OpenZwave weird behaviour
Patricen
Domoticz version: Beta rel
Post by Patricen »
I do have some roller shutters that are programmed to open with a timer.
At set time the open command is sent then a close command is sent by OpenZwave.
Do you have any suggestion regarding this issue?
Domoticz version: 2026.3
Re: OpenZwave weird behaviour
It could be that the open command is not being accepted/received by the device and it reports back its closed status in Domoticz.
Do you see the blind go open when triggered by the timer?
By the way you are using OpenZwave which will be remove from the next stable release!! You will have to move to Zwave-JS-UI very quickly
https://www.domoticz.com/wiki/Zwave
Patricen
Post by Patricen »
waltervl wrote: Friday 01 December 2023 12:05 It could be that the open command is not being accepted/received by the device and it reports back its closed status in Domoticz.
Yes, I know that OZW is becoming outdated, but I don't have any simple tutorial to switch to Zwave-JS-UI. Is there a simple way proceeding to this migration?
Patricen
Post by Patricen »
Oh...
Never succeeded to build a docker file maybe can I get help.
wiki shows :
git clone https://github.com/zwave-js/zwave-js-ui.git
cd zwave-js-ui
git checkout -b [the branch that you want] [b]What should I specify there?[/b]
docker build -f docker/Dockerfile -t zwavejs/zwave-js-ui:latest [b]What should be "Dockerfile"[/b]
You don't have to build it, just use it
https://zwave-js.github.io/zwave-js-ui/ ... ted/docker
gizmocuz
Post by gizmocuz »
And it's "docker compose" you want to use, so you need to use the 'docker-compose.yml' file from the above link
Patricen
Post by Patricen »
Ok thanks,
I have to go further in details as Docker is pretty new for me.
Patricen
Post by Patricen »
Hello
I've managed to install Z-Wave-JS using docker.
The issue I'm encountering is that there is no devices discovered. I have selected the right usb port -onlu the port number is displayed in the drop-down menu, no serial by id name.
The following warning appears on the trace "Z-Wave-JS driver is not ready yet"
I'm using a Z-wave.me UZB1 stick.
Do you know how to solve this issue?
What is in your docker compose file in section devices.
Should be something like below. Change /dev/serial/by-id/insert_stick_reference_here into the real name on you system.
Do the following command in a terminal window to find the correct USB name
ls -lah /dev/serial/by-id
devices section Docker compose Zwave-JS-UI
        devices:
            # Do not use /dev/ttyUSBX serial devices, as those mappings can change over time.
            # Instead, use the /dev/serial/by-id/X serial device for your Z-Wave stick.
            - '/dev/serial/by-id/insert_stick_reference_here:/dev/zwave'
Patricen
Post by Patricen »
I did modify Docker compose file, but still encounter an error.
I have stopped Domoticz to be sure it is not connected to the zwave stick, restarted Zwave-JS-ui but still have the error from attached image.
I tried both /dev/serial/by-id/usb-0658_0200-if00:/dev/zwave and /dev/serial/by-id/usb-0658_0200-if00 within the ZWave section of GUI.
The directory looks to be the right one? Maybe access rights?
gizmocuz
Post by gizmocuz »
Try following the updated guide, this is working
https://www.domoticz.com/wiki/Zwave-JS-UI
BartSr
Domoticz version: V2024.7
Post by BartSr »
does the debian version matters?
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Patricen
Post by Patricen »
gizmocuz wrote: Monday 08 January 2024 11:47 Try following the updated guide, this is working
Brilliant! I now do have MQTT and ZWave-JS-UI that works, but no connection to Domoticz using "MQTT Auto Discovery Client Gateway with LAN interface". I did not use neither localhost nor 127.0.0.1, the only thing that looks strange to me is TLS that I can't disable from dropdown menu.
The issue is in between MQTT broker and Domoticz as I can access messages using MQTT explorer utility.
It looks like MQTT Auto Discovery Client Gateway with LAN interface is the right hardware to use as it is the only MQTT auto discovery hardware available (version 2023.2).
gizmocuz
Post by gizmocuz »
Choose TLSv2 for secured connections (port 8883) or use the default when you connect to port 1883
can you connect with MQTT Explorer?
Patricen
Post by Patricen »
Yes, MQTT explorer shows results
Patricen
Post by Patricen »
Ok! Nothing shows-up within the configuration screen but devices are discovered.
Looks like there is no pending issue.
What is the usage of config screen then?
Patricen
Post by Patricen »
So,
The Domoticz device list was populated with devices named as "node_IDXX_", I then decided to give a name to each device within ZW2JSUI, remove the MQTT discovered devices in Domoticz and allow new devices to have the list populated with real names.
The issue is that the devices are not coming back. Is there something to purge in Mosquitto or any other trick to proceed?
akamming
Post by akamming »
Go to settings in zwave js ui and click on save, that will force resending the Discovery messages
Patricen
Post by Patricen »
Great, thanks !
That works perfectly, as well as 2024.1 update. So far it looks more reliable than OZW.
Is there a Zigbee-JS-UI that would replace deConz?
