domoticz.LOG_ERROR)
domoticz.log(item.data, domoticz.LOG_ERROR)
}Code: Select all
30 22:02:00.461 Status: dzVents: > mu: 10.308
2023-11-30 22:02:00.461 Status: dzVents: > d: 2023-11-30 21:00
2023-11-30 22:02:00.461 Status: dzVents: > 25:
2023-11-30 22:02:00.461 Status: dzVents: > v: 0.000
2023-11-30 22:02:00.461 Status: dzVents: > mu: 10.308
2023-11-30 22:02:00.461 Status: dzVents: > d: 2023-11-30 22:00
2023-11-30 22:02:00.461 Status: dzVents: > ValueQuantity:
2023-11-30 22:02:00.461 Status: dzVents: > CostEnergyR1: 800
2023-11-30 22:02:00.461 Status: dzVents: > ValueUnits:
2023-11-30 22:02:00.461 Status: dzVents: > DividerWater: 100.0
2023-11-30 22:02:00.461 Status: dzVents: > CostEnergyR2: 800
2023-11-30 22:02:00.461 Status: dzVents: > CostWater: 16473
2023-11-30 22:02:00.473 Status: dzVents: Info: ------ Finished GasCalc
2023-11-30 22:02:00.473 Error: dzVents: Error: (3.1.8) An error occurred when calling event handler GasCalc
2023-11-30 22:02:00.473 Error: dzVents: Error: (3.1.8) ...n/domoticz/scripts/dzVents/generated_scripts/GasCalc.lua:26: attempt to call a nil value (field 'updateSensor') Let's say I want to fetch value 1: like 24 hours before.
How do I update ?
domoticz.devices('Yestergas').updateText(item.json.result[44].mu)EDIT
Bugs bug me.
- habahabahaba
Can you show the result of this request:
Your log is saying that item.json.result[1].Data is empty
http://192.168.1.1:8080/json.htm?type=command¶m=graph&sensor=counter&idx=16&range=day-
Tukker
The log shows data as well as the json does
And the log:
It's working, however I was only able to catch it in a text file and I want to automate it to give me the value of 24 hours before now.
To be more precise: I'd like to catch the Gas consumtion at noon yesterday.
The mu that is connected with d: 2023-11-30 12:00 or maybe better d: 2023-11-30 12:00 just the d: and 12:00
2023-12-01 10:24:00.292 Status: dzVents: > 27:
2023-12-01 10:24:00.292 Status: dzVents: > d: 2023-11-30 12:00
2023-12-01 10:24:00.292 Status: dzVents: > mu: 3.528
2023-12-01 10:24:00.292 Status: dzVents: > v: 0.582Bugs bug me.
willemd
Please check the Dzvents documentation to select the correct update function for your type of device:
https://www.domoticz.com/wiki/DzVents:_ ... ipting#Gas
If it is a GAS device then it is updateGas()
The first hour in the list will be the currentHour X days ago, X being the number of days in your history.
So yesterdays value of the previous complete hour will be (X-1)*24
CurrentHour yesterday will be (X-1)*24+1
etc.
To pick out the mu value from the response you can use
item.json.result[(X-1)*24].mu
Just to add: if you want to make it more error-proof in case your history is not complete for example, you could read the "d" value first, check the date and hour, and only then get the corresponding "mu" value. The above (X-1)*24 calculation assumes your history is complete, which might not always be the case.
etc.
Tukker
Thanks @willemd
The updateGas tip is what I needed.
Next problems
Here is the code:
and the output:
So the gas seems to have a need to be multiplied by 1000
Nice outcome: The list always seems to be ending at #49, so asking the #25 outcome should be ok.
Next problems
Here is the code:
domoticz.devices('Gas yesterday').updateGas(item.json.result[27].mu) domoticz.devices('Yestergas').updateText(item.json.result[27].mu)Nice outcome: The list always seems to be ending at #49, so asking the #25 outcome should be ok.
Bugs bug me.
willemd
It is in the documentation:HvdW wrote: Friday 01 December 2023 17:37
updateGas(usage): Function. Usage in dm3 (liters).
#49 because you have your history setting at 2 days.
#25 will give you the current hour yesterday, which will be a full hour, so comparing this to the current hour total only makes sense at the end of the current hour.
Tukker
Re: DzVents script suggestions please [Solved]
Found the easy way out.HvdW wrote: Tuesday 28 November 2023 12:03 I want to write/copy a script that can display the usage at a given time, or at the current time yesterday and the days before.
What I wanted to achieve is to know yesterdays values and display those.
Main question: what was the gas consumption at noon yesterday.
My simple approach now is to check and update every day at noon + 5 or so minutes because gas updates some minutes after the hour.
Here is the script:
timer = {'at 12:08'},
execute = function(domoticz, triggeredItem)
local gasconsumptiontoday = domoticz.devices('Gas').counterToday
domoticz.devices('Gas yesterday noon').updateGas((gasconsumptiontoday*1000))
domoticz.notify('Gasmeter ' .. gasconsumptiontoday, domoticz.PRIORITY_HIGH)
}Code: Select all
domoticz.devices('Gas yesterday noon').updateGas(domoticz.devices('Gas').counterToday*1000)
}Bugs bug me.
willemd
Indeed an easy way out, but much more limited functionality than initially requested "usage at a given time" of course.
I think what you will find out over time is that waltervl was right: comparison makes more sense when you include degree day calculation.
And even with degree day calculation it is inaccurate. For example you might want to factor in the amount of sunshine since that might be heating up your house significantly if you have large windows, even if temperature from one day to the other is the same.
