For monitoring the temperature of the heating system, I use Domoticz's very powerfull display of temperature and humidity curves. Unfortunately, as of version 2023.x, the temporal representation seems to be limited. Cache clearing didn't help either, if that will be one of the first helping hints.
In Domoticz version 2022.2 the temporal scaling can be displayed individually in steps (7 - 3 - 1 days; as well as 3h and 1h). With the "Costum Graph" there are further setting possibilities, whereby a "short term" resolution is possible only up to max. of the last 7 days, which is in my case finally also sufficient.
In Domoticz version 2023.2 I am missing der 7 and 3 days scaling, and furthermore - the temporal scaling via the "Costum Graph" is limited. A setting via the "Costum Graph" over a period of more than one day seems not to be implemented in the graph. It remains with a max. representation of 24h. Is it a bug, a feature or just a user operating error from my side?
As a workaroud: Is there an easy possibility to export the history data captured over a period of time longer than one day?
Any hints are very appreciated!
Limitted Costum Graph presentation Topic is solved
uschuga
- Domoticz version: 2023.2
Used Z-Wave devices: EUR_SPIRITZ, FGBS001, FGR223, FGS223, FGBS222, ZMNHYD1 Smart Plug 16A, ZWA009 AërQ Sensor, NAS-WR01Z Power plug 12A, ZME_WALLC-S, FGD212, ST812 Flood Detector, PAN04-1 Double Relay Switch, ZMNHND1 Flush 1D relay, ZME_UZB1 USB Stick
Jofre
- Domoticz version: Latest
Re: Limitted Costum Graph presentation
Hi, on the custom graph page select long term day values and the time span from date to date.
uschuga
thank you for the reply. I am aware that the time span can be expanded. However, the details get lost and only daily values get visualized. I want to observe events with a periodicity of "some minutes" and "hours". This can be achieved with the short term (5 minutes values) setting.
In Version 2022.2 the time span can be selected up to 7 days and the resolution remains high. This is what I am expecting:
In Version 2023.2 the time span with high resolution is only selectable up to 24h:
Furthermore, the individual setting of the time span longer than one day is not displayed. Here the example from Version 2023.2 with a time span from 2023-09-24 to 2023-10-01. Only last 24 hours are displayes instead of 7 days:
Again: Is it a bug, a feature or just an user operating error from my side?
Is it possible to configure and add presets as 3 and 7 days?
This limitation keeps me from updating to version 2023.2.
- Domoticz version: 2026.3
I my case I have a 4 days short log (5 min) and in custom graph it will also show these 4 days if the initial time frame is correct.
There is no option on the custom graphs for short cuts for other time frames (3d, 3h, 1h).
So please check your short log setting in menu Setup - Settings.
uschuga
The setting in the menu was the crucial clue. I think I had used that entry myself a few years ago and had been forgotten.
Thank you very much.
