Monthly self-consumption percentage for solar energy.
pat44
I'm currently using the custom graph function to display information regarding my solar energy equipment.
It works pretty well. Please see the picture.
In yellow : solar production
In red : solar injection in the grid (negative value). It corresponds to the "surplus"
In blue : consumption from the grid (EDF as I reside in France).
What I want is to automatically calculate and display my self-consumption percentage (see the black line).
self-consumtion = (solar_prod + solar_injection) / solar_prod (solar_injection is negative so that's OK).
Graph display works well for Daily report since Dashticz makes the calculation based on the CounterToday information I believe.
However, I'm struggling to have a good monthly report.
What I want is just to display the self-consumption line based on accumulated energy : (Sum_SolarProd + Sum_SolarInjection)/Sum_SolarProd
So simply it corresponds to (YellowBox + RedBox)/YellowBox
But Dashticz is calculating the self-conso percentage for each day, and make the average for the entire month.
In other words, Dashticz calculates this value: avg((SolarProd/SolarInjection)/SolarProd)). avg stands for "average of".
But I would like this calculation : (Sum_SolarProd + Sum_SolarInjection)/Sum_SolarProd
If someone could help me. Thanks in advance.
- simplified_config.js
- (849 Bytes) Downloaded 129 times
- Capture_autoconso.JPG (85.38 KiB) Viewed 4147 times
pat44
Re: Monthly self-consumption percentage for solar energy.
See the json code here:
- Capture_autoconso_code.JPG (46.42 KiB) Viewed 4126 times
pat44
Please see below the picture showing the issue I have for August.
Self-consumption (also called auto-consumption) should be "100*(833,74-196,56)/833,74 = 76,4 %"
But Dashticz is returning 79,81% because it calculates the average of daily percentage for all the days in August.
The problem seems to be very straighforward and easy to solve.
But I think Dashticz is simply not appropriate to make such a calculation. It would require something as an intermediate function to make a monthly calculation and return this value to the custom graphic function. I dont' know if this is possible ? Or maybe I'm missing a simpler solution ?
However, I love very much Dashticz for its infinite possiblities, it is a very nice domoticz extension.
- Capture_autoconso_code_august.JPG (27.03 KiB) Viewed 4077 times
Lokonli
I understand the issue.
Probably I can add something to compute results from the aggregated data.
Like:
Would this fulfill your needs? Additional suggestions?
Like:
data: [
SolarInj: 'd.v_277',
SolarProd: 'd.v_274',
GridConso: 'd.v_278'
data_aggr: [
AutoConso: '(aggr.SolarProd + aggr.SolarInj)*100/aggr.SolarInj'
pat44
Yes it would fully satisfy my needs.
Is this "data_aggr" method already present or you plan to add it ?
Thanks so much for your quick answer.
Lokonli
I plan to add it before the end of the year.pat44 wrote: Friday 29 September 2023 9:37 Yes it would fully satisfy my needs.
pat44
Perfect, thanks!
pat44
Hi @Lokonli, did you have time to work on this issue ?
Thanks.
Thanks.
