Multiply value
Lillios
Multiply value
Post by Lillios »
Hey,
I have an old LUA scripts that was used to multiply a value from a sensor with 50.
The actual sensor is an Co2 sensor, but Telldus reads the value as a temperature.
I have recently setup my old installation, and i can not remember how i got this working, but now i get error in Domoticz log:
Error: EventSystem: in Script #1: [string "--Domoticz LUA Script (put text in file scrip..."]:12: attempt to index a nil value (global 'devicechanged')
Any ideas?
Or how to make this in DzVents?
--Name of the real CO2 meter
aqMeterName = 'WMS-Co2'
--ID of the created dummy CO2 meter
dummyAqMeterId = 41
aqVal = otherdevices_svalues[aqMeterName]
if devicechanged[aqMeterName] then
   --calculate actual value
   actual = 50 * tonumber(aqVal)
   --update dummy meter
   commandArray['UpdateDevice'] = dummyAqMeterId .. "|" .. actual .. "|0"
Domoticz version: 2026.3
Re: Multiply value
I think you mixed something up in your event script.
What is script named script#1 ? Is that the script you want to run? Or is it some empty script you need to delete? The error is coming from this script.
Lillios
Re: Multiply value
Post by Lillios »
waltervl wrote: Tuesday 10 October 2023 23:12 I think you mixed something up in your event script.
It is the script i want to run, (renamed it to Co2)
RonkA
Domoticz version: 2025.1
Re: Multiply value
Post by RonkA »
Not tested but is this something?
    logging = {
        level = domoticz.LOG_INFO, -- Adjust the log level as needed
        marker = 'CO2 Script'
        devices = { 'WMS-Co2' }
    execute = function(dz)
        local aqMeterName = 'WMS-Co2'  -- Name of the real CO2 meter that is a temperature device
        local dummyAqMeterId = 41 -- ID of the dummy that is a Air quality device
        local aqVal = dz.devices(aqMeterName).temperature  -- read the value from sensor
        local commandArray = {}
        local actual = 0
        if dz.changedDevices[aqMeterName] then
            -- Calculate actual value
            -- Log the calculated value
            dz.log("Actual CO2 value: " .. actual, domoticz.LOG_INFO)
            -- Update dummy meter
        dz.devices(41).updateAirQuality(actual)
SolarEdge ModbusTCP - Kaku - Synology NAS - Watermeter - ESPEasy - DS18b20
Work in progress = Life in general..
boum
Domoticz version: 4.10717
Re: Multiply value
Post by boum »
RonkA wrote: Tuesday 10 October 2023 23:58 Not tested but is this something?
This script has zero chance to work.
Lillios
Re: Multiply value
Post by Lillios »
boum wrote: Wednesday 11 October 2023 0:08
What needs to be changed?
I dont have any knowledge reguarding scripting. Trying to learn, but its frustrating when its not working :o
boum
Re: Multiply value
Post by boum »
Your issue with devicechanged being nil is probably because you set your script to be triggered by "time" or "all" (basically every choice in the trigger drop-down except "device")
When the script is triggered every minute, there is no changed device at that point.
In my opinion, one advantage of dzVents is that the triggers are explicit in the script (in the "on" section)
Also do not use chatgpt to generate scripts (not targetting anyone — maybe —), the result might work but it's more like a lottery.
When learning, I understand the frustration. Come with your issues of the forum, but if you want good honest help, document what you've tried. Also, learn to use debug logging.
I have not tested the following dzVent script, but at least it's not complete bullshit:
    logging = {
        devices = { aqMeterName }
    execute = function(dz, item)
        local actual = 50 * item.temperature
        dz.log("Actual CO2 value: " .. actual)
        dz.devices(dummyAqMeterId).updateAirQuality(actual)
Lillios
Re: Multiply value
Post by Lillios »
Thanks alot!
Unfortunately i cant get it to work.
Have set logging to Debug for Dzvent. And also changed your script to:
level = domoticz.LOG_DEBUG
But the log does not show anything. No errors, or no info.
I also tried to move "Line 1", as i thought it should be placed after "return {", and then i get an error in the Domoticz Log.
So the scripts seems to be running.
2023-10-12 22:17:56.398 Status: EventSystem: reset all events...
2023-10-12 22:17:56.399 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/CO2 Script.lua
2023-10-12 22:17:56.442 Status: dzVents: Debug: Dumping domoticz data to /home/pi/domoticz/scripts/dzVents/domoticzData.lua
2023-10-12 22:17:56.452 Status: dzVents: Debug: dzVents version: 3.1.8
2023-10-12 22:17:56.452 Status: dzVents: Debug: Event triggers:
RonkA
Re: Multiply value
Post by RonkA »
Searching (Ctrl+F) on 'wiki/DzVents:_next_generation_Lua_scripting' for 'item.' i read:
  • Since you can define multiple on-triggers in your script, it is not always clear what the type is of this second parameter. In your code you need to know this in order to properly respond to the different events. To help you inspect the object you can use these attributes like if (item.isDevice) then ... end:
So... is it maybe:
        local actual = 50 * (item.temperature)
boum
Re: Multiply value
Post by boum »
Lillios wrote: Thursday 12 October 2023 22:19 Have set logging to Debug for Dzvent. And also changed your script to:
Once you've done that, you've got to pepper the script with dz.log calls to check how things are going. If you don't get any output, then the script is compiled, but never called. Does the "temperature" device really change? (or is it modified with the JSON API with parsetrigger?)
        dz.log("Entering CO2 script update, from device changed: " .. item.name, dz.LOG_DEBUG)
        dz.log("CO2 meter temperature: " .. item.temperature, dz.LOG_DEBUG)
        dz.log("Actual CO2 value: " .. actual, dz.LOG_INFO)
        local aqMeter = dz.devices(41) -- ID of the dummy that is a Air quality device
        dz.log("Air quality before update: " .. aqMeter.co2, dz.LOG_DEBUG)
        aqMeter.updateAirQuality(actual)
do you see?
Lillios
Re: Multiply value
Post by Lillios »
boum wrote: Friday 13 October 2023 15:45
do you see?
Awesome, its working...!
At first it did not work, even if i breed on the Co2 sensor to get it to change the value of "VMS-Co2".
But then i unplugged the sensor, removed it from Domoticz, added it again and added it to "Temperature" page... and Baaaam its working :lol:
Big, big thank your for your help. I have put so many hours trying to get this to work!
Thanks again!
boum
Re: Multiply value
Post by boum »
