trim() in dzVents ?  [Solved]
willemd
Domoticz version: 2026.3
Post by willemd »
Does dzvents have a trim() function? I cannot find it in the documentation.
I am importing data and one of the fields has a trailing space that I want to remove.
I tried the stringSplit function with space as separator but this did not achieve the result.
Currently I am forcing conversion to a number and then converting back to a string to achieve this.
Does a trim() function exist?
Doler
Re: trim() in dzVents ?
Post by Doler »
Don't know if dzvents has this function but in case not:
-- Trim a string
stringTrim = function(s)
  return s:match'^%s*(.*%S)' or ''
Mark: Domoticz latest Beta on Virtual machine (Proxmox) running Debian Trixie - Z-Stick 7 - RFXCom - P1 - SolarEdge - Dahua - Philips Hue - Docker - Zigbee2mqtt (latest, docker) via python plugin - Zwave-js-ui (latest, docker) - dzVents - Nodered
Dzvents has no trim function, neither does Lua but there are lots of ways to create one: http://lua-users.org/wiki/StringTrim
willemd
Post by willemd »
Thank you both, one solution is enough ;-)
What kind of programming language is used for that function definition? I don't recognise it and can't decifer the logic. It works but I don't see why.
Doler
Post by Doler »
It's Lua. There is a little error in the function (sorry for that): 'match' should be 'string.match'. I guess you can recognize it now.
willemd
Post by willemd »
Assembler, basic, algol, pascal, lisp, cobol, various 4gl's, python, dzVents, probably forgetting a few .... I am trying not to add Lua to it. ;-)
Thank you for your solution.
