I want to setup an motion alarm bsed on several motion detectors, the issue is some times there is a bird that triggers it and some times it's the mail delivery.
How can I check if an motion is detected a second time within a time period?
trigger between time
- jacobsentertainment
- Domoticz version: 2021-1
- Domoticz version: 2024.7
Re: trigger between time
It also depends on the motion sensor as some only report off (no motion) after x seconds.
But you can calculate the time delta with the second motion trigger with function domoticz.time.compare()
eg
https://www.domoticz.com/wiki/DzVents:_ ... ime_object
eg
local deltatime = domoticz.time.compare(myDevice.lastUpdate).secs)
Some sensors with config parameters can be configured to require several pulse in a time frame to trigger.
Anyway, the most generic way to manage sensors is imo to use weights and add them over a time slice of 1mn for instance.
For ext sensors you may use a weight that is a fraction of trigger weight so several trig of any sensors in this mn would be needed to ring a siren.
Weigh attribution may come from a sensor name prefix for instance. So future additions do not need script changes if naming convention is respected.
See alarm wiki.
See alarm wiki.
I found my way to get something working and added a couple of things to it, so here is my little alarm script. Still work in progress (fine tuning)
active = true,
devices = { 47, 49, 176, 603, 621, 65, },
logging = {
level = domoticz.LOG_DEBUG,
marker = "##Alarm"
data = {
Mot_a = { initial = 0 },
Mot_b = { initial = 0 },
Mot_c = { initial = 0 },
Mot_d = { initial = 0 },
Mot_e = { initial = 0 },
local thuis = domoticz.devices(65)
local sirene = domoticz.devices(161)
local cam_script = domoticz.devices(620)
--motion sensors buiten "Ikea trädrfi" on time ca 180sec
local Mot_A = domoticz.devices(47) -- Voordeur
local Mot_B = domoticz.devices(49) -- Achterdeur
local Mot_C = domoticz.devices(176) -- Carport
local Mot_D = domoticz.devices(603) -- Terras
local Mot_E = domoticz.devices(621) -- Schuren
--sirene timings
local So = '5' --Sirene_on_time
local Si = '5' --Sirene_interval
local Sr = '3' --Sirene_repeat
--camera snapshot settings
local Co = '1' --Camera trigger on for
local Ci = '30' --Camera --Sirene_interval
local Cr = '3' --Camera snapshots repeat
--Voordeur
if thuis.state == 'Off' and Mot_A.state == 'On' then
local currentTime = domoticz.time.minutesSinceMidnight
local lastTriggerTime = domoticz.data.Mot_a
if (currentTime - lastTriggerTime) <= 5 then --aangepaste tijd voor de postbode
sirene.switchOn().forSec(So).repeatAfterSec(Si, Sr)
cam_script.switchOn().forSec(Co).repeatAfterSec(Ci, Cr)
domoticz.data.Mot_a = currentTime
--Achterdeur
elseif thuis.state == 'Off' and Mot_B.state == 'On' then
local lastTriggerTime = domoticz.data.Mot_b
if (currentTime - lastTriggerTime) <= 5 then --aangepaste tijd voor postbode
domoticz.data.Mot_b = currentTime
--Carport
elseif thuis.state == 'Off' and Mot_C.state == 'On' then
local lastTriggerTime = domoticz.data.Mot_c
if (currentTime - lastTriggerTime) <= 4 then
domoticz.data.Mot_c = currentTime
--Terras
elseif thuis.state == 'Off' and Mot_D.state == 'On' then
local lastTriggerTime = domoticz.data.Mot_d
domoticz.data.Mot_d = currentTime
--Schuren
elseif thuis.state == 'Off' and Mot_E.state == 'On' then
local lastTriggerTime = domoticz.data.Mot_e
domoticz.data.Mot_e = currentTime
--Thuis aan
elseif thuis.state == 'On' then
sirene.cancelQueuedCommands()
cam_script.cancelQueuedCommands()
sirene.switchOff()
cam_script.switchOff().afterSec(60).checkFirst()
if thuis.state == 'Off' and device.state == 'On' then
domoticz.log('##Beweging bij ' ..device.name.. '')
domoticz.notify("Camera", 'Beweging gedetecteerd bij de ' ..device.name.. '', domoticz.PRIORITY_NORMAL,domoticz.SOUND_DEFAULT, "" , "telegram")
