ran virgin install from prompt (curl) and updatebeta now login needed
ErnieFR
Domoticz version: 2023.1
Post by ErnieFR »
Hi there, anybody known to what the account id/pwd is after running updatebeta ?
Just got a brand new Raspi4, headless accessed ssh to install Domoticz with curl command. All went great but would not start after install. Ran the service status command and it showed "exited" and "file not found /home/pi/domoticz/domoticz" which was perfectly there. Same when starting this file from the prompt, no such file found :-( part I
Looked a bit around, found a remark from others saying to run the ./updatebeta script and so I did. Now it start fine, but it asks for an account ID/PWD and nothing seems to be accepted :-( part II
Did another reboot, it keeps asking for an account while nothing is yet configured. Tried to simply click ok, or Admin or Admin/Admin or root account info but nothing seems to work....
If something on the basic login security has changed, which used to be zero/absent, why is there no info after using the upgradebeta script on this?
Doler
Re: ran virgin install from prompt (curl) and updatebeta now login needed
Post by Doler »
I suggest you start reading the Wiki (hint: the answer is on the front page)
Mark: Domoticz latest Beta on Virtual machine (Proxmox) running Debian Trixie - Z-Stick 7 - RFXCom - P1 - SolarEdge - Dahua - Philips Hue - Docker - Zigbee2mqtt (latest, docker) via python plugin - Zwave-js-ui (latest, docker) - dzVents - Nodered
Domoticz version: 2026.3
Next to the tip to use the wiki https://www.domoticz.com/wiki/Getting_started I would also advise you to use the stable release and not the beta especially as a virgin.
cd domoticz
sudo ./updaterelease
ErnieFR
Post by ErnieFR »
Doler wrote: Thursday 21 September 2023 12:59 I suggest you start reading the Wiki (hint: the answer is on the front page)
for you this all might be very clear, for a newbe it is not.
went to
https://www.domoticz.com/wiki/Releases#Versions
can't work it out even with your "hint"
ErnieFR
Post by ErnieFR »
waltervl wrote: Thursday 21 September 2023 13:04 Next to the tip to use the wiki https://www.domoticz.com/wiki/Getting_started I would also advise you to use the stable release and not the beta especially as a virgin.
cd domoticz
thanks to this action I'm back to square one : "file not found" in both service status info and in bash
There should not be any user account info been asked, or am I wrong. Could you please simply reply to this question?
ErnieFR
Post by ErnieFR »
ok ok ok ok,
I found it allright bloody admin/domoticz but why is the ./updatebeta not simply warning about this after running successfully ?
Who thinks of returning to page zero, but thanks for helping out
