There is a huge delay in starting a scene in fibaro hc2 when i use fibarolink. Is there a setting to change the delay? Is there another way to start the scene without delay?
Some context of my project.
I have domoticz running on my Synology NAS. My NAS can't run docker so i installed the version availible in the plugin libary (version 2020.2)
I use domoticz to recieve button clicks from a Hue switch.
For this i use Events (blockly) to catch the trigger from the hue button and push a dummy switch.
In fibarolink i monitor the dummy switch and start a scene in Fibaro.
(i do this because i can't sellect a buton pushed with the hue switch device directly)
This, i got working! But the delay between pushing and see my lights (controlled with fibaro) changing is up to 10 seconds!
Delay in fibarolink Topic is solved
ravaoo
- Domoticz version: 2024-7
Delay in fibarolink
Running latest BETA on on Docker (Container Manager) in Synology NAS using zwave_js_ui with mqtt. Getting started with homebridge.
Living in an automated house is a survival but it is worth it
- Domoticz version: 2026.3
Re: Delay in fibarolink
what happens if you switch the dummy switch manually? Does it have the same delay?
Check the domoticz log file (menu setup - Log) to see what the timing of your actions are.
ravaoo
O, this is a good idee. When i switch the dummy's it is reacting almost immediately! So the delay is in de hue-domoticz link, or in the blockly handling.waltervl wrote: Monday 09 October 2023 15:35 what happens if you switch the dummy switch manually? Does it have the same delay?
ravaoo
How to figure out to eliminate the delay?
ravaoo
I found a solution in another tread:
viewtopic.php?t=20466
I have set the polling on 1 sec in the hardware config for the hue bridge! I hope this setting doesn't cook my NAS
thanks for the help waltervl!!
