script to check, it's not working
ssk17051980
Domoticz version: 2023.2
Post by ssk17051980 »
devices = {
'81' -- Replace with the actual IDX of the switch
logging = {
level = domoticz.LOG_DEBUG, -- Can be changed to domoticz.LOG_INFO to reduce logging volume
local sensorName = '200' -- Replace with the actual IDX of the water sensor
local areaInSquareMeters = 1 -- Replace with actual area in square meters
if device.state == 'On' then
local amountOfWater = 0.52615 * areaInSquareMeters -- Calculates the amount of water
domoticz.devices(sensorName).updateCustomSensor(amountOfWater) -- Updates the custom water sensor
domoticz.log('Amount of water added: ' .. amountOfWater .. ' L', domoticz.LOG_DEBUG)
can somebody to corect the script ?
thx
HvdW
Re: script to check, it's not working
Post by HvdW »
check this example
return
    on =
        devices = { 'Room switch'}
    execute = function(domoticz, roomSwitch)
        if (roomSwitch.active and domoticz.devices('Living room').temperature > 18) then
        domoticz.devices('Another switch').switchOn()
        domoticz.notify('This rocks!',
                        'Turns out that it is getting warm here',
                        domoticz.PRIORITY_LOW)
look where you place the braces
Bugs bug me.
Domoticz version: 2024.7
I linked you to this script viewtopic.php?p=255592#p255592
Why did you not use that?
And if something is not working please indicate what is not working. But better use the script I linked to.
Make a dummy rain device (in the script named 'regenmeter').
ssk17051980
I created the virtual sensor with the name regenmeter. I replaced the tippingbucketrain name with Terrace in the script, this being the element that transmits the information.
still no response from the dummy
return
on =
devices =
"tippingbucketrain",
logging =
level = domoticz.LOG_DEBUG, -- INFO, ERROR or DEBUG
marker = "ESP test",
execute = function(dz, item)
local rainDevice = dz.devices("Regenmeter") -- Your (virtual) rain device
local rainSwitch = dz.devices("Terasa") -- Your (triggered by bucket full) switch
local rainmm = 2 -- find out what 1 bucket full means in terms of mm
local rainTotal = 0
local timeSlice = math.min( (rainDevice.lastUpdate.secondsAgo / 3600), 10) -- at least 1 bucket in 10 hours
local rainAmountHour = dz.utils.round((rainmm / timeSlice),1)
if item.active then
rainTotal = dz.utils.round((rainmm + rainDevice.rain),1)
rainDevice.updateRain(rainAmountHour, rainTotal)
dz.log("One bucket full ==>> updating raindevice. rainrate: " .. rainAmountHour .. " mm/hr, " .. rainTotal .." mm in total today ", dz.LOG_DEBUG )
rainSwitch.switchOff().silent()
As indicated please put code into brackets.
You did not replace tippingbicketrain to Terasa everywhere in the script. So the script will not be triggered when Terasa is switched.
